E30 DIY upplýsingar
E30 DIY upplýsingar
Postby gstuning » Mon 24. Jan 2005 09:54
Mods
Engine etc:
325e to 325i Engine Swap - strictlyeta.net
325i Exhaust Upgrade - strictlyeta.net
AFM and Injector upgrade - davelength.net
Changing the M20B25/B27 Oil Pan - strictlyeta.net
M20 E to I 2.8 Liter Engine Conversion - strictlyeta.net
Painting The Intake Manifold - pelicanparts.com
Performance Chip Installation - pelicanparts.com
Racing Dynamics E34 M20 Header Installation - strictlyeta.net
Tranny etc:
5-Speed Swap - seambmw.com
E34 M5 Guibo Upgrade - e30m3perforumance.com
Limited Slip Differential Swap - pelicanparts.com
Z3 Short Shift Conversion - e30zone.co.uk
Z3 Short Shift Conversion - seambmw.com
Ground Control:
E30 M3 Complete Suspension Swap - davelength.net
E36 rack conversion - e30zone.co.uk
Indepth E36 M3 Steering Rack Conversion - e30m3performance.com
M Roadster 5 Lug Swap - davelength.net
Z3 Rear Shock Tower Reinforcement - e30m3performance.com
Brakes:
25mm Brake Master Cylinder Upgrade - e30m3performance.com
Cross-Drilled Front Brake Rotor Upgrade - pelicanparts.com
Lighting:
All Red Tail-lights - e30.bmwdiy.info
E39 CELIS Light Source - e30.bmwdiy.info
Blinking Sidemarker Modification - pelicanparts.com
Clear Sidemarkers For Your E30 - strictlyeta.net
H1/H4 Headlight Upgrade - strictlyeta.net
Independent Fog Lights - e30.bmwdiy.info
LED Key Conversion - e30.bmwdiy.info
Smoked Sidemarkers - e30.bmwdiy.info
Tinted Tail Lights - e30zone.co.uk
[url=http://e30.bmwdiy.info/xenon/index.html]Xenon Bulb & Ballast Installation
(Ellipsoid Headlight)[/url] - e30.bmwdiy.info
Exterior:
[URL=http://www.strictlyeta.net/technical/spoilerinstall.html]Factory Front Spoiler Installation Instructions
1986-1987 325es/325is [/URL] - strictlyeta.net
Installing the "is" Lip Spoiler - e30.bmwdiy.info
Shadowline Trim Procedure - strictlyeta.net
Tucking the E30 84-88 Aluminum Bumpers - strictlyeta.net
Upgrading to later style bumpers - bmwe30.net
Interior:
318i/325i Tachometer Upgrade - strictlyeta.net
Cup Holder - e30.bmwdiy.info
Illuminated Rear Heater Switch - e30zone.co.uk
Lighted Rearview Mirror Installation - strictlyeta.net
Lighted Rearview Mirror Retro-Fit - e30.bmwdiy.info
Electronics:
Head Unit Installation - pelicanparts.com
OBC Retrofit - strictlyeta.net
On Board Computer Retrofit - e30zone.co.uk
Maintenance
Engine etc:
[url=http://e30.bmwdiy.info/aux-fan-resistor/index.html]Aux Fan
Resistor Replacement (Bosch)[/url] - e30.bmwdiy.info
Coolant Temp Sensor Replacement - pelicanparts.com
Flushing the cooling system - bmwe30.net
Fuel Filter Replacement - pelicanparts.com
Cleaning Fuel Injectors - pelicanparts.com
Ignition System Tune-Up - pelicanparts.com
Motor Mount Replacement - pelicanparts.com
[url=http://e30.bmwdiy.info/oil-leak/index.html]Oil Control Valve Gasket Leak
M20/B25 Engine[/url] - e30.bmwdiy.info
Oxygen Sensor Replacement - pelicanparts.com
Valve Adjustment - e30zone.co.uk
Valve Adjustment - pelicanparts.com
Ground Control:
Changing Rear Shock Mounts - pelicanparts.com
Front Springs and Shock Replacement - pelicanparts.com
Front Suspension Bushing Overhaul - pelicanparts.com
Front Wheel Bearing Replacement - pelicanparts.com
[url=http://www.pelicanparts.com/bmw/techarticles/E30-Rear_Suspen/E30-Rear_Suspen.htm]Rear
Shock & Spring Replacement[/url] - pelicanparts.com
Rear Sway Bar Bushing Replacement - pelicanparts.com
Rear Wheel Bearing - pelicanparts.com
Sway Bar Bushing / Drop Link Replacement - pelicanparts.com
Brakes:
Bleeding the brakes system - bmwe30.net
Building a brake bleeder - bmwe30.net
Front Disc Brake Replacement - pelicanparts.com
Getting rid of the brake dust - bmwe30.net
How to adjust your brakes pedal - bmwe30.net
Noises while braking - bmwe30.net
Parking Brake Adjustment - pelicanparts.com
Rear Disc Brake Replacement - pelicanparts.com
Stopping the brake squeal - bmwe30.net
Lighting:
Instrument Light Replacement - pelicanparts.com
OBC light replacement - pelicanparts.com
Exterior:
[url=http://e30.bmwdiy.info/bumper-adjust/index.html]Bumper Removal and Adjustment
(One-piece bumper - Non-Cabriolet)[/url] - e30.bmwdiy.info
Central Locking Faults - e30zone.co.uk
Cleaner windshield washer fluid - bmwe30.net
Dash Removal - strictlyeta.net
Door lock cylinder fix - bmwe30.net
Door lock replacement - bmwe30.net
Driver's Lock Cylinder repair - bmwe30.net
Fixing an inoperative door lock - bmwe30.net
Fixing Power Door Locks - bmwe30.net
Front & Rear valance refinishing - bmwe30.net
Mirror Repair - e30.bmwdiy.info
Pain Free Hood shock - bmwe30.net
Rear Seat Removal - e30.bmwdiy.info
Replacing your BMW Roundel Emblem - pelicanparts.com
Sunroof Adjustment - e30.bmwdiy.info
Interior:
[url=http://e30.bmwdiy.info/passenger-water-leak/index.html]Passenger-Side
Water Leak[/url] - e30.bmwdiy.info
Water in rear floor of convertibles - bmwe30.net
Electronics:
Instrument Cluster SI Board Replacement - e30m3performance.com
Brake Pedal Switch Replacement - pelicanparts.com
Replacing Service Indicator Board Batteries - pelicanparts.com
Resetting BMW Airbag Warning Lamps (SRS Reset) - pelicanparts.com
Wiper Problems Fixed - e30zone.co.uk
Ventalation & A/C:
Air Conditioning Recharging and Repair - pelicanparts.com
Blower Motor Resistor Replacement - e30.bmwdiy.info
Blower motor runs with ignition off - bmwe30.net
Poor Air conditioner operation - bmwe30.net
Extra:
Detailing 101
Care of Your BMW E30 Paintwork Part 2 - e30zone.co.uk
Cleaning the Soft Top - e30zone.co.uk
Cleaning the Rear Window of Your Soft Top - e30zone.co.uk
Cleaning Your Hardtop - e30zone.co.uk
Glass cleaning with paint polish - bmwe30.net
The Meguiars System - e30zone.co.uk
Proper Detailing - bmwe30.net
Þessu var stolið af www.e30tech.com
Vonandi getur einhver hérna notað þetta sér til aðstoðar
Original linkur :
Hérna er upprunalegi þráðurinn á e30tech
Postby gunnar » Mon 24. Jan 2005 10:10
Held að margir muni koma til með að nota sér þetta 8)
Postby Twincam » Mon 24. Jan 2005 10:28
Svo er náttla M50 í E30 swap guide til á Ebay thessa stundina...
Hérna
Rúnar P
662 5272
Druslusafnið núna:
BMW e46
Suzuki Baleno
Honda CRF250R
Twincam
Postby gstuning » Mon 24. Jan 2005 10:44
Twincam wrote:Svo er náttla M50 í E30 swap guide til á Ebay thessa stundina...
Hérna
allt frítt á internetinu ,, engin ástæða til að vera kaupa svona
Postby Twincam » Mon 24. Jan 2005 10:45
já... en sumir.. eins og ég.. eru latir og nenna ekkert ad vera ad leita um allt.
Svo er ég líka gjørsamlega sneiddur øllum hæfileikum til ad leita ad einhverju á netinu :oops:
Rúnar P
662 5272
Druslusafnið núna:
BMW e46
Suzuki Baleno
Honda CRF250R
Twincam
Postby capische » Mon 24. Jan 2005 10:53
stórsniðugt :clap:
bmw 328i '98/ónýtur
BMW 750IA '90 rolling on 18"rondell 58 ap 40/40 og diskalæstur/seldur
BMW 318i '87/seldur
polaris edge x 600 '01/seldur
capische
Postby joiS » Mon 24. Jan 2005 10:55
sweet info ,,, þetta á eftir að nýtast mér vel
e46 320td 02
e21 335I
joiS
Postby Joolli » Tue 25. Jan 2005 01:08
GERA STICKY!! Þetta er snilldar safn!
M. Benz E320 Sportline '94 Svart Metallic
M. Benz E420 '94 Vínrauður
BMW 530iA '94 Diamondschwarts Metallic - Seldur
BMW 525iA E34 '94 Orientblau Metallic - Seldur
M. Benz 220E W124 '93 Ljósgrár - Seldur
BMW 316i E30 '90 Gletscherblau Metallic - Seldur
Joolli
