AA Z3 Coupe Turbo
AA Z3 Coupe Turbo
Postby Svezel » Sun 17. Apr 2005 12:43
Specification:
0-60mph: 3.6 sec
0-100mph: under 7.4 sec (estimated with smoking tires)
1/4 mile: 11.6 sec / 131 mph
Horsepower: 726.00 BHP at flywheel @ 21 psi
Fuel: 93 octane (pump gasoline super unleaded)
Engine:
* 1999 S52 fully bulit engine. JE Pistons / Pauter rods
* AA Turbo spec camshafts
Turbo Kit:
* AA custom intercooler 1300 CFM with air deflector 12.9x3.5x20 core 2.5" in/out
* AA custom auxillary fan
* Garrett GT40R Turbocharger
* AA turbo manifold with external wastegate upgrade
* HKS GTII 50mm racing wastegate
* Greddy oil catchcan
* HKS racing bypass valve
* AA constant torque hoseclamps
* AA custom 4.0" intake plumbing to turbo
* K&N Air filter with low pick-up intake
* Kevlar thermal wrap on all turbo plumbing
* Intake manifold thermal wrapped
* AA custom software/dyno tuned
Additional Cooling:
* AA custom aluminum radiator
* AA custom water/alcohol injection system with (2)
accumulators
* AA custom water/alcohol reservoir with thermal wrap
* AA dual water/alcohol injector nozzles
Instruments:
* Stock instruments
* Custom boost gauge with chrome ring replaced clock
* Greddy Turbo timer
* Greddy electronic boost controller
* Lean/Rich mixture gauge
* Oil Temperature gauge
Fuel:
* Custom 14mm I.D. fuel hose (stock = 7.5mm)
* Custom 1000 HP fuel pump
* Custom hi-flow fuel filters
* AA custom dead-end fuel rail
* AA custom 550cc fuel injectors
* AA custom external fuel pressure regulator with liquid filled gauge
Ignition:
* AEM ignition module / iridium plugs
Traction Control:
* Racelogic
Exhaust:
* AA custom 3.0" exhaust with dual 3.0" resonators
* (4) 3.5" exhaust tips
Clutch:
* Sachs 4 puck metal race clutch
* AA GEN3 Aluminum 12.0 Lb Flywheel
Differential:
* AA Custom 40% lock up with 2.79:1 ratio
Shifter:
* AA Short Shifter Level 4 kit with AA Tuning Knob
Suspension:
* Eibacjh Race springs 550lbs front 700 lbs rear
* Ground Control adjustable camber/caster plates
* Adjustable Koni shocks
* Factory swaybars
Wheels/Tires:
* Kinesis K58
(F)18x8.5
(R)18x11
* Michelin Pilot Sport
(F) 235/40ZR18
(R) 315/30ZR18
Brakes:
Front-Brembo gas/slotted 355x32 on 2 piece hat with Brembo 4 piston caliper
Rear -Brembo gas/slotted on 2 piece hat with Brembo 4 piston calipers
Myndir
Grein
Hress þessi :shock:
Svezel
Postby fart » Sun 17. Apr 2005 12:51
Svakalegur.
Gaman að sjá hvað þú ert að slá inn á google þessa dagana... "Turbo Z3 Coupe"... :twisted:
Postby Arnar » Sun 17. Apr 2005 13:12
21 psi Úfffff Þetta er rosaleg græja 8)
Feitur rass !
Arnar
Postby Djofullinn » Sun 17. Apr 2005 13:35
Gjööööööööðveikur bíll! :bow:
Postby Kristjan » Sun 17. Apr 2005 15:35
hlutirnir gerast varla mikið svalari.
Postby bebecar » Sun 17. Apr 2005 15:56
Þetta er rosaleg KICKASS græja maður!
Flottur rumpur á þessu líka 8)
Hvernig væri að þú haldir bara þínum Z Coupé og betrumbætir hægt og rólega (þangað til M coupé bíllinn hér heima verður til sölu) og færð þér bara einhver fleiri skemmtileg tæki með :wink:
Postby Jss » Sun 17. Apr 2005 18:18
Geggjaður bíll, svakaleg orkan í þessu. :shock: :shock:
bebecar wrote:Hvernig væri að þú haldir bara þínum Z Coupé og betrumbætir hægt og rólega (þangað til M coupé bíllinn hér heima verður til sölu) og færð þér bara einhver fleiri skemmtileg tæki með :wink:
Þá held ég að hann verði að bíða ansi lengi. ;)
Eigandi þess bíls er eftir minni bestu vitund ekkert á leiðinni að selja. ;)
Jóhann
Jss
Postby Schnitzerinn » Mon 18. Apr 2005 00:38
Hann er Bjeeelaðurrr 8) :twisted:
Dóri
Image BMW 525i e34 '91 [SELDUR]
Image Opel Vectra CD 2.0 '97[Í notkun]
Schnitzerinn
