UBER S62
Re: UBER S62
Postby Alpina » Wed 08. Dec 2010 19:26
Sem ég segi ...
M30,,, S38 eru team bigpower í F/I
S62 er ágæt oem
Re: UBER S62
Postby bimmer » Sat 05. Feb 2011 16:59
Startup:
Re: UBER S62
Postby Alpina » Sat 05. Feb 2011 17:03
Var þetta taka II eða III
Re: UBER S62
Postby bimmer » Sat 05. Feb 2011 17:10
Alpina wrote:Var þetta taka II eða III
II.
Re: UBER S62
Postby fart » Sat 05. Feb 2011 17:13
:lol: á gæjan sem startar bílnum
Re: UBER S62
Postby slapi » Sat 05. Feb 2011 17:15
Bara VANOS delete Bank 2 ??? :shock:
Re: UBER S62
Postby ömmudriver » Sun 06. Feb 2011 08:51
fart wrote::lol: á gæjan sem startar bílnum
x2 :lol:
Re: UBER S62
Postby bimmer » Wed 02. Mar 2011 20:20
Úff......:
"Well, here's a post that relates directly to the topic of the thread (we've wandered a bit recently): At Mike O'Neil's recommendation and in coordination with Mike's own evaluation and analysis, my Bavarian Disaster engine is on its way to VAC in Philly, where its remaining components will be dismantled and evaluated over the course of the next ten days. VAC will make its recommendations about what should be done to fix the engine. The initial tear down showed nothing wrong with the heads, cams, valves, valvesprings, pistons, rings, rods, crankshaft or bearings, yet there is a ton of ferrous material throughout the engine. Given that the bearings are fine and the only other ferrous in the engine are the sleeves, that is the likely source of the problem, i.e., some form of cylinder deformation or piston to bore tolerances out of whack. Interestingly, the engine will NOT spin freely even when it should; there is some form of resistance manifesting itself in different places in the cycle on each turn, sometimes requiring a reverse crank to release it. Clearly, something is not right. In any event, VAC will diagnose and remedy and, with any luck, present me with a PROPERLY engineered S62 in the next month. More than sufficient time to break it in and invite Mr. X back to the States for tuning--hopefully, one last time.
In the meantime, I'm going to revamp my fuel delivery system and have some body and paint work done to the Beast.
--Peter"
EDIT: Þetta er semsagt taka III, ekki eftir atriðið með lol startup gaurnum.
Re: UBER S62
Postby IvanAnders » Thu 03. Mar 2011 00:49
:shock: :shock: :shock: :shock: :? :? :? :?
Leiðindamál í alla staði fyrir alla aðila!
Sjitt! :bawl:
IvanAnders
Re: UBER S62
Postby Alpina » Thu 03. Mar 2011 23:42
IvanAnders wrote::shock: :shock: :shock: :shock: :? :? :? :?
Sjitt! :bawl:
============== S62 :|
Re: UBER S62
Postby IvanAnders » Fri 04. Mar 2011 00:08
Sjitt! :bawl:
Rétt, sendu honum info um M30!
IvanAnders
Re: UBER S62
Postby bimmer » Sun 29. May 2011 00:01
Re: UBER S62
Postby Alpina » Sun 29. May 2011 00:08
:shock:
Re: UBER S62
Postby kalli* » Sun 29. May 2011 01:13
Er þetta ekki eins CF cover og þú varst með á þínum Þórður ?
tradin1 wrote:i really need to buy a flashlight, fml
being poor college student ftl
:lol: :lol:
kalli*
Re: UBER S62
Postby bimmer » Sun 29. May 2011 10:18
kalli* wrote:Er þetta ekki eins CF cover og þú varst með á þínum Þórður ?
Nei þetta er mega rare 1@2 held ég - eitthvað fyrir Sveinka.
Voru gerð upphaflega fyrir DA bílana og er með plexigluggum til að sjá trumpetana.
