It is currently Thu 07. May 2026 10:24
Post new topic Reply to topic  [ 9 posts ]
 Post subject: Finnskir tunerar S38
PostPosted: Mon 15. Dec 2008 23:27
Veit ekki hvort ég var búinn að pósta þessu áður,, ef svo er þá :oops:
M5 3.6/3.8 engine tuning
Dear BMW Tuners
We have started to tune-up BMW M5, 6 -cylinder engine about six years ago in Finland.
The engine was were started is normal factory make M5 3,6 litre ( S38B36 ) -engine, that delivered in a dynamometer 317 Hp and 369 Nm of torque. The same dyno has been used always and every time at all the tests below:
Orginal engine
Wetterauer Chip 331 Hp / 391 Hp
110,6 Nm / litre / 1000 cc
93,6 Hp / litre / 1000 cc
Stage 1. Race engine
-Schrick 280 Camsaft
-Unichips ECU
-Adjustable Camgears
-Whit orginal airbox and exhaust manifold
345 Hp / 6600 rpm
406 Nm / 5270 rpm
114,8 Nm / litre / 1000 cc
97,6 Hp / litre / 1000 cc
Stage 2. Race engine
-Schrick 280 Camsaft (inlet/Exhaust)
-Hestec ECU
352 Hp / 6650 rpm
415 Nm / 5200 rpm
117,4 Nm / litre / 1000 cc
99,6 Hp / litre / 1000 cc
Stage 3. Race engine
-Inlet camsaft 296 made by Mauri Virtanen, Finland
-Exhaust camsaft 280 Schrick
-Cylinderhead works by Hannu Makkonen, Finland
-Throttle body M5 3.8 (S38B38) 50 mm
-Inlet valve 38 mm
-Wiseco Piston BMW M3 2.3 (3580 cc)
-Compression ratio ~ 11,2:1
-Stock cranksafth + conrods
-Whit out orginal airbox + ITG Megaflow special made air filter
-Orginal exhaust manifold
-Hestec ECU
390 Hp / 6900 rpm
424 Nm / ~6000 rpm
118,4 Nm / litre / 1000 cc
108.9 Hp / litre / 1000 cc
Stage 4. Race engine
-Inlet camsaft 296 by Mauri Virtanen, Finland
-Inlet valve 39 mm
-Wiseco Piston BMW M3 2.3 / 94 mm
-Compression ratio 12:1
-Stock S38B36 Cranksaft + stock conrods (3580 cc)
-Whit out airbox
-Stock air horns
-ITG Megaflow special made air filter
-Adjustable race exhaust 6-2-1 + exhaust pipe made by Marko Roni
-Hestec ECU
435 Nm / 6100 rpm
4000-7000 rpm + 410 Nm
121,5 Nm / litre / 1000 cc
417 Hp / 7000 rpm
116,4 Hp / litre / 1000 cc
Stage 5. Race engine
-Cylinderhead works Hannu Makkonen, Finland
-Inlet valve 39 mm
-Wiseco Piston special made (bore 94,5)
-Wiseco light weight piston pins
-BMW M5 3.8 stock cranksaft (3785 cc)
-BMW M5 3.8 stock conrods
-Steel flywheel 4 kg + Alcon 184 mm twinplate clutch
-Piston-, conrods-, cranksaft-, flywheel all balanced (single + together)
-Adjustable stainless steel Race exhaust 6-2-1+ stainless steel exhaust pipe made by Marko, Finland
-Whitout airbox
-Adjustable air horn
-Special made ITG Megaflow air filter
-Haltec E11v2 ECU
470,6 Nm / 6000 rpm
4000-7000 rpm + 420 Nm
124,3 Nm / litre / 1000 cc
436 Hp / 7000 rpm
115 Hp / litre / 1000 cc
I’m not selling engines or parts, because tuning (whitout owerchargin) engines is only my passion. I'm not even using the engine in a E34 body, we have fitted it to a BMW E30 M3 -model car that is fully equipped to race but fully legal to use in traffic.
With the last Stage 5. -engine, I'm also tuning a non-turbocharged engine M5 3.8 litre (S38B38) 3795cc race engine, that has experienced all the possible changes to get better. Our passion is to make the most powerfull non-turbocharged M5 3.8 (3795 cc) engine there is in the north side of the world.
The accomplishment is to achieve over 490 Nm of torque (+129,1 Nm / 1000 cc) and plus 475 Hp (+125,1 Hp / 1000 cc) of power.
Later, I can report more about the engine project…
Best Regards
Jari Valtti, Finland
Ps. Fotoalbum; http://Camber.kuvablogi.com/
__________________
Þetta eru engar smá tölur,,,,,,, :shock: :shock: :shock: :shock:
PostPosted: Mon 15. Dec 2008 23:38
Ég þakka mér 8)
PostPosted: Mon 15. Dec 2008 23:43
gstuning wrote:
Ég þakka mér 8)
:shock: :idea: :idea: :idea:
PostPosted: Mon 15. Dec 2008 23:44
nevermind ég nenni ekki að byrja
PostPosted: Mon 15. Dec 2008 23:45
skil ekkert hvað þú meinar :?
PostPosted: Mon 15. Dec 2008 23:54
Gunni fann þetta fyrir þig í gær þegar hann var að leita að upplýsingum um M5 vélar fyrir þig. Ekki vera svona :roll: heldur þakkaðu honum fyrir hjálpina og vertu svona 8)
En annars mjög svalir gaurar þessir finnar
E30 S50B32
X5 3,0i ´02
Artic Cat ZR500 ´98
GSTuning
PostPosted: Tue 16. Dec 2008 13:21
Ég hringdi í gst ... og hann sendi mér póst með stærðinni í mm
og ég þakkaði fyrir ..
en rétt er að hann sendi linka ....... sem ég var alls ekki búinn að opna ,,eða taka eftir
þetta sem ég copyaði var svar inni á m5board,, til Mert þar sem menn eru ekki alveg að kaupa rökin hans ,, og einn sendi þetta svar á móti
 Post subject: Re: Finnskir tunerar S38
PostPosted: Sun 14. Nov 2021 19:17
Áhugaverð.
Sent from my SM-G975F using Tapatalk
e34 "M5" Nauticgrun
BMW X5 4,4i sport
e34 525T TDS Brokatrot
e32 740i Calypsorot
PostPosted: Mon 15. Nov 2021 23:42
Bartek wrote:
Áhugaverð.
Heldur betur
þú verður að turbóa S38!
