e34 mælaborð test
e34 mælaborð test
Postby Bjarki » Sun 12. Aug 2007 01:28
hvernig framkvæmir maður þetta aftur.
Ég var að reyna að halda inni km mælinum og snúa um einn en það gerðist ekki, prófaði í 3 bílum.
Ég er semsagt að reyna að fá alla mælana til að fara alveg upp og svo niður.
Bjarki
E39: 540iA '98
Bjarki
Postby Gunni » Sun 12. Aug 2007 01:44
Þetta sem þú ert að gera virkar allavega í E36,
þ.e. setja lykil í sviss, halda km pinnanum inni, svissa á pos #1 á svissinum
og sleppa km pinnanum.
Mig minnti að þetta hafi verið nákvæmlega eins í E34, en greinilega ekki
í þínum þremur :lol:
Gunni
Postby lulex » Sun 12. Aug 2007 03:10
Try this for a laugh. Turn off the ignition. Push and hold down the trip odometer reset button on the speedometer. Turn the ignition key to position one (first click) whilst still holding the reset button, may take a few attempts but as far I know it works on all E36s and some other BMWs.
You will now be treated to a very jolly show indeed. First the DME will display a few of it's internal registers in the mileometer LED space. Next all the gauges on the dash will cycle from zero to full scale deflection and back again whilst all the warning lights illuminate. Not only is this pretty but it's the only time you'll see the speedo on my 318iS indicate 160mph!
The registers displayed are
* Vehicle identification number
* Number for BMW internal use
* Number of wheel rotations needed to make up one kilometer
* Software version
* Hardware version
* Index of changes
BMW 325i
lulex
Postby lulex » Sun 12. Aug 2007 03:22
This works on all instrument clusters 1992-1999 E36 - 4 door/coupe/convertible/M3.
Step 1. Press and hold the mileage reset button.
Step 2. Put key into ignition switch and turn to KLR (Ignition switch position #1)
Your LCD display will show something like this "tESt 01"
Step 3. Once "tESt 01" is shown, let go of reset button and the IC
(Instrument Cluster) will go through some test cycles.
Numbers will be shown and here's what they mean:
1st display: BMW PART NUMBER (6 digits)
2nd display: CODE NUMBER (5 digits) Internal Coding Plug #
3rd display: K NUMBER (4 digits)
4th display: CHASSIS NUMBER (5 digits) this is part of your VIN
5th display: SOFTWARE VERSION (3 digits)
6th display: REVISION INDEX (2 digits) Hardware #
After all 6 displays are finished, an analog gauge test will be performed.
The self-test is canceled by switching the ignition off or
to KL-15 (ignition switch position 2)
IC (instrument cluster) tests 1-15
1995 - 1998 (99) 318ti
1996 - 2000? Z3
1997 - 1999 E36 4dr/coupe/convertible/M3
NOTE:
*Test functions 1-4 are unlocked tests and can be called up at any time for display.
*Test functions 5-14 are locked and require unlocking the test mode before they can be displayed.
*Test functions 2-14 can be selected at any time when the cluster is unlocked, even when vehicle is moving.
*Test function 15 is the lock/unlock function.
Step 1: Press and hold the mileage reset button.
Step 2: Put key into ignition switch and turn to KLR (Ignition switch position #1)
Step 3: You will need to unlock the test function first so when the LCD
Display shows "tESt 01," press the reset button till you get to "tESt 15."
Once you're on test 15 press, and hold the reset button for a few seconds
until it displays "off." Now you can cycle through the test features.
Here they are as they follow:
Test 1: Instrument self test
Test 2: Engine Data - This display is an "engine factor" value that is stored
in the coding plug. The instrument cluster processor uses this factor in
addition to the "TD" signal from the DME control module to process and
display tachometer RPM based on the engine installed.
For EXAMPLE:
*ENGINE FACTOR 2 = 4 CYLINDER
*ENGINE FACTOR 3 = 6 CYLINDER
*ENGINE FACTOR 4 = 8 CYLINDER
Test 3: SI elapsed distance - the total mileage in kilometer since the last reset.
Which service is due at the next inspection (OIL SERVICE or INSPECTION)
Test 4: SI elapsed days - no value for US vehicles. Relates to Euro annual inspections.
Test 5: SI evaluation factor - for engine speed and temp. thresholds being passed.
Display: n = 0 or 1. Engine speed (over-rev)
t = 0 or 1. Engine temp.
NOTE: "n0" means that you hit the maximum threshold for engine speed and "t1"
means you overheated the engine. I found out from my instructor that this
test 5 is false due to software related problems.
Test 6: Fuel Level and coolant temp. - Display of hexadecimal codes in
relation to gauge position.
Fuel gauge ----------------> Hex value
A (empty)--------------> 0d
End of reserve----------> 37
B-----------------------> 54
C-----------------------> 90
D-----------------------> c4
E (full)------------------> f0
Engine temp. --------------> Hex Value
A-----------------------> ce
B-----------------------> 6d
C-----------------------> 5c
D (center)--------------> 4f-23
E-----------------------> 1e
F-----------------------> 18
Test 7: Engine speed (Digital Tach)- display of current engine speed
Test 8: Road speed - display of current road speed in km/h
Test 9: Distance reading - this allows the total stored mileage to be updated
if one of the storage components has to be replaced. This test step will be
used if the manipulation dot is illuminated in the cluster display. This
display will show the component with the lower mileage. For example:
Display of 012654 l indicates that the mileage in the internal EEPROM is
lower than the mileage stored in the coding plug.
Display of 000325 E indicates that the mileage in external coding plug is
lower then the total mileage stored in the internal EEPROM.
Pressing the reset button for 4 seconds will over write the lower mileage
with the higher mileage and cancel the manipulation dot. The SI data will
also be transferred at the same time.
Test 10: Status bits (input signals) - the status of digital inputs to the cluster are displayed as 0 or 1.
Display: 0 = input low, 1 = input high.
_ _ _ _ _ _ <--- Mileage display...6 digits left to right
1st - belt contact, seat belt fastened = 0
2nd - ignition lock contact, key inserted = 0
3rd - door contact, door open = 0
4th - clock button pressed = 0
5th - SI reset = 0, for reset = 0
6th - EGS transmission failure = 0
Test 11: Status Bits (output signals) - the status of digital outputs is displayed.
Display: 0 = output inactive, 1 = output active
1st - Gong output
2nd - Brake warning lamp
3rd - Low fuel warning lamp
4th - EGA lamp
5th - seat belt lamp
6th - manipulation dot
Test 12: not used
Test 13: Country code of cluster - the display indicates the country version
of the cluster. This cannot be changed in the workshop. Display: USA 02
Test 14: Software Reset - The reset must be carried out if any faults are
present that are not plausible before any components are replaced. After the
reset, the system will exit the TEST mode and the lock will be reactived.
BMW 325i
lulex
