Scangauge OBD-II tölva
Postby hjortur » Wed 09. Feb 2005 09:08
Alvöru diagnostic tölva sem stingst í OBD-II pluginn undir mælaborðinu.
Eru ekki flestir bimmar eftir 96 OBD-II ?
scangauge.com og
thinkgeek.com
Meðal fídusa
thinkgeek.com wrote:Scan Tool
* Reads Trouble Codes
* Reads conditions that set the Trouble Code
* Clears Trouble Codes
* Turns off "Check Engine" light
* Make and store up to 10 rewritable special codes to send to the vehicle computer
Digital Gauges - Shows 4 gauges at a time from the possible following:
* Fuel Economy (MPG - gasoline engines only)
* Fuel Rate (GPH - gasoline engines only)
* Battery Voltage
* Coolant Temperature
* Intake Air Temperature
* Engine Speed (RPM)
* Vehicle speed (MPH)
* Manifold Pressure (not available on some vehicles)
* Engine Load
* Throttle Position
* Ignition Timing
* Open/Closed Loop
Trip Computer
* Maximum Speed
* Average Speed
* Maximum Coolant Temperature
* Maximum RPM
* Driving Time
* Driving Distance
* Fuel Used (Gasoline engines only)
* Trip Fuel Economy(Gasoline engines only)
BMW 323i '97 montreal blau
http://sveitavargurinn.is
hjortur
