færa lsd yfir í annað drif
Postby gunnar695 » Thu 12. Nov 2009 12:12
eg var að spá það er búið að vera að tala um að það se hægt að færa læsingar ámilli drifa úr oðrum bimmum
eg er að spá er hægt að taka lsd úr 730i e32 og sitja í stóra drifið í bmw e36
þetta er læsingin sem eg er með í huga .
Part 33141209688 (LIMITED SLIP DIFF.UNIT) was found on the following vehicles:
E23 735i Sedan, M30, USA, AUTO (6884) : DIFFERENTIAL-LIMITED SLIP DIFF.UNIT
E23 735i Sedan, M30, USA, AUTO (6724) : DIFFERENTIAL-LIMITED SLIP DIFF.UNIT
E23 735i Sedan, M30, USA, MANUAL (6874) : DIFFERENTIAL-LIMITED SLIP DIFF.UNIT
E23 728i Sedan, M30, Europe, AUTO (6581) : DIFFERENTIAL-LIMITED SLIP DIFF.UNIT
E23 728i Sedan, M30, Europe, AUTO (6541) : DIFFERENTIAL-LIMITED SLIP DIFF.UNIT
E23 728i Sedan, M30, Europe, RHD, AUTO (6582) : DIFFERENTIAL-LIMITED SLIP DIFF.UNIT
E23 728i Sedan, M30, Europe, RHD, AUTO (6542) : DIFFERENTIAL-LIMITED SLIP DIFF.UNIT
E23 728i Sedan, M30, Europe, MANUAL (6531) : DIFFERENTIAL-LIMITED SLIP DIFF.UNIT
E23 728i Sedan, M30, Europe, MANUAL (6571) : DIFFERENTIAL-LIMITED SLIP DIFF.UNIT
E23 728i Sedan, M30, Europe, RHD, MANUAL (6572) : DIFFERENTIAL-LIMITED SLIP DIFF.UNIT
E23 728i Sedan, M30, Europe, RHD, MANUAL (6532) : DIFFERENTIAL-LIMITED SLIP DIFF.UNIT
E23 728iS Sedan, M30, Europe, AUTO (6481) : DIFFERENTIAL-LIMITED SLIP DIFF.UNIT
E23 728iS Sedan, M30, Europe, AUTO (6441) : DIFFERENTIAL-LIMITED SLIP DIFF.UNIT
E23 728iS Sedan, M30, Europe, MANUAL (6431) : DIFFERENTIAL-LIMITED SLIP DIFF.UNIT
E23 728iS Sedan, M30, Europe, MANUAL (6471) : DIFFERENTIAL-LIMITED SLIP DIFF.UNIT
E23 732i Sedan, M30, Europe, AUTO (6681) : DIFFERENTIAL-LIMITED SLIP DIFF.UNIT
E23 732i Sedan, M30, Europe, AUTO (6641) : DIFFERENTIAL-LIMITED SLIP DIFF.UNIT
E23 732i Sedan, M30, Europe, RHD, AUTO (6682) : DIFFERENTIAL-LIMITED SLIP DIFF.UNIT
E23 732i Sedan, M30, Europe, RHD, AUTO (6642) : DIFFERENTIAL-LIMITED SLIP DIFF.UNIT
E23 732i Sedan, M30, Europe, MANUAL (6631) : DIFFERENTIAL-LIMITED SLIP DIFF.UNIT
E23 732i Sedan, M30, Europe, MANUAL (6671) : DIFFERENTIAL-LIMITED SLIP DIFF.UNIT
E23 732i Sedan, M30, Europe, RHD, MANUAL (6672) : DIFFERENTIAL-LIMITED SLIP DIFF.UNIT
E23 732i Sedan, M30, Europe, RHD, MANUAL (6632) : DIFFERENTIAL-LIMITED SLIP DIFF.UNIT
E23 733i Sedan, M30, Europe, AUTO (6745) : DIFFERENTIAL-LIMITED SLIP DIFF.UNIT
E23 733i Sedan, M30, Europe, AUTO (6741) : DIFFERENTIAL-LIMITED SLIP DIFF.UNIT
E23 733i Sedan, M30, Europe, RHD, AUTO (6746) : DIFFERENTIAL-LIMITED SLIP DIFF.UNIT
E23 733i Sedan, M30, Europe, RHD, AUTO (6742) : DIFFERENTIAL-LIMITED SLIP DIFF.UNIT
E23 733i Sedan, M30, Europe, MANUAL (6731) : DIFFERENTIAL-LIMITED SLIP DIFF.UNIT
E23 733i Sedan, M30, Europe, RHD, MANUAL (6732) : DIFFERENTIAL-LIMITED SLIP DIFF.UNIT
E23 728i Sedan, M30, Europe, AUTO (6581) : LIMITED SLIP DIFF.UNIT-SINGLE PARTS
E23 728i Sedan, M30, Europe, AUTO (6541) : LIMITED SLIP DIFF.UNIT-SINGLE PARTS
E23 728i Sedan, M30, Europe, RHD, AUTO (6582) : LIMITED SLIP DIFF.UNIT-SINGLE PARTS
E23 728i Sedan, M30, Europe, RHD, AUTO (6542) : LIMITED SLIP DIFF.UNIT-SINGLE PARTS
E23 728i Sedan, M30, Europe, MANUAL (6531) : LIMITED SLIP DIFF.UNIT-SINGLE PARTS
E23 728i Sedan, M30, Europe, MANUAL (6571) : LIMITED SLIP DIFF.UNIT-SINGLE PARTS
E23 728i Sedan, M30, Europe, RHD, MANUAL (6572) : LIMITED SLIP DIFF.UNIT-SINGLE PARTS
E23 728i Sedan, M30, Europe, RHD, MANUAL (6532) : LIMITED SLIP DIFF.UNIT-SINGLE PARTS
E23 728iS Sedan, M30, Europe, AUTO (6481) : LIMITED SLIP DIFF.UNIT-SINGLE PARTS
E23 728iS Sedan, M30, Europe, AUTO (6441) : LIMITED SLIP DIFF.UNIT-SINGLE PARTS
E23 728iS Sedan, M30, Europe, MANUAL (6471) : LIMITED SLIP DIFF.UNIT-SINGLE PARTS
E23 728iS Sedan, M30, Europe, MANUAL (6431) : LIMITED SLIP DIFF.UNIT-SINGLE PARTS
E23 732i Sedan, M30, Europe, AUTO (6681) : LIMITED SLIP DIFF.UNIT-SINGLE PARTS
E23 732i Sedan, M30, Europe, AUTO (6641) : LIMITED SLIP DIFF.UNIT-SINGLE PARTS
E23 732i Sedan, M30, Europe, RHD, AUTO (6682) : LIMITED SLIP DIFF.UNIT-SINGLE PARTS
E23 732i Sedan, M30, Europe, RHD, AUTO (6642) : LIMITED SLIP DIFF.UNIT-SINGLE PARTS
E23 732i Sedan, M30, Europe, MANUAL (6631) : LIMITED SLIP DIFF.UNIT-SINGLE PARTS
E23 732i Sedan, M30, Europe, MANUAL (6671) : LIMITED SLIP DIFF.UNIT-SINGLE PARTS
E23 732i Sedan, M30, Europe, RHD, MANUAL (6672) : LIMITED SLIP DIFF.UNIT-SINGLE PARTS
E23 732i Sedan, M30, Europe, RHD, MANUAL (6632) : LIMITED SLIP DIFF.UNIT-SINGLE PARTS
E32 735i Sedan, M30, USA, AUTO (GB43) : DIFFERENTIAL-LIMITED SLIP DIFF.UNIT
E32 735i Sedan, M30, USA, MANUAL (GB33) : DIFFERENTIAL-LIMITED SLIP DIFF.UNIT
E32 735iL Sedan, M30, USA, AUTO (GC43) : DIFFERENTIAL-LIMITED SLIP DIFF.UNIT
E32 730i Sedan, M30, Europe, AUTO (GA81) : DIFFERENTIAL-LIMITED SLIP DIFF.UNIT
E32 730i Sedan, M30, Europe, AUTO (GA41) : DIFFERENTIAL-LIMITED SLIP DIFF.UNIT
E32 730i Sedan, M60, Europe, AUTO (GD21) : DIFFERENTIAL-LIMITED SLIP DIFF.UNIT
E32 730i Sedan, M30, Europe, RHD, AUTO (GA82) : DIFFERENTIAL-LIMITED SLIP DIFF.UNIT
E32 730i Sedan, M30, Europe, RHD, AUTO (GA42) : DIFFERENTIAL-LIMITED SLIP DIFF.UNIT
E32 730i Sedan, M60, Europe, RHD, AUTO (GD22) : DIFFERENTIAL-LIMITED SLIP DIFF.UNIT
E32 730i Sedan, M30, Europe, MANUAL (GA71) : DIFFERENTIAL-LIMITED SLIP DIFF.UNIT
E32 730i Sedan, M30, Europe, MANUAL (GA31) : DIFFERENTIAL-LIMITED SLIP DIFF.UNIT
E32 730i Sedan, M60, Europe, MANUAL (GD11) : DIFFERENTIAL-LIMITED SLIP DIFF.UNIT
E32 730i Sedan, M30, Europe, RHD, MANUAL (GA72) : DIFFERENTIAL-LIMITED SLIP DIFF.UNIT
E32 730i Sedan, M30, Europe, RHD, MANUAL (GA32) : DIFFERENTIAL-LIMITED SLIP DIFF.UNIT
E32 730iL Sedan, M30, Europe, AUTO (GC21) : DIFFERENTIAL-LIMITED SLIP DIFF.UNIT
E32 730iL Sedan, M60, Europe, AUTO (GD61) : DIFFERENTIAL-LIMITED SLIP DIFF.UNIT
E32 730iL Sedan, M30, Europe, RHD, AUTO (GC22) : DIFFERENTIAL-LIMITED SLIP DIFF.UNIT
E32 730iL Sedan, M60, Europe, RHD, AUTO (GD62) : DIFFERENTIAL-LIMITED SLIP DIFF.UNIT
E32 730iL Sedan, M60, Europe, MANUAL (GD51) : DIFFERENTIAL-LIMITED SLIP DIFF.UNIT
E32 730iL Sedan, M30, Europe, MANUAL (GC11) : DIFFERENTIAL-LIMITED SLIP DIFF.UNIT
E32 730iL Sedan, M30, Europe, RHD, MANUAL (GC12) : DIFFERENTIAL-LIMITED SLIP DIFF.UNIT
E32 735i Sedan, M30, Europe, AUTO (GB61) : DIFFERENTIAL-LIMITED SLIP DIFF.UNIT
E32 735i Sedan, M30, Europe, AUTO (GB41) : DIFFERENTIAL-LIMITED SLIP DIFF.UNIT
E32 735i Sedan, M30, Europe, RHD, AUTO (GB62) : DIFFERENTIAL-LIMITED SLIP DIFF.UNIT
E32 735i Sedan, M30, Europe, RHD, AUTO (GB42) : DIFFERENTIAL-LIMITED SLIP DIFF.UNIT
E32 735i Sedan, M30, Europe, MANUAL (GB51) : DIFFERENTIAL-LIMITED SLIP DIFF.UNIT
E32 735i Sedan, M30, Europe, MANUAL (GB31) : DIFFERENTIAL-LIMITED SLIP DIFF.UNIT
E32 735i Sedan, M30, Europe, RHD, MANUAL (GB52) : DIFFERENTIAL-LIMITED SLIP DIFF.UNIT
E32 735i Sedan, M30, Europe, RHD, MANUAL (GB32) : DIFFERENTIAL-LIMITED SLIP DIFF.UNIT
E32 735iL Sedan, M30, Europe, AUTO (GC61) : DIFFERENTIAL-LIMITED SLIP DIFF.UNIT
E32 735iL Sedan, M30, Europe, AUTO (GC41) : DIFFERENTIAL-LIMITED SLIP DIFF.UNIT
E32 735iL Sedan, M30, Europe, RHD, AUTO (GC62) : DIFFERENTIAL-LIMITED SLIP DIFF.UNIT
E32 735iL Sedan, M30, Europe, RHD, AUTO (GC42) : DIFFERENTIAL-LIMITED SLIP DIFF.UNIT
E32 735iL Sedan, M30, Europe, MANUAL (GC51) : DIFFERENTIAL-LIMITED SLIP DIFF.UNIT
E32 735iL Sedan, M30, Europe, MANUAL (GC31) : DIFFERENTIAL-LIMITED SLIP DIFF.UNIT
E32 735iL Sedan, M30, Europe, RHD, MANUAL (GC52) : DIFFERENTIAL-LIMITED SLIP DIFF.UNIT
E32 735iL Sedan, M30, Europe, RHD, MANUAL (GC32) : DIFFERENTIAL-LIMITED SLIP DIFF.UNIT
E34 530i Touring, M60, Europe, AUTO (HK21) : DIFFERENTIAL-LIMITED SLIP DIFF.UNIT
E34 530i Touring, M60, Europe, RHD, AUTO (HK22) : DIFFERENTIAL-LIMITED SLIP DIFF.UNIT
E34 530i Touring, M60, Europe, MANUAL (HK11) : DIFFERENTIAL-LIMITED SLIP DIFF.UNIT
gunnar695
Re: færa lsd yfir í annað drif
Postby 300+ » Thu 12. Nov 2009 12:38
Ef að þetta er læsing sem að kom original með 730 bílnum þá ættti það að ganga, bæði 188mm drif.
300+
Postby Axel Jóhann » Fri 13. Nov 2009 00:09
Mig grunar nú að þetta sé stærra drifið, sem passar þar af leiðandi EKKI í e36 drif.
