Twin Turbo BMW... ok.. en E60M5TT
Postby fart » Fri 16. Feb 2007 19:12
Just got the BMWCar magazine and reading it as i type. The twin turbos are not actually located under the hood. They are under the rear bumper!!, where the rear silencers used to be. The charged air is forced back via a pipe leading along the passenger side of the car, hidden by the sill. Up through the wheelarch, the pipe leads directly to the huge, custom made intercooler which is mounted in the front of the engine bay.
The guy who owns it Ron is a millionaire with a lot of spare cash and seems to have written a blank cheque to get this conversion done. He's owned 75 cars. Power is claimed to be 800bhp. He owns Currency Motors and will build ten cars with the twin turbos for $350,000 each. The problem comes from the oil and electrics being run underneath the car to supply the turbos. But you get over the problem of heat dissipation if they were located under the hood. The engine has been left alone. It took 4 months to crack the electronics and do the remapping. Developing and testing the hardware took 4 months too. Turbo lag problems - no says the owner as the hybrid design minimizes lag and maximizes responsiveness. Transmission has been left alone!!
Their website is www.currencymotorcars.com
690whp.. :D
Postby Aron Fridrik » Fri 16. Feb 2007 19:15
sá einmitt myndband af corvette með túrbínunar að aftan.. nokkuð magnað :shock:
Postby ///M » Fri 16. Feb 2007 19:32
úú e9
2016 BMW X3 sDrive28i
///M
Postby Jón Ragnar » Fri 16. Feb 2007 19:34
///M wrote:úú e9
Geðveikur E9 :shock:
Postby JOGA » Fri 16. Feb 2007 20:06
Túrbínur í afturstuðarunum ?
Gæti það ekki orsakað turbo-lag?
Postby Aron Fridrik » Fri 16. Feb 2007 20:20
JOGA wrote:Túrbínur í afturstuðarunum ?
held að það sé boost loss á um eitt pund :?
Postby ValliFudd » Fri 16. Feb 2007 20:39
Þeir hafa verið að gera þetta á snjósleðum.. þar sem það er ekkert sérstaklega mikið pláss þarna frammí á þeim..
ValliFudd
Postby gstuning » Fri 16. Feb 2007 20:46
þetta hefur ekkert með það að segja,
heldur tímann sem tekur að mynda nægann þrýsting til að túrbinan snúi öxlinum sem snýr compressornum nógu hratt til að fæða vélina
Postby Aron Fridrik » Fri 16. Feb 2007 20:48
já ok.. bara þegar þeir gerðu þetta á corvette þá sögðu þeir að þeir voru að tapa einu pundi út af staðsetningunni..
Postby gstuning » Fri 16. Feb 2007 20:59
aronisonfire wrote:já ok.. bara þegar þeir gerðu þetta á corvette þá sögðu þeir að þeir voru að tapa einu pundi út af staðsetningunni..
þetta gerir það líka enn það er ekki aðal ástæðan fyrir því að þetta sé verri staður,
Postby íbbi_ » Fri 16. Feb 2007 21:02
í c4 ZR1 voru þeir yfirleitt settar undir bílin þar sme það var ekki pláss í vélarýminu
Postby Svíþjóð. » Fri 16. Feb 2007 21:31
Skilst samt að þrýstimismunur ef að intercooler sé einnig minnki spool-up tíminn umtalsvert (m.v n.ic.)og þá vegna einmitt meiri kælingar sem að er möguleg vegna lengda pípanna :drunk: (??óskiljanlegt??)
Hef skoðað remote mounted turbo í ls1 camaro, var "mighty fine".
--Óþokki--
---T5R T-GUL---
---Heja Sverige---
Svíþjóð.
Postby ///M » Fri 16. Feb 2007 22:23
Svíþjóð. wrote:Skilst samt að þrýstimismunur ef að intercooler sé einnig minnki spool-up tíminn umtalsvert (m.v n.ic.)og þá vegna einmitt meiri kælingar sem að er möguleg vegna lengda pípanna :drunk: (??óskiljanlegt??)
jebb
///M
Postby bjahja » Fri 16. Feb 2007 23:15
Djöfull er twin turbo m5 crazy samt :shock:
bjahja
Postby bimmer » Fri 16. Feb 2007 23:45
Klikkuð græja!!! :shock:
