Svo má einhver líka gera þetta fyrir mig ef hann nennir fyrir eitthvað smá cash ?
bimma_frík wrote:Alpina wrote:Þetta er ekkert ..ægilega flókið
þarf ekki að fara undir bílinn og eitthvað?
No. Description Supplement Qty From Up To Part Number Price Notes
01 SHIFTING ARM 1 25111220871 $34.88
02 BEARING SLEEVE, ROUND L=26MM 1 05/2005 25111220832 ENDED, See SI 230192468
02 BEARING SLEEVE, ROUND L=26MM 1 25117519669 $8.59
03 BEARING BOLT D=10MMX40MM 1 25111221849 $6.61
04 BEARING, SHIFTING ARM 1 25111220707 $20.87
05 SELF-LOCKING HEX NUT M8 1 07/2007 07129946400 $0.30
05 SELF-LOCKING HEX NUT M8-8-ZNNI SI 1 07129906196
06 SHIFT LEVER 1 25111221978 $63.05 See SI 230192468
07 BEARING, SHIFT LEVER 1 25111220600 $8.48
08 RUBBER BOOT 1 25111220912 $13.50
09 GEAR LEVER COVER SCHWARZ 1 25111221306 $16.63
10 LEATHER SHIFTING KNOB WITHOUT EMBLEM SCHWARZ 1 25111221284 $47.43
10 GEAR SHIFT KNOB PLASTIC/5-SPEED SCHWARZ 1 25111434495 $23.16
11 BENT SELECTOR ROD 1 25111221250 $25.95
12 PLASTIC WASHER 10X16X0,9 2 25111220439 $0.57
13 CIRCLIP 1 25111220379 $0.78
14 GEARSHIFT ROD JOINT SCHWARZ 1 25117503525 $28.46
16 PLASTIC WASHER 10X16X0,9 2 25111220439 $0.57
17 CIRCLIP 1 25111220379 $0.78
18 DOWEL PIN 1 23411466134
19 TENSION BUSH 1 25111203682
20 PLASTIC WASHER 1 25111434194 $0.56
21 TUBING BACKUP LIGHT SWITCH 1 23141220263 $30.69
22 CABLE CLAMP 1 61138364037 $0.11
23 CABLE CLAMP 1 25111220837 $0.41
24 PUSH-BUTTON 1 51481900729 $0.39
25 BACKUP LIGHT SWITCH M12X1,5 1 23141354071 $11.94
