Hvernig ræniru sjálfsala?? Hér er svarið
Postby Haffi » Wed 04. Jun 2003 21:43
Part 1 - How to Rob Pop Machines for money and pop
Take an empty 2 litre bottle of pop and fill it with luke warm water.
Then put about a good 1/2 cup of salt in and mix it up real well. Go find a
fairly deserted pop machine late at night, and either make a funnel with a
rolled up newspaper, or go and buy one. Then stick the funnel in the slot
where you deposit your money, and slowly start pouring the salt water into the
coin slot (get the brave one to do this ;-) ).
The water will run down the METAL and into the coin box. In the coin
box, there are two little "switches". One gives out pop when it is activated,
and the other gives out change. When the water runs down in between them,
the water conducts electricity and short circuts them. The pop machine will
then start to radomly shoot out pop and money. It is best advised to either
have someone stading near the power cord to the pop machine (ready to unplug
it), or have somebody with a pair of hedge clippers that will cut the cord.
This is not always needed, but we had one machine that was possesed, and almost
fucking landed on top of us!
Thanks to Analog Kid from 2112 for this GROOVY info!
Part 2 - How to Rob Arcade Games
This method is very simple, but it does work. Go and get and ordinary
quater and drill a hole near the out side about 1/16 of an inch big. Then go
down to your local hobby store and pick up some of that thin heavy duty string
they use on model rocket parachutes. As you probabbly have guessed, tie the
string through the hole, and viola! Insert your quarter VERY VERY SLOWLY, and
when you hear the machine accept your credit, slowly pull it back a little ways
and do it again and again untill you have like 100 credits. I have also heard
of people magnetizing their quarter and when they pulled the "quarter on a
string" out of the coin box, they brought like six more quarters up with them.
If your quarter does get stuck, you can pull fairly hard on the string, and
even if it does break, it's only a quarter. This also works well for cigarette
machines (especially in Canada if you use "loonies").
(áGâ Note: There is also a method that has gotten less publicity called
"Penny Flicking" in which you take a penny and flick it up the coin return
slot. However, we have yet to experience this successfully. If anyone
succeeds in doing, let us know.)
Part 3 - How to get free Candy and chips and shit.
This only works on two types of machines. 1 - The type that have the
25 cent gumballs, or the M&M's, or peanuts and other shit. You put in a dime,
or a quarter and turn it. 2 - Almost the same, except you must use silver
dollars or 4 quarters, they have the chocolate bars and chips that have that
coily thing that revolves and drops the item. It would probabbly work at some
laundry machines that work the same way. Take your quarter and put it in the
slot. Now you can either do two things here, you can use a peice of scotch
tape and tape the quarter in, or you can even use a peice of gum on the back of
the quarter to hold it in place (This actually works alot better). Then just
simply turn the handle, when it somes around again, your money will still be
there, and the candy will come out! So, turn it again! The reason this works
is because the machine releases candy as soon as the coin slot can turn all the
way, not when the coin drops....The coin doesn't even have to drop, it just has
to turn. So if you prevent your quarter from falling, it will come back.
Haffi W. Schnurrenberger.
Haffi
Postby arnib » Thu 05. Jun 2003 00:42
Þetta er nú meiri snilldin! :)
Ég er alveg að fara að fara í leiðangur heheh.
BMW E46 328i
arnib
Postby Haffi » Thu 05. Jun 2003 12:06
Ég var að finna rúmlega 12.000 bækur á tölvunni og svo einhverjar 269 bækur og hint's um að lifa frítt og svíkja peninga útúr ríkinu :)
Ætla að fá einhvern heilalítinn félaga til að prófa eitthvað af þessu.
Haffi
Postby benzboy » Thu 05. Jun 2003 13:15
Þvílíkt vesen fyrir pop og súkkulaði
XC 90 2005 V8 (frúarbíllinn)
Suzuki Hayabusa GSX1300R 1999
B3 biturbo 2008 #101 (on it's way)
benzboy
Postby GHR » Thu 05. Jun 2003 13:29
benzboy wrote:Þvílíkt vesen fyrir pop og súkkulaði
Nákvæmlega :lol:
GHR
Postby flamatron » Thu 05. Jun 2003 17:32
"Pop"ið er reyndar Gos.! :lol:
Tómas
BMW 325ic '95
Isuzu Trooper '99
flamatron
Postby benzboy » Fri 06. Jun 2003 09:49
flamatron wrote:"Pop"ið er reyndar Gos.! :lol:
Sem gerir þetta þá ómaksins virði eða.... :?: :?: :?:
benzboy
Postby flamatron » Fri 06. Jun 2003 15:54
Ég sagði það ekki, ég helt að þú hafið verið að meina Popp,!! :?
Tómas
BMW 325ic '95
Isuzu Trooper '99
flamatron
