Smá vandræði með TV í e38 750I
Postby Roark85 » Tue 17. Oct 2006 15:07
Sælir,er með E38 BMW 750i og hann er með tv (Litla skjánum) og er að spá hvernig eg tek insiglið af svo eg geti horft á tv/dvd á meðan eg keyri,kemur alltaf upp þetta safety kjaftæði..
Einhver sem getur hjálpað mér???????
BMW:
E90 320D M/// 2,0L Big Turbo (my05)
E53 X5 4,4L Sport V8 (my01)
E46 318i AC-Schnitzer 2,0L (my03)
E38 750ia 5,4L V12 (my98) (Induvidual)
E34 520i 2,0L (my95)
E39 540i Touring M 4,4L V8..(my98)
E34 M5 3,6L(my91)
E28 528i 2,8L (my84)
Roark85
Postby Eggert » Tue 17. Oct 2006 15:40
Seinast þegar ég vissi þá er þetta ekki innsigli, heldur stilling? Heyrði allavega af því í E39... Hef samt því miður ekki fyrir þig það sem þú þarft. Gangi þér vel að finna það þó..
Eggert
Postby Jss » Tue 17. Oct 2006 15:43
http://www.750i.de/e/repair.htm wrote:Watch TV / Videotext during driving
This works on all 5/7 Series with the Mk. I Navigation System (the one with the male voice). On Mk II (the newer version with the female voice) you have to use "brightness" instead of contrast for TV and "color" instead of brightness for videotext to get the trick to work. I know that the trick works on latest 99 7series models as well. But I heard also that some cars sold into the US do not have any TV equipment on board. You will notice this as they do not have any TV option in the main menu. Also latest BMWs sold in Europe (2000 onward, 3/5/7 series) have the trick disabled! The only chance to get the TV running is somewhere hidden in the menu of the BMW Sevice Tester DIS. But up to now I can't thell you where. If I ever find it out, I'll post it here!
As far as I know the software update for latest navigation CD Roms does not affect or disable this trick.
* Set ignition to pos. II
* enter TV mode
* enter "settings"
* enter "contrast"
* when the green contrast bar is visible, push the knob and keep it pressed
* turn ignition off (keep button pressed!)
* wait 8-10 seconds (timing must be accurate!)
* release the knob
* turn on ignition again
* Now you can watch TV during driving (but always keep at least one eye on the road - that said)
To watch videotext use the same procesure as above, but chose"brightness" instead of "contrast" (thanks to my friend Herbert Posner, who discovered this secret).
Fannst á google á innan við mínútu. ;)
Jóhann
Jss
Users browsing this forum: No registered users and 60 guests
