It is currently Sat 19. Jul 2025 04:06
PostPosted: Fri 18. Jul 2025 07:46
Armed robberies in GTA 6 are more intense and high-stakes than ever. With smarter AI, tighter escape routes, and heavier consequences for failure, surviving these heists requires more than just good aim. Whether you're robbing convenience stores, armored trucks, or high-security vaults, preparation and execution are key. Here are 13 tips to help you stay alive longer and make every robbery count.
Choose the Right Crew
Not all NPC crew members are created equal. Prioritize members with higher skills in driving, shooting, or hacking—they can be the difference between a clean escape and a shootout gone wrong.
Use Pre-Mission Scouting
Always scope out the location before committing. Look for exits, camera placements, and potential choke points. It may take time, but it reduces risk during the job.
Suppress Your Weapon
Start with a suppressed firearm if you want to delay triggering alarms. This buys you precious seconds to complete objectives or reach an exit.
Wear the Right Gear
Don’t go in with street clothes. Use light tactical gear that balances protection with mobility. Heavy armor slows you down too much during getaways.
Clear Civilians Fast
Civilians will call the cops or panic, which draws attention. Manage the room quickly, but don’t overdo it—high aggression can trigger more aggressive AI responses.
Always Have a Getaway Plan
Pre-park a fast vehicle in a nearby alley or garage. Avoid main roads, which are usually swarming with patrols within minutes of the alarm sounding.
Manage Reloading Wisely
Reload behind cover, not in the open. GTA 6 enemies are more aggressive and accurate, especially during extended shootouts.
Control the Clock
Time is everything. Don’t overstay just to grab extra cash. Exfil early if your crew starts taking hits or if reinforcements arrive.
Hack Surveillance Fast
If the job involves hacking, upgrade your gear beforehand. Fast hacking keeps alarms off longer and reduces incoming threats.
Use Distraction Tools
Smoke bombs or noise generators can disorient enemies and buy time for repositioning or escaping.
Learn Enemy AI Patterns
Cops and private security units now flank and flush more intelligently. Study their response times and patterns during lower-risk jobs.
Heal Up Between Phases
Bring snacks, stims, or healing sprays and use them between robbery stages when safe. Don’t wait until you’re nearly dead.
Use Earnings to Reinforce
Once you’ve started earning from robberies, reinvest wisely. Some players buy GTA 6 money early to get a head start on upgrades. If you're on Xbox, you might consider checking deals to buy GTA 6 money Xbox One from marketplaces like U4N, which many players turn to for convenience.
Mastering robberies in GTA 6 takes patience and smart play. By following these tips, you’ll boost your survivability and turn risky jobs into reliable income streams.
