1998 BMW M3 with LS3 Swap for Sale Bara í lagí
Postby Tommi Camaro » Sat 21. Jul 2012 23:36
Selling my 1998 BMW M3 with LS3 swap and 6 Speed T56 transmission.
$23,000 or best offer.
Car is located in Irvine California.
Wife just gave me permission to pick up a Z06 Vette and while I love my car, I always wanted a Z06.
Full story of the car and the build is Here http://forums.bimmerforums.com/forum/showthread.php?t=1624778 , I am hiding nothing, you can see the full build from stock. I've had the car for about a year. It currently has 119K miles on the chassis and only 1K on a freshly built LS3. I had a LS1 in it first, but had a valvetrain failure so the motor was pulled and I built the new LS3. I have over 30K in the car as it sits right now. On the last dyno session it put down 455whp and 435wtq. It stupid fast, it destroys my buddies E92 M3 with a supercharger that puts down 490whp.
The entire suspension was replaced, every bushing and all balljoints.
Only issues with the car are driver door lock solenoid sometimes doesnt work. It opens and closes with a key just fine. I also lost the remote control, so it only has a manual key. The Alarm is installed and functional just need the fob.
Mod List
Engine:
LS3 shortblock
LS3 heads
LS3 ported Intake manifold
LS3 Injectors and rail
Melling High Pressure Oil Pump
ARP Head Bolts
ARP Crank pulley Bolt
PTM 92MM Cable Throttle body
LS1 Wiring Harness
Custom 4inch intake
85mm Maf
222/230 EPS Camshaft
ACT clutch
lightened flywheel
2002 Camaro T56 Transmission with 40K miles on it.
Aeromotive stealth fuel pump in custom holder intank
MGW Shifter
NAHR swap kit which includes - NAHR stainless steel headers, custom CNC motor mounts, CNC Transmission mount, custom driveshaft, custom steering shaft. BMW (E36) 3-Series / New Age Hotrods Online Shop for more details
Custom exhaust with dual cats and Dinan catback.
Suspension:
AKG Subframe bushings
AKG Diff bushings
All new balljoints front and back
All new remaining bushings
Bilstein sport struts and shocks
Tein S-tech springs
New shock and strut mounts
New Swaybar endlinks and rubber mounts
New DBA drilled slotted front rotors
New stoptech pads
3.91 ring and pinion using the stock M3 LSD
BBS CH 18x10 Wheels
Nitto NT05 Tires 265/35/18 square setup
Misc:
Custom FXR retrofitted HID projectors with 55w morimoto ballasts.
BSW speakers, Alpine headunit with ipod adapter and bluetooth.
Car has working ABS, Airbags and Air conditioning. It has cats, but Smog is buyers responsibility.
Car is super fast, weighs about 3100lbs. Everything works on it. Interior is 9/10 exterior about 9/10 as well, has couple of dings in the paint, but overall very good.
LS3 swap BMW M3 - YouTube
eas | E36 M3 Corvette LS3 V8 Engine Swap Dyno - YouTube
523 E61 Touring
Offical E30 H8R CREW
Member ONE
Tommi Camaro
Re: 1998 BMW M3 with LS3 Swap for Sale Bara í lagí
Postby bimmer » Sun 22. Jul 2012 01:45
Flottur að utan!
Postby JonFreyr » Sun 22. Jul 2012 09:54
Geggjaður bíll í alla staði !!! Djöfull held ég að þetta tussist áfram 8)
Volvo 945 Túúúúúrbó
JonFreyr
Postby gardara » Sun 22. Jul 2012 21:19
geðveikt!
██ 1974 BMW 1802
██ 1994 BMW E36 332i sedan
██ 2008 BMW E92 335i
██ 2013 BMW F30 320d
Postby ValliFudd » Sun 22. Jul 2012 21:37
hvað er málið með þessa golfkúlu?
ValliFudd
Postby gardara » Sun 22. Jul 2012 21:51
Þetta er Hurst t56 gírhnúinn
██ 1974 BMW 1802
Postby bimmer » Sun 22. Jul 2012 23:17
Postby Raggi M5 » Mon 23. Jul 2012 12:15
djöfull er þetta snyrtilegur bíll! M5 killer
E39 525d Touring ´03
Toy Yaris T-Sport ´02
Yamaha R1 ´05
Raggi M5
Postby Tommi Camaro » Thu 26. Jul 2012 09:48
Raggi M5 wrote:djöfull er þetta snyrtilegur bíll! M5 killer
523 E61 Touring
Member ONE
Tommi Camaro
Postby Axel Jóhann » Thu 26. Jul 2012 10:13
STÖNGÍBRÓK!
Tommi, villtu slíta vélina og kassann úr camro hjá þér og láta mig hafa? :angel:
Postby Tommi Camaro » Thu 26. Jul 2012 12:08
Axel Jóhann wrote:STÖNGÍBRÓK!
Tommi, villtu slíta vélina og kassann úr camAro hjá þér og láta mig hafa? :angel:
Ef það er veski á bakvið stór orð er allt hægt :mrgreen:
523 E61 Touring
Member ONE
Tommi Camaro
Postby gylfithor » Sun 29. Jul 2012 14:59
djöfull er hann geðveikur !
bmw e39 540 '98
bmw e36 318 '96
benz c280 '96
bmw e36 316i '96 compact rifinn
skoda octavia vrs turbo '02 seldur
bmw e36 325is '93 seldur
bmw e36 316i '92 seldur
bmw e36 318i '93 seldur
bmw e36 318i '96 seldur
bmw e36 318is coupe '95 seldur
og fullt af druslum seldar
gylfithor
