Þýðing á texta og villumeldingu í e46
Postby xripton » Sun 19. Oct 2008 23:38
Sælir
ég er að fá upp merki sem lítur út eins og riflað dekk með upprópunarmerki inn í við hliðina á D
textin sem ég fann í bókinni sem er btw á þýsku segir
Automatic Getriebe das automatic Getriebe schaltest wegen einer storung nur im notprogramm. bitte den nachsten bmw service aufscuchen nahrer hinweise seite 68
BMW e46 325i Seldur
xripton
Postby xripton » Sun 19. Oct 2008 23:43
hmm fann eitthvað um þetta
Automatic transmission*
Because of a malfunction, the
automatic transmission shifts
only in the emergency program. Please
consult the nearest BMW center.
For additional information: Refer to
page 65.
einhverjir sem hafa lennt í þessu?
BMW e46 325i Seldur
xripton
Postby xripton » Sun 19. Oct 2008 23:46
If the indicator lamp comes on,
there is a malfunction in the
transmission system.
Bring the vehicle to a stop, select transmission
position "P," set the parking
brake and turn the engine off (ignition
key to position 0).
Wait a few seconds, then start the
engine.
If the indicator lamp goes out after a
few seconds, normal transmission performance
has been restored. You may
continue to drive as usual.
If the indicator lamp does not go out,
you can place the selector lever in all
positions. However, the vehicle will now
only operate in 3rd and 4th gear.
If this happens, avoid extreme engine
loads and consult the nearest BMW
center.
hmm sec testa þetta
BMW e46 325i Seldur
xripton
Postby xripton » Sun 19. Oct 2008 23:48
hmm ok nevermind þennan þráð virðist vera komið í lag
BMW e46 325i Seldur
xripton
Postby Angelic0- » Mon 20. Oct 2008 00:20
Var verið að spóla :lol: :?:
Postby xripton » Mon 20. Oct 2008 01:15
:oops:
BMW e46 325i Seldur
xripton
