LSD í Z4
LSD í Z4
Postby Thrullerinn » Fri 13. Feb 2009 22:11
Er að spá í að setja LSD í zetuna, er aðeins búinn að skoða á netinu en
verðin í súrari kanntinum...
Er einhver sniðugur sem gæti svarað mér hvort drif passaði úr E46
eða einhverjum öðrum?
Postby IceDev » Fri 13. Feb 2009 22:49
AWWW YEAH!
Líst mér ON!
Hvað með þetta ?
http://www.turnermotorsport.com/html/de ... 3107531625
http://www.bmw-syndikat.de/bmwsyndikatf ... MW+%2D+E46
Eitthvað sem ég skil ekki en gæti verið sneddí
IceDev
Postby Thrullerinn » Fri 13. Feb 2009 22:57
IceDev wrote:AWWW YEAH!
Líst mér ON!
Only non-M E46 and Z4 diffs will fit. No others.
http://forum.e46fanatics.com/archive/in ... 82976.html
Jæja er til einhver ekki-M E46 með LSD á landinu?
Kippa af bjór handa manninum sem finnur svona á lausu!!
Postby Thrullerinn » Fri 13. Feb 2009 23:02
Líst mér ON!
Hvað með þetta ?
HEYRÐU!!! efri linkurinn er alls ekkert út úr myndinni!
3.46 Differential for E46 3 Series and Z4
Part #: 33107531625 (33 10 7 531 625)
Applications: 1999 - 2006 (E46 Z4)
3.46 Differential for E46 3 Series and Z4. This is a factory BMW differential with a 3.46 ratio. A perfect addition to this unit would be the TMS Limited Slip Unit, see link below. $100 core charge applies.
Price: $1,199.95
Postby IceDev » Fri 13. Feb 2009 23:06
Google power! :D
IceDev
Postby Thrullerinn » Fri 13. Feb 2009 23:27
http://www.simpsonmotorsport.co.uk/bmw- ... roduct=114
Replacement á allt involsið...
BMW stopped putting limited slip differentials in all cars in 1995 (except for “M” cars.) So, if it’s not an M3 or M5 your car does not have power going to BOTH wheels at the same time. In other words, it is “one wheel drive.” This is not good for any type of performance car and if you have taken your car to the track or have auto crossed it you can see why. TMS has a cost effective solution to “one wheel drive. Manufactured exclusively for TMS, our limited slip unit for the E46 323i, 325i, 328i, 330i, and Z4 (Not M3) is a complete assembly that replaces the “open” differential chunk in your cars current differential. It is machined from billet heat treated 4340 chromoly steel for strength and offers added benefit to racers because it is completely adjustable by varying the amount of pre-load and the ramp angles. The ramps are asymmetrical which allows specific tuning for the racing customer. The unit is completely re-buildable, and all parts are replaceable. The TMS limited slip uses the factory bearings, fits into the factory differential housing with no modifications, and all critical dimensions are identical to the factory unit. This makes installation quick and easy, requiring minimal ring and pinion setup time and shimming. Professional installation is recommended, however. **NOTE, IF YOU ARE GOING TO FIT THIS IN A 3.15 to 4.33 DIFF YOU NEED A SPACER AND BOLT KIT +£50**
Mikill verðmunur 1400 pund vs. 1200 USD
Postby finnbogi » Sat 14. Feb 2009 05:09
ég mæli með að senda mail á strákana í Diffsonline.com
dan@diffsonline.com
gæri verið að þeir eigu læsingu handa þér á góður verði eða jafnvel notað drif
svo geturu hringt í hemma í B&L og hann getur sett hana (læsinguna) í drifið þitt :wink:
Þórður Finnbogi
GSM:663-2524
BMW M5 E39 1999 veðlaus :D
BMW 316i E36 1999 kraftlaus
finnbogi
Postby iar » Sat 14. Feb 2009 09:54
Thrullerinn wrote:Mikill verðmunur 1400 pund vs. 1200 USD
Epli og appelsínur... Er ekki $1200 græjan frá TMS ólæst? :?
Góður punktur líka hjá Finnboga að spyrja Diffsonline hvað þeir geta boðið þér upp á.
Postby BjarkiHS » Sat 14. Feb 2009 10:07
Líst mér ON!
Hvað með þetta ?
Price: $1,199.95
Mér sýnist það...
BjarkiHS
Postby Thrullerinn » Sat 14. Feb 2009 15:30
Done.
Hann ætlar að quota mig um verð á innvolsið, ekki allt drifið.
Er nokkuð einhver stóraðgerð að skipta þessu út, nú hef ég haft vanan á
því að sjá um viðhaldið á bílunum sjálfur en þyrfti helst að komast í lyftu..
More to come í þeim efnum hér á bæ..
Hafa e-r pantað hjá þessu kompaníi, ekki alveg mest sannfærandi heima-
síða sem þeir eru með.
Postby hauksi » Sat 14. Feb 2009 15:42
Spurning hvort þú komir á Group buy dæmi, Ég væri alveg til í að skoða svona ef verðið er ekki skyhigh. 8) 8)
540iA e34 - seldur
330Ci e46 - seldur - RIP 2013 hefði aldrei átt að selja :(
540iA e39 - seldur - RIP 2012
hauksi
Postby iar » Sat 14. Feb 2009 16:09
Done.
Ég keypti drifið mitt hjá þeim og er mjög sáttur við þá (Dan).
Postby slapi » Sun 15. Feb 2009 09:12
Það þarf að stilla drifið inn.
Ef að þú hefur ekki gert það áður myndi ég ekki mæla með að drífa í því sjálfur nema þú hafir vanan mann yfir öxlina á þér.
Postby JonFreyr » Sun 15. Feb 2009 10:11
Ég er einmitt búinn að senda þeim fyrirspurn varðandi drif, gaman að sjá hvað þeir taka fyrir shipping :) enda er þetta kannski ekki það léttasta sem maður getur pantað frá USA :lol:
Volvo 945 Túúúúúrbó
JonFreyr
Postby SævarM » Sun 15. Feb 2009 11:09
ef hann er ekki að skipta um hlutfall þar að segja hring og pinion þá þarf ekki að stilla það inn bara að raða saman.
Sævar M
Stoltur meðlimur í TURBO-CREW
Toyota Avensis 2004
Jeep Willys 383 torfærutæki
KFX450R heavy modded 8)
SævarM
