E30 320is BARA flottur
Postby Alpina » Wed 08. Apr 2009 22:14
Re: E30 320is BARA flottur
Postby gardara » Wed 08. Apr 2009 23:08
pff maður þarf að vera með aðgang þarna
██ 1974 BMW 1802
██ 1994 BMW E36 332i sedan
██ 2008 BMW E92 335i
██ 2013 BMW F30 320d
Postby Mazi! » Thu 09. Apr 2009 00:48
Nenni ekki að skrá mig þarna :roll:
póstaðu myndunum..
Postby zarko » Thu 09. Apr 2009 01:02
Já sammála mása pósta myndum!!
Stoltur E30 eigand www.e30.is
zarko
Postby ValliFudd » Thu 09. Apr 2009 03:23
invite only?
Sorry, registration has been disabled by the administrator.
ValliFudd
Postby Alpina » Thu 09. Apr 2009 07:44
Pósta myndum í kvöld..
Postby BjarkiHS » Mon 13. Apr 2009 13:00
Alpina wrote:Pósta myndum í kvöld..
Jæja.............. hvar eru svo myndir ?? :bawl:
Bjarki Steingrímsson.
8253105
Jeremy Clarkson wrote:"Handbuilt" is just another way to say "the doors will come off"
BjarkiHS
Postby Alpina » Mon 13. Apr 2009 13:09
Hi, here are some pics of my 320is rebuild
The 320is was produced in Regensburg 1987 - 1990 and was sold only on the Italian and Portuguese market. The engine is a 1990 cc version of the S14 engine.
Gearbox (Getrag 260, with dogleg shift pattern) plus rear axle are shared with the M3E30. A total of 3746 cars were produced.
The construction of the roll-cage was started in the autumn of 2004:
The cage painted in black
The car has just gotten the full cage approved by the Swedish car authorities (equivalent to the German TÜV)
Ground Control kit with camber/caster adjustment, delrin wishbone bushings. The pict is showing the old break setup with Yellow Pagid RS-19 and Zimmermann cross drilled rotors. The rotors didn't last for long so they are now replaced by 4 pot Porsche calipers and Tarox rotors
After registration of the cage the original seats where replaced with two Sparco Corsa's and two sets of Sabelt 3inch 6-point harness.
Exhaust system from Köhler Racing, DTM style with 2x63mm (ID).
The exhaust fitted. The tailpipes had to be cut off, and reshaped, since the M3E30 has the pipes straight while the 320is angled.
The original Girling calipers were replaced by Porsche 4-pot calipers with Pagid RS 4-4 and Tarox 278x25mm rotors.
I removed the dust shield and had it replaced with an stainless steel brake cooling shield.
Willwood brake reduction valve.
The steering-rack rubber guibo replaced by an alloy ditto
The original steering rack (4.1 turns) was replaced by Zionvilles modified one from an M3E36 (2.7 turns)
Last winter the engine was rebuilt with forged JE pistons (with Total-Seal gapless rings) increasing the compression from 10.8:1 to 11.5:1 (M3 195hp: 10.5:1, M3 EvoII 11:1).
The cams was grinded to 292degrees (intake) and 288 (exhaust). The top + tb was ported, new valve steering in brass, mira-grinded valve seats, top and block decked, lash caps, the crank + flywheel polished and balanced, new oil pump, new bearings, new water hoses, etc, etc
Adjustable cam gears
The engine ready after four months of work...
The engine in place. Time for the C/f plenum and Alpha-N from John/MAXX to be mounted!
The Mototronic box attached to the Alpha-N
The standard map loaded.
Almost ready for mapping. Note the brake ducts in glassfibre. They are mounted where the fog-lights + original brake duct normally goes.
I had a hard time relocating the brake fluid reservoir since the c/f plenum+cage+reloacted fuse box+sparco strut bar used up the existing space.
This was the first attempt where I mounted the brake fluid reservoir to the firewall. This turned out to be a bad choice. I later moved it to a bracket made out of stainless steel attached to the old AFM mount. This is the place where most people with c/f boxes mount their p/s reservoir. This meant that I had to move the p/s reservoir even further forward, to just behind the headlights ;smilie[45]
Entering the Karussell at Nürburgring last summer.
Postby BjarkiHS » Mon 13. Apr 2009 13:17
Glæsilegt .
takk fyrir þetta :)
8253105
BjarkiHS
Postby gunnar » Mon 13. Apr 2009 13:32
Ansi flott græja.
Velti því samt ósjálfsrátt fyrir mér hvort það hefði ekki verið gáfulegra að taka bara venjulegt E30 boddí og aðra vél en S14 ef smíða átti trackbíl..
Sá á myndunum að hann er með sömu fjöðrun og ég. :drool:
Postby Alpina » Mon 13. Apr 2009 13:46
gunnar wrote:Ansi flott græja.
Gunnar ........ :lol: :lol:
þetta er oem vél í þessum bíl
Postby gunnar » Mon 13. Apr 2009 14:12
Ég veit það alveg gamli...
Ég var bara að benda á að mér þætti vitleysa að taka svona bíl og breyta honum í trackbíl.
Hluti af ástæðunni fyrir því er þessi mótor. Bara dýrt að fá einhver hestöfl útur þessu.
Postby maxel » Mon 13. Apr 2009 15:44
Og 320is er nú ekki beint á hverju strái.
Postby Alpina » Mon 13. Apr 2009 17:45
Þetta er BARA kúl..
Myndi ekki tima M3 í svona .. fengi mér S62 eða S50B32 í slíkann bíl
Postby fart » Mon 13. Apr 2009 17:52
Algjör della að breyta rare bílum í track græjur :lol:
Users browsing this forum: Google [Bot] and 11 guests
