german to english maelabordsvidvaranir
Postby arntor » Fri 30. Dec 2011 13:13
fann thetta, fint fyrir ta sem geta ekki skipt yfir i ensku.
http://home.online.no/~st-arhol/enge32obc.htm
Messages are in 3 different priorities.
Priority 1
The faults are shown immediately with a gong-gong signal and flashing indicators in the display.
Bremsdruck, Brake Assist Inact
Bremsflussigheit, Low Brake Fluid
Oeldruck Motor, Engine Oil Press Low
Kuhlwassertemp., Coolant Temperature
Handbremse losen, Handbrake on
Kein Bremslicht, Brake Lights Failure
Bremsli. Elektrik, Brake Light Circuit
Niveauregelung, Automatic Level
Priority 2
These faults are shown in the display when ignition key is in position 2
If the + sign appears, more signals can be displayed by pressing the CHECK button.
Getriebeprogramm, Trans Fail-Safe Prog
Bremsbelage, Brake Linings
Waschwasserstand, Washer Fluid Low
Tur offen, Door Open
Kofferraum offen, Trunk Open
1 Bremslicht, 1 Brake Light fail
Abblendlicht, Low Beam Failure
Standlicht, Side Light Failure
Rucklicht, Tail Light Failure
Nebellicht vorn, F/Fog Light failure
Nebellicht hint., R/ Fog Light failure
Kennzeichenlicht, Num Plate Light Fail
Anhanger-Licht, Trailer light failure
Priority 3
Oelstand Motor, Check Engine Oil Lev
Oelst. Lenkhilfe, Check P.A.S. Fluid
Kuhlwasserstand, Coolant Level Low
Check-Control Check-Control
Sensor Oelstand , Oil Level Sensor
Licht an? , Lights on
Bitte angurten, Fasten Seatbelts
Arnþór S. Bílamálari síðan 2003
773-7874
BMW 540i 1999 RO-960
Pontiac Firebird 1999
arntor
Re: german to english maelabordsvidvaranir
Postby srr » Fri 30. Dec 2011 13:19
Standlicht, Side Light Failure,,,,,,,Side Light?
Ég er nokkuð viss um að þetta séu stöðuljósin.
Postby arntor » Fri 30. Dec 2011 13:25
"Standlicht" English translation
Display search filter
Results: 1-2 of 2
Standlicht {n} [autom.] (also: Seitenlichter)
sidelights
Standlicht {n} [autom.] (also: Parkleuchte, Parklicht)
parking light
getur thytt baedi samkvaemt ordabok..en eg skrifadi thetta ekki svo tetta getur vel verid rett hja ter
773-7874
arntor
Postby birkire » Fri 30. Dec 2011 19:15
eða bara breyta tungumálinu í tölvunni yfir í ensku
svissar á accessories og heldur inni hægri pinnanum á mælaborðinu í 10-15 sek og þú finnur út ur þessu
birkire
Postby agustingig » Mon 02. Jan 2012 08:19
birkire wrote:eða bara breyta tungumálinu í tölvunni yfir í ensku
Er þetta líka hægt á e34? :O
Postby Danni » Mon 02. Jan 2012 12:29
Jamm. Ég breytti bæði OBC og mælaborðinu í ensku í fyrra sumar.
Postby arntor » Mon 02. Jan 2012 15:40
vandamalid er ad í sumum sjöum og fimmum er tad orðið bilað. t.d hjá mér virðist það vera bilað.
773-7874
arntor
Postby Alpina » Mon 02. Jan 2012 16:12
hvernig bíll ??
Postby srr » Mon 02. Jan 2012 18:56
arntor wrote:vandamalid er ad í sumum sjöum og fimmum er tad orðið bilað. t.d hjá mér virðist það vera bilað.
Jebb, algengt vandamál að takkinn á speedoinu hætti að virka :?
Postby ömmudriver » Tue 03. Jan 2012 12:13
Þetta er einmitt bilað í sjöunni minni :thdown:
Postby srr » Tue 03. Jan 2012 19:00
En 750i,,,,,,did we test that?
