1500hö S50.
1500hö S50.
Postby gstuning » Fri 07. Nov 2008 09:54
iXer wrote:Just dynoed at VM Performance in Västerås, Sweden:
Its a BMW M3 3,0L 6 cyl engine with Autronic SM4 with upgraded injector drives and 2 High power R500 CDI´s.
It has a Borg&Warner S500 custom 91 mm turbo and running on methanol.
1507hp @ 8500 rpm
1357nm(1010lb/ft) @ 7600 rpm
3.5bar(50psi) Boost
Postby SteiniDJ » Fri 07. Nov 2008 12:00
Úff, ekkert lítið afl :o Svíar, turbo masters!
Postby arnibjorn » Fri 07. Nov 2008 12:16
Haha weak.. af hverju ekki að fara bara í 2000hp fyrst að hann var kominn yfir 1500??
2000hp er klárlega inn í dag.
Postby Einarsss » Fri 07. Nov 2008 12:16
arnibjorn wrote:Haha weak.. af hverju ekki að fara bara í 2000hp fyrst að hann var kominn yfir 1500??
já þokkalega 1500hp= wannabe
Postby Angelic0- » Fri 07. Nov 2008 12:17
flott lausn með háspennukeflin :)
hitinn frá turbo hefði bara valdið veseni :)
Postby Turbo- » Fri 07. Nov 2008 18:29
uhm vá, 50psi(3,5bar)
Turbo-
Postby Kristjan » Fri 07. Nov 2008 18:52
Turbo- wrote:uhm vá, 50psi(3,5bar)
PFF það er örlítið meiri þrýstingur en í dekkjunum hjá mér, weak
Postby Einarsss » Tue 11. Nov 2008 14:30
dyno video
