Nurburgring report
Re: Nurburgring report
Postby bimmer » Mon 01. Feb 2010 11:43
Töffari #1:
Greinin:
auto motor und sport
Postby bimmer » Fri 05. Feb 2010 16:50
Postby Alpina » Sat 06. Feb 2010 13:36
þetta er semsagt GAMLA startpointið.. þar sem GP og NNS splittast saman
en ég man vel eftir þessum 300 m hæðarmun umræðu..
það er einstakt á svona braut,
ath pikes peak og einhverjar japanskar fjallaleiðir eru með eflaust meiri hæðar mun ,, en varla þar sem meðalhraðinn er eins og á Slaufunni
Postby fart » Sat 06. Feb 2010 14:38
Sambærilegt GPS plott sem ég tók sumarið 2007.
Græna línan er elovation
Rauða línan er hjartsláttur
Bláa línan er hraði.
Postby Alpina » Sat 06. Feb 2010 16:22
8)
Postby bimmer » Sat 06. Feb 2010 20:37
Flottur akstur:
Postby bimmer » Sat 13. Feb 2010 23:34
Postby kalli* » Sun 14. Feb 2010 01:46
Vá hvað ég sá þessar myndir og það fyrsta sem kom upp í hugann minn var ''Pearl Harbour''.
kalli*
Postby Kristjan » Sun 14. Feb 2010 12:28
20 ára gamlar framdrifnar tíkur á hringnum... jei
Postby bimmer » Mon 22. Feb 2010 00:53
Fjarskyldur ættingi Sveinka:
Postby bimmer » Mon 22. Feb 2010 00:54
Verið að byrrja einhverja mega hljóðveggi í Adenau :?
Postby Alpina » Mon 22. Feb 2010 01:35
bimmer wrote:Fjarskyldur ættingi Sveinka:
BARA kúl 8)
Postby bimmer » Fri 26. Feb 2010 12:00
USE THIS INFO AT YOUR OWN RISK!
Nordschleife Section A
Brave and precice through the fast early section will make the biggest impact on lap times.
Nordschlife Section B
A short sharp brake, you could try your left foot and then hard on the gas is better than a long lift through Flugplatz.
Nordschleife Section C
Relax and keep it tidy and it will seem straightforward enough, wait for the turn into the tight right.
Nordschleife Section D
Try to carry maximum speed through the first left right combination.
Nordschleife Section E
Remember under no circumstance back off through Ex Muhle, anticipate the easy exit and get on the power early.
Nordschleife Section F
This is fast so keep it very smooth for the confidence to keep it flat, try to not over brake at Kesselchen. Little time can be gained at Steilstrecken Kurve so don’t banzi this, and be precise in the banking.
Nordschleife Section G
You now enter the Green Hell this is a very slippery section in the wet with water flowing across the track a precise line is needed and you cannot go off line here, a late apex for the left-hander makes a better run through Wipperman keep in the grove for Brunnche and Eis Kurve.
Nordschleife Section H
The next section contains two jumps keep the power on through the left-hand exit this will benefit far more than any amount of bravery at the jump, carry as much speed as you can through the final swerves. For speed the Kleine Karussell needs to be attacked but is brutal on the car, the exit is critical to limit wheel spin so experiment with line here, remember fast exit is critical for speed on the straight out of Galgenkopf.
Nordschleife Section I
Antoniusbuche is the fast left handler, turn in when you see the kerb, a big slow down is needed for Hohenrain and you can use the tarmac apron here to give a late turn in, a short blast is required before the next right turn remember spins are common place here.
Postby bimmer » Sat 27. Feb 2010 10:56
Sveinbjörn - ég treysti því að þú verslir þér svona í ferðinni í vor!!!!! :lol:
https://www.nuerburgring-shop.de/defaul ... hop.detail
Postby Alpina » Sat 27. Feb 2010 11:32
Engar áhyggjur,,,,,,,
þetta verður ÖRUGGLEGA keypt
MEGA svalt 8) 8)
nú vantar bara ASCARI ristavélina :lol:
Users browsing this forum: Google [Bot] and 76 guests
