BMW wrote:"The solution implemented will still provide for a monitoring of vehicle and drive train conditions and it should be pointed out that under unfavorable traction conditions even a deactivated DSC still can intervene by reducing engine output".
Hence the solution they are providing is in fact not a pure "DSC off" solution but instead a DSC "mostly-off" solution. BMW NA had stated in the past that the reason for the original plan to not allow DSC off was due to rear wheel hop under launching conditions and the potential for rear drivetrain/subframe damage. So it appears they are going to somehow monitor for that condition and dump the throttle on you if you put the car in such a state. This may be a real tricky car to launch hard now since you're going to have to balance the onset of wheel hop versus too much hop and DSC cutting out the throttle. I wonder if there are other "conditions" they are going to have it intervene also (i.e. at speeds higher than a launching condition)? They REALLY need to come clean on the whole potential envelope of control it still has so people know what to expect.
slapi wrote:Hverjir hata SMG ?
slapi wrote:Hef ekki séð það að SMG hafi eitthvað verið að klikka , þá hérna heima.
SMG er algjör snilld , gírunin , hraðinn og nákvæmnin er öskrandi geðveik og ég sé ekki alveg hvernig að þessi sexgíra bsk kassi sem að er sá sami og í E39 henti S85 mótornum jafnvel og S62.
SMG 4TW
SMG 4TW
