BMW S1000RR
BMW S1000RR
Postby JOGA » Sat 27. Jun 2009 06:01
Læt vaða á að setja þetta hér. Þetta er í það minnsta BMW.
Nýtt hjól að koma frá BMW. Ætla að keppa í heimsmeistara mótinu fyrir "superbikes" og þá þurfa þeir að framleiða þúsund stykki. Kraftmesta 1000cc hjól heims. 193hp og vélin bara 59kg :shock:
Finnst þetta vel flott hjól 8)
Meiri uppl. hér
Overview of the BMW S 1000 RR Technical Highlights:
Best-in-class performance and supreme riding dynamics in the supersports segment.
Engine output 142 kW (193 hp) at 13,000 rpm, peak torque 112 Nm (82.5 lb-ft) at 9,750 rpm.
Weighing 206.5 kg (455.3lb) in road trim and with a full tank, this is the lightest supersports in the 1000-cc class with ABS.
Best power-to-weight ratio in this class of just 1.05 and, respectively, 1.06 kg (2.31 and, respectively, 2.34 lb) per horsepower without/with Race ABS.
Optional Race ABS for outstanding brake performance and safety; Weight of the entire system just 2.5 kg (5.51 lb), while other systems of a similar kind weigh up to 10 kg.
Optional DTC Dynamic Traction Control in conjunction with Race ABS for optimum performance and maximum active safety when accelerating.
Only supersports machine with Race ABS and DTC Dynamic Traction Control.
Various riding modes available at the touch of a button for wet surfaces, regular road requirements, race tracks with sports tires and race tracks with slicks.
All-round set-up, coordination and balance of Race ABS, DTC Dynamic Traction Control and engine management for all four riding modes.
High-speed, extra-sturdy valve drive with individual cam followers and titanium valves following the example of BMW ’s Formula 1 engines.
Innovative exhaust system with a small and short rear-end muffler, pre-silencer and electronically controlled interference pipe flaps as well as a fully controlled exhaust gas manifold and two fully controlled three-way catalytic converters.
Optimum gas dosage combined with maximum functional reliability ensured by E-gas (ride-by-wire), incorporating two Bowden cables (opening and closing cable) leading to the throttle butterfly adjuster.
Fulfillment of all environmental standards with the potential to meet future emission requirements ensured by two fully controlled catalytic converters and digital motor electronics.
Damper elements with a wide range of adjustment on the spring base, the inbound and rebound stroke, as well as the greatest damping reserves, particularly for racing.
New, clearly defined, simple and straightforward options to adjust the suspension and running gear.
Aluminum tank unique in this segment for further reduction of overall weight.
Supreme handling combined with best-in-class high speed and braking stability.
Multi-functional instrument cluster with racing features such as a lap timer; the rider is able to set all functions directly from the ends of the handlebar.
New generation of switches with optimized ergonomics.
Supreme aerodynamics and sporting ergonomics ideal for both the tall and short rider.
Optional HP Gearshift Assistant for shifting up without operating the clutch and without the slightest interruption of torque and pulling power.
Wide range of equipment, special features and options tailored to the S 1000 RR and naturally offering full BMW quality.
Re: BMW S1000RR
Postby iar » Sat 27. Jun 2009 10:56
Þessi hestaflatala fær mann ósjálfrátt til að setja kg/hp í samhengi við 328i. :lol:
Re: BMW S1000RR
Postby JOGA » Sat 27. Jun 2009 11:09
iar wrote:Þessi hestaflatala fær mann ósjálfrátt til að setja kg/hp í samhengi við 328i. :lol:
Já ég verð að viðurkenna að ég gerði nákvæmlega það sama :lol:
Re: BMW S1000RR
Postby Jón Ragnar » Sat 27. Jun 2009 17:26
Voðalega líkt R6 / R1 / Fireblade samt :oops:
Re: BMW S1000RR
Postby BMWaff » Sat 27. Jun 2009 21:27
Eitt svona takk
Núið:
BMW 730d '04
BMWaff
Re: BMW S1000RR
Postby Raggi M5 » Sat 27. Jun 2009 21:47
uuuuuuuu jááááá takk !!!!!
8) 8) 8) 8) 8) 8) 8) 8) 8) 8) 8) 8) 8)
E39 525d Touring ´03
Toy Yaris T-Sport ´02
Yamaha R1 ´05
Raggi M5
Re: BMW S1000RR
Postby HAMAR » Sat 27. Jun 2009 23:26
Me like very nice 8) 8)
Re: BMW S1000RR
Postby Mánisnær » Mon 29. Jun 2009 17:58
Váááá gleymum asíu, þetta verður hjólið eftir 2 ár :|
Mánisnær
Re: BMW S1000RR
Postby Thrullerinn » Tue 30. Jun 2009 10:24
#1 -> BMW hjól
#2 -> 193hp og 206kg
#3 -> 8)
Re: BMW S1000RR
Postby Einarsss » Tue 30. Jun 2009 11:04
held ég myndi pottþétt fá mér hvíta hjólið .. ef ég myndi þora að hjóla á svona götuhjólum :shock:
Re: BMW S1000RR
Postby bebecar » Sat 04. Jul 2009 01:01
BMW Motorrad eru svakalegir þessi árin og toppa í alveg ótrúlegustu deildum... HP Sport, HP2, Megamoto, Einhver krúser sem ég man ekki hvað heitir og svo S1000RR... plús allt hitt þetta "venjulega"...
