Fullt af góðgæti fyrir fiktara
Postby SteiniDJ » Wed 18. Jun 2008 00:31
Þið vitið þetta öruggulega flestir, en ég ákvað að pósta þessu samt. Með þessu tókst mér að fá 'live' RPM / km/h display á tölvuna í bílnum (og mikið meira).
Code: Select all
USE OF TRIP METER TEST FUNCTION
To select the coolant temperature display you need to unlock the odometer test functions and then select it - if locked you can only see tests 1 & 2.
1. Hold down the trip reset button and turn the ignition to position I or II.
2. Release the button and press it steadily and repeatedly until you get to test 19.
3. Press and hold the button for about half a second to select test 19.
4. Wait till the display shows "L-Off" and press briefly (1/4 sec).
5. Display should now show test 0.
6. Cycle through to test 7 and press briefly (1/4 sec) to select.
Test 7.0 (which is now selected) is the coolant temp. You can now start the engine.
Everything will cancel (including the unlocking) when you turn the ignition off. If the display returns to the mileage display before you are done, you must turn the ignition off and re-enter test mode. If the display briefly shows a test number (from 3-21) then returns to mileage display, the extended tests have not been unlocked.
Other useful displays are 7.2, the rev counter and 7.3, the speedo (in km/h).
Instructions to access the hidden functions:
1. Hold Trip Reset while turning ignition key to on position
2. LCD should show "Test"
3. Use Trip Reset to select function 19.0 that unlocks all the features
3. Wait for display to show "Off"
4. Depress Trip Reset for 1/4 second and release it
5. With no delay press Trip Reset several times to select one of the following function s
BMW E46 On-Board Computer (OBC) Hidden Codes
1 Car Engine and cluster data
1.0 46nnn Chassis nr/VIN serial number (last 5 digits)
1.1 4nnn K-number
1.2 690236 Cluster Part #
1.3 045210 Coding (04)/diagnosis (52)/bus index (10)
1.4 1200 Week (12)/year of manufacture (2000)
1.5 09_160 Hardware (09) and software # (16.0) of cluster
1.6 Not used
1.7 04__44 CAN-version (04) KI-revision index (44)
2 (test) Cluster System Test - Activates the gauge drivers,
indicators and LEDs to confirm function
3 SI Data
3.0 1098 Used fuel in litres since last SI (Service Inspection)
3.1 0231 Periodic inspection days; elapsed days (since last SI)
4 Momentary Consumption
4.0 0145+ Instant fuel consumption - 0145=14.5 liters/100km
4.1 0018 Instant fuel consumption - 0018=1.8 l/Hour
5 Distance Gone Consumption
5.0 082 Average mileage; 082=8.2 liters/100km
5.1 0536 Calc. km to refuel (momentary distance to go)
6 Fuel Level sensor inputs in liters
6.0 109330+ Fuel level averaged; Left half sensor input=10.9 liters; Right sensor input=33.0 liters
6.1 0439+ Total tank level averaged; vlgs 6.0: 10.9+33.0=43.9 liters
6.2 0442+ Indicated value (44.2) and tank phase
7 Temperature and Speed
7.0 021+ Coolant temperature (2.1C)
7.1 130 Ambient/Outside temperature - chg met 5 pts. 125/130/135
7.2 + Engine speed / Current RPMs 1/min
7.3 + Vehicle speed / Current Speed in km/hour
8 Input value in HEX form
8.0 1d0+ System voltage ADC-Value Hex code
8.1 26C33C+ ADC Values HG left/HG right
8.2 0000 ADC Value brake degradation sensor (000=o.k.)
8.3 18C ADC Value outside temperature
9 Battery
9.0 140 Battery Voltage - 140 = UB 14.0v
9.1 242013+?
9.2 074_78+?
9.3 0011+?
10 Not used
11 Not used
12 Not used
13 Gong Test
14 Not used
15 Status cluster I/O-ports (bit codes) 0=low; 1=high
1st-belt contact, seat belt fastened=0; 2) ignition lock contact, key inserted=0; 3) door contact, door open=0; 4) clock button pressed=0; 5) SI reset=0, for reset=0; 6) EGS transmission failure=0
Status Digital Outputs (bits) 0=inactive, 1=active
1) Gong output; 2) Brake warning lamp; 3) Low fuel warning lamp; 4) EGA lamp; 5) seat belt lamp; 6) manipulation dot
16 Not used
17 Not used
18 Not used
19 Lock Status; unlocks functions in range 3-18
19.0 L-On/L-Off Unlock: press button when "L-Off"
20 Not used
21 Software Reset; reset OBC settings
00 End of test
Stal þessu hérna: http://www.zroadster.net/forum/viewtopic.php?t=14201
Re: Fullt af góðgæti fyrir fiktara
Postby Helgi M » Wed 18. Jun 2008 12:11
Setja þetta í viðgerðarhornið hiklaust, margt mjög gagnlegt þar á ferð 8)
Ekki nógu margir
Helgi M
