Nowack IN500 M5
Nowack IN500 M5
Postby Raggi M5 » Tue 25. Mar 2003 00:18
Ég hef nú bara aldrei heyrt um þessa týpu áður.......
Nowack IN500 M5
A relative newcomer on the tuning scene, the German company Nowack proves that there is still quite a bit of room for improvement in the BMW M5 engine bay. By modifying the intake and exhaust systems, which Nowack found to be leaving the M5 gasping for air, power rises over 100 horsepower with a similar increase in torque, resulting in a healthy 102 horsepower per litre. Each throttle body is gas-flowed and the butterflies are reshaped to minimise airflow intrusion, the cylinder heads are ported and polished, the race-style exhaust headers and catalysts are built in-house, and the camshafts are also replaced. While the 0-60 mph shows a definite improvement, it is at higher speeds that the IN500 reaches peak performance. 124 mph (199 km/h) arrives in just 14.6 seconds and by removing the speed limiter, terminal velocity jumps to just 2 mph shy of the 200 mph barrier or a whopping 317 km/h.
The clutch also receives an upgrade but still remains as docile as the standard unit at low speeds and around town. A modified ECU is also part of the package, allowing the IN500 to accelerate from 20 mph in 4th gear without protest from either the engine or drivetrain. Floor the throttle on a long stretch of road and the creamy smooth power delivery is almost enough to make you forget that you passed 60 mph faster than a Ferrari F355 and 124 mph 1.5 secods quicker than the 0-100 mph time of a Qvale Mangusta (just some interesting comparos for you). To keep this M5 planted, Nowack drops it by 35mm and adds uprated springs and anti-roll bars from Eibach, Sachs dampers and 19-inch BBS wheels covered in Yokohama rubber. The brakes receive 380mm rotors in front and 322mm units at the rear with road-race pads. The ride quality remains remarkably supple and comfortable, roll is reduced, turn-in and steering feel both enhanced and the brakes are completely fade-free. A 4-door supercar this certainly is.
Specifications
Base Price, USD -
Engine Type dohc V8
Powertrain Layout front engine/rwd
Displacement, cc 4941
Horsepower@rpm 503@7700
Torque lb-ft@rpm 465@3400
Curb Weight, lb -
0-60 mph, sec 4.5
0-124 mph, sec 14.6
600 ft slalom, mph -
60-0 mph, ft -
Top Speed, mph 198
E39 525d Touring ´03
Toy Yaris T-Sport ´02
Yamaha R1 ´05
Raggi M5
Postby gstuning » Tue 25. Mar 2003 00:39
Ég man að ég var að rífast einu sinni við gæja sem sagði að nýji M5 bíllinn fengi 70% auka power með kubb,
Nowak eyddi milljónum að fá 100hö
Þetta er M5 kóngurinn í NA tjúning
Postby oskard » Tue 25. Mar 2003 00:55
NA power rúlar ;) get varla beðið eftir e60 v10 m5 *slef* :mrgreen:
oskard
Postby rutur325i » Tue 25. Mar 2003 02:50
nowack er snilldar tjúning fyritæki sem starfar í þýskalandi (döh) og er að sérhæfa sig í m5 sem þeir kalla já n500, þeir bæta líka bremsur til muna og er nowack m5 með aðra styðstu bremuvegalengd í production car að ég held. allar frekari uppl. á www.m5-n500.de snilldar gaurar :!:
Renault 19 '95 - bráðabirgða
BMW E-30 325i; IM-870, Farinn
BMW E-30 320i; IR-406, Seldur
rutur325i
Postby bjahja » Tue 25. Mar 2003 07:42
Þetta er virkilega töff bíll, loftintökin að framan eru töff.
bjahja
Postby Jói » Tue 25. Mar 2003 08:31
Mér finnst loftinntökin skemma fyrir.
Jói
Postby hlynurst » Tue 25. Mar 2003 10:58
Hvað er þetta framaná svuntunni? Vélbyssustútar að hætta James Bond?
hlynurst
Postby Haffi » Tue 25. Mar 2003 11:24
Mér finnst minn alveg nóg þar sem ég keyri eins og kelling :roll:
Haffi W. Schnurrenberger.
Haffi
Postby Kull » Tue 25. Mar 2003 13:31
Það þyrfti bara að samlita loftinntökin, þá væri þetta fínt.
C32 AMG Carlsson
Toyota Land Cruiser 80
Subaru Impreza GX - beater!
Kull
Postby bebecar » Tue 25. Mar 2003 13:34
Þetta er bíll sem vit er í! Skítt með loftinntökin, þau þjóna ákveðnum tilgangi!
Postby Halli » Tue 25. Mar 2003 14:24
þetta er geðveikur bíll vitið þið hvað hann kostar?
Corvette c5
Bmw 330i
Halli
Postby Svezel » Tue 25. Mar 2003 15:12
N/A tuning all the way :D
Og ég sem hélt að M5 væri geðveiki...
Svezel
Postby Gunni » Tue 25. Mar 2003 16:01
Svezel wrote:N/A tuning all the way :D
fyrir hvað stendur N/A ?
Gunni
Postby Kull » Tue 25. Mar 2003 16:16
Naturally Aspirated. Það er bíll sem "andar eðlilega", þ.e. er ekki með turbo eða supercharger sem dælir inn lofti.
C32 AMG Carlsson
Kull
Postby Alpina » Tue 25. Mar 2003 20:28
Ég man eftir því bmwm5 .com gengið fór að skoða þennannbíl og urðu FREKAR svekktir
http://www.bmwm5.com/articles/germany/germany.html
