M Tech II framstuðari - festingar
Postby jens » Wed 14. Dec 2011 12:54
Vantar smá ráð - reynslu hjá þeim sem eru með M Tech II stuðara+svuntu.
Hvað þarf ég af smellum og dóti til að smella saman stuðara og svuntu.
No. Description Supplement Qty From Up To Part Number Price Notes Photo
02 INSTALLING SET SPOILER FRONT M TECHNIC 1 05/1990 51112239709 $710.31 Cat=Yes, See ABE 9786216, EBA 9788634
03 Clamp M TECHNIC 7 05/1990 51712239711 $0.60 Cat=Yes
04 EXPANDING RIVET 8 05/1990 17111712963 $0.27 Cat=Yes
05 CLAMPING BOLT 2 05/1990 51711933719 $1.94 Cat=Yes
06 Clamp 2 05/1990 51711922599 $0.42 Cat=Yes
07 Plastic nut M6 2 05/1990 16131176747 $0.53 Cat=Yes
08 AIR CHANNEL LEFT M TECHNIC 1 05/1990 51712238867 $37.07 Cat=Yes
08 AIR CHANNEL RIGHT M TECHNIC 1 05/1990 51712238868 $36.81 Cat=Yes
09 Gasket M TECHNIC 1 05/1990 51712239713 $13.73 Cat=Yes
10 Foil M TECHNIC 1 05/1990 51712239714 $4.51 Cat=Yes
12 Retrofit kit, trim panel M TECHNIC 1 05/1990 51112239700 $597.37 Cat=Yes
13 Clamp M TECHNIC 8 05/1990 51112239701 $0.38 Cat=Yes
14 EXPANDING RIVET ? 05/1990 51111908077 $0.30 Cat=Yes
15 Expanding nut M TECHNIC 2 05/1990 51112239842 Cat=Yes, ENDED
16 Body nut B4,2 4 05/1990 51112239707 $0.79 Cat=Yes
17 Fillister head self-tapping screw ST4,2X19-Z2 4 05/1990 07119907809 Cat=Yes, ENDED
17 Fillister head self-tapping screw ST4,2X19-Z2 4 05/1990 07119901181 Cat=Yes, ENDED
17 Fillister head self-tapping screw ST4,2X19 ZN-SW 4 05/1990 07119901179 Cat=Yes, ENDED
17 Sheet metal screw ST4,2X19-U2-C-H 4 05/1990 07119904176 $0.25 Cat=Yes
18 WEDGE M TECHNIC ? 05/1990 51112239702 $0.30 Cat=Yes
19 GUIDE LEFT M TECHNIC 1 05/1990 51112239703 $9.57 Cat=Yes
19 GUIDE RIGHT M TECHNIC 1 05/1990 51112239704 $9.57 Cat=Yes
20 BRACKET FRONT LEFT 1 05/1990 51111953097 $5.53 Cat=Yes
20 BRACKET FRONT RIGHT 1 05/1990 51111953098 $5.53 Cat=Yes
21 Cover M TECHNIC 2 05/1990 51112239708 $9.98 Cat=Yes
22 Holding strap 2 05/1990 51111938263 Cat=Yes, ENDED
22 Holding strap 2 05/1990 51111973721 $0.77 Cat=Yes
23 SPACER BUSH 4 05/1990 51112238833 $0.43 Cat=Yes
24 Support M TECHNIC 2 05/1990 51712238866 $3.08 Cat=Yes
Re: M Tech II framstuðari - festingar
Postby Aron Andrew » Fri 16. Dec 2011 09:50
Ég var með 3 eða 4 stk nr 3 og svo bara ziptie á endunum. Var með endana í orginal festingum en ef eitthvað klikkaði þá fór svuntran í mauk
