M10 8v meistarinn 740whp
Postby gstuning » Sat 03. Sep 2011 21:18
Þetta er sko alvöru shit.
Robert wrote:I've just tested my 1602 on my dyno (Dynapack 5000) and it made 740whp with 95% duty on my new bosch 2200cc injectors. I have to raise the fuelpressure and give it more boost :)
This would give me around 800hp at the crank! So I guess its now the strongest M10 8v in the world right?
New boschs 2000cc Injectors
E85 fuel
Je pistons
H-rods
Custom custom, and custom :)
http://www.bmw2002faq.com/component/opt ... /t,362345/
Consept in short:
90mm bore with custom JE pistons, copperrings for sealing instead of headgasket, special modified oil channels.
1.8i head (very special) intakeports welded and moved up 30mm, new valve seats, modified racing valves 48/39mm, steel motorsport rockers, custom camshaft, CrMo retainers, special race springs 72/135 @ 12mm, head flow almost -> 250cfm
stainless twin entry exhaust pipe with borg and warner 72mm turbo with 1.10 A/R, 3.5" exhaust pipe to rearaxle
h-profile motornord rods 144mm (modified for m10 bearings, instead of m5), modified oilmarks etc etc
racing bearings
special m10 oilpump with rotor from m30 30% more flow
modified oilpan
228mm 4pad sinter with sachs performance 618 pressureplate
getrag 262 with e28 m535 driveshaft to e34 m5 rear axle, modified e28 trailingarms and special made drive shafts to 108mm cvsplice, protech special made shocks and springs and motorsport anti sway-bar. 11.5" ET Street slicks.
In the front its bilstein and adjustable coilon springs with adjustable camber plates, 301mm brembo brakes, and pedals from wilwood.
Plastic Zender fenders in front/rear.
car also have rollingcage down to Et 7.50sec
Autronic SM4 management system with 2200cc injectors and MSD CDi coils
Lots and lots of small and big details changes all over.
Goal = the most extreme m10 turbo engine in the world.
Gaurinn ætlar svo að reyna við 50psi boost næst þegar vélin fer á dynoið
Re: M10 8v meistarinn 740whp
Postby ppp » Sun 04. Sep 2011 04:32
Engir bakkskynjarar :thdown:
330d e46 (Mr. X!)
ppp
Postby Einarsss » Sun 04. Sep 2011 08:42
djöfulsins geðveiki! :twisted:
Postby Alpina » Sun 04. Sep 2011 17:59
Rosalegt,,,
er þetta ekki grunnurinn að F1 F/I back in the days
Postby sh4rk » Sun 04. Sep 2011 18:24
Eru þetta ekki tölunar á F1 BMW m12/13-1 vélunum
Siggi
E23 735i
E32 740i 6 spd 8)
E38 740d
E32 735i Shadowline Seldur
E32 740i Seldur
E32 740i RIP
sh4rk
Postby maxel » Tue 06. Sep 2011 03:40
sh4rk wrote:Eru þetta ekki tölunar á F1 BMW m12/13-1 vélunum
1300hp á 1.5l mótor, er hann með kubb?
Postby sh4rk » Tue 06. Sep 2011 07:05
Ekki hugmynd en 1300 hp á ca 80psi í blæstri
Siggi
E23 735i
E32 740i 6 spd 8)
E38 740d
E32 740i Seldur
E32 740i RIP
sh4rk
