E30 M3 Europa(RUST)Meister
Re: E30 M3 Europa(RUST)Meister
Postby Angelic0- » Mon 01. Nov 2010 02:08
Angelic0- wrote:OMG, var að vona að þessi yrði OEM forever... en jesús hvað hann er/var ryðgaður.... hélt að þetta væri nú með heillegri E30 á landinu !!!
Það verður öllu OEM haldið til haga skilst mér þannig að hægt sé að fara með hann til baka.
öllu OEM sem að er í lagi :) en þá hljómar þetta strax betur :)
Postby bimmer » Mon 01. Nov 2010 13:24
Was looking at the car today on a rotisserie (veltibúkki) and...... :shock:
Rustmeister indeed!!!
Postby Zorba » Mon 01. Nov 2010 15:45
Things to be ordered this week. Some will be changed but here is what we are negotiating so far:
UUC E30 M3 Stainless Steel Clutch Line
Clutchmasters - E30 M3 Clutch Kits Stage 1, Performance full-face Organic
E30 Stainless Steel Brake Line Kit, with Protective Coating, D.O.T & TUV Approved
E30 (M3) Complete Chassis Reinforcement Kit, Includes:
-Front Sway Bar tab reinforcements (2)
-Front subframe/Motor mount reinforcements (2)
-Rear Sway bar trailing arm reinforcements (2)
-Rear Sway bar chassis floor reinforcements (2)
-Rear Shock-tower mount reinforcements (2)
-Instructions
BMW-E30 M3, Short-Shift Kit Premium Kit, Includes:
-1.9L Z3 Shifter (A long time favorite replacement of E30M3 enthusiasts)
-Gear Shift Rod-Joint Washer
-(2) Cir clips
-Shifter-Rod Sleeve Bushing
-Carrier Rod Bushing
-(4) yellow washer shims
-Gearshift Selector Rod Joint
-Rod Joint foam Shim / Spacer
-Shifter Carrier Arm Bearing
E30 Finned Differential Cover *** With Hardware, Bushing, and Gasket ***
AKG E30 M3 Group N Polyurethane Engine & Trans Mount Set
SAMCO - Stainless 26 piece Coolant Hose Clamp Kit, E30 M3
SAMCO BMW E30 M3 Sport Hose Kit, (13 pcs ) – Black
BMW-TRMO-E30M3 Thermostat
E30 M3 Water Pump - Original BMW
BMW - E30 M3 Oil Pump, High Performance/ Evo 3 Version
S14 Oil Pump Upgrade Kit Installed
VAC E30 M3 Standard Stroker Kit
BMW OEM Sport Evolution 2.5L Crankshaft
-BMW OEM Bearings or VAC High Performance Race Bearings
-BMW OEM Crank Bolt, and Washer
-BMW OEM Head Bolts & Rod Bolts
-BMW OEM 2.5 Head Gasket
-BMW OEM Lower Gasket Set
-CP Pistons Forged Piston set with high quality Rings, Pins, & Locks
SPECIFY DESIRED COMPRESSION RATIO
-VAC Tech Support
-VAC custom tuned Motronic ECU Software (on request)
S14 Torque Plate Kit, with 1.4" Spacers to simulate head thickness
VAC - ACS Style Carbon Fiber Aero Mirrors
VAC - E30 M3 (Sport Evolution size) Wing, Fiberglass body with Carbo Fiber Flap
BMW - E30 M3 Evo2 Front Air-dam
Hella Smoked Headlights with 8 piece OEM Connector Set/Installation Set
Suspension Techniques - Sway Bar Kit, E30 (all, not iX)
-22mm fixed front bar
-19mm adjustable rear
-Bushings, Hardware, Reinforcements for rear
VAC Roll Center Spacers, E30 M3 -3/4"
TCK Rear Shock Mount, Urethane 12mm, Pair
Semi-Trailing Arm Rear Camber or Toe Adjustment Kit, one pair only
(2 needed for camber + Toe)
Tree House Racing E36, E30 Eyeball Arms / Control Arm Bushings
Powerflex Rear Inner and Outer Trailing Arm Bushing Set
Powerflex - E30 Rear Subframe Bushing Set
S14 Heavy Duty Alternator Bushings, Set of 4
VAC - "Stage 2" S14 Performance Kit, Includes:
-Schrick camshafts (284in/276ex) A favorite all around cam setup.
-Matched VAC Motorsports Dual Valve Springs
-VAC Software for factory Bosch Motronic ECU (2.3L)
Ignition Wire Set for S14
VAC S14 Oil Pan Baffle
High Pressure Radiator Cap 24 lbs.
VAC E30M3 Brake Cooling Kit, Inlcudes ducts, backing plates, hoses, and clamps
KW Variant 2 Coil over kit, E30M3 with $200 core charge for stock spindles
Ground Control E30 Caster Camber Plates
VAC E30 M3 BBK:
-Precision machined aluminum hats
-Extra heavy duty upgraded vented rotors (at no cost)
-New Dynapro 4-Piston Wilwood calipers
-VAC Caliper brackets and fittings
-Stainless steel brake lines
-ARP hardware
-6 piston option available for 17" wheels or larger at +$200
Choice of: Performance Street, Heavy Duty Street, or Track pads (+$110)
VAC E30 M3 BBK, Rear:
Choice of radially mounted SL4R calipers (+$450) or lug mounted Superlite ( Backing plates must be trimmed for street use
-Emergency brake ring using stock mechanism is available for +$250
Choice of: Performance Street, Heavy Duty Street, or Track pads. (+$110)
BBS RGR 17x8 Forged Aluminum Wheel
BBS RGR 17x9 Forged Aluminum Wheel
BMW 26 12 1 225 071 Driveshaft Ball Bearing
BMW 33 10 7 505 602 Shaft seal with lock ring for differential
BMW 33 21 9 067 812 Repair kit, CV boots, Inside
BMW 33 21 9 067 815 Repair kit, CV boots, Outisde
BMW E34 M5 Drive Shaft Guibo, E30 M3 Upgrade
BMW 18 21 1 315 015 Middle Exhaust Hanger
BMW 07 11 9 900 052 Flat Washer for middle exhaust hanger
BMW 07 11 9 913 011 Hex Bolt for middle exhaust hanger
BMW 18 21 1 105 635 Rubber Ring rear exhaust hanger
BMW 18 20 1 310 509 Bow Rear Exhaust hanger
BMW 07 11 9 915 189 Hex bolt Rear exhaust hanger
BMW 18 30 1 737 774 Hex nut rear exhaust hanger
BMW 18 21 1 712 838 Rubber Ring Exhaust hanger
BMW 31 12 1 130 823 Front Left control arm, Al
BMW 31 12 1 130 824 Front Right control arm, Al
BMW 32 21 6 769 539 Self locking hex nut
BMW 31 11 1 114 348 Flat Washer for lollipops
BMW 31 11 1 137 888 Hex bolt for lollipops
BMW 07 12 9 906 196 Self locking hex nut, alternator bracket
BMW 12 31 1 312 137 Alternator Adjusting bar
BMW 12 31 7 677 914 Idler, Alternator bracket
BMW 12 31 1 276 516 Saucer head screw alternator
BMW 07 11 9 913 676 Hex bolt alternator
BMW 07 11 9 913 659 Hex bolt alternator
VHT Translucent Lens Tint
VAC S14 Carbon Fiber Intake Kit
Includes-
-Carbon fiber Airbox
-Carbon fiber lower Snorkel
-Silicone Airbox-to-Snorkel Hose
-ATE Brake Fluid Reservoir
-Reservoir Hoses
-K&N Filter
-Laser cut Throttle relocation brackets
-Hose Clamps
-Required Hardware & Brackets
BMW 850 Brembo 4 Piston Caliper, bolts onto E30M3 Spindle
BMW E46 M3 CSL Brake Disc
-------DTM Airbox kit with Nearly Plug and Play Standalone Engine Management Option------
VAC - "Stage 3 Pro" S14 Performance Solution
>S14 Stage 3 Pro Kit Includes:
-VAC Carbon fiber DTM Airbox Kit for S14 (everything needed)
-KMS MA25 Premium Engine Control Unit (mil-spec aluminum, plastic on request)
-KMS Mx25 ECU Harness
-KMS In-car Lambda/ ECU readout display
-KMS Wide band O2-Sensor and controller
-KMS Air & Water Temp Sensors
-KMS Engine Harness
-KMS Distributor-less ignition unit
-VAC DIS-Coil Billet Mounting Kit
-VAC Crank trigger kit
-VAC TPS Adaptor Kit
-VAC S14 Idle Air Valve Delete
-VAC OE Distributor Block Off Plate
-VAC Intake Cam cover plate
-K&N Filter
---Your choice of base maps so you can install and go!
---The invaluable tech support and experience of VAC Motorsports
---Full warranty
Engine Rebuild Labor, S14 2.5 Stroker Conversion -Estimate- :
Includes...
-Complete Disassembly & Inspection of all Components from an Assembled Engine.
-Clean, Check, Degrease, Steam Clean or Hot-tank all Components.
-Magnaflux/ Inspect all Ferrous Components.
-Bore & Hone with VAC torque plate.
-Resurface Block Deck and Cylinder Head.
-Balance Rotating Assembly.
-Prep Con Rods, Gap Rings & Install Pistons, Blueprint.
-Mic all Bearings and Machine as Necessary.
-Install Crank. Install & Degree Cams, Set Spring Seat Pressure, Time Engine
-Final assembly, Prime & Paint External Finish.
*specify block color*
(align bore may be needed on some engines, + $150)
VAC Stage 1 Performance Cylinder Head
Features the following:
-Complete Disassembly & Cleaning
-Comprehensive Leak, Crack & Pressure Test
-Inspect All Components For Irregular Wear
-Our High performance Multi Angle Valve Job using Serdi Equipment
-All New VAC Uprated Valve Guides
-Viton Valve Seals
-Reconditioning & Blueprinting of Your Valves
-Balancing of Your OE Springs
-Trueness Checked & Resurfaced Mating Surface
-Unshrouding of Valves
-Attention to Potential Hot-spot Areas and Chamfering
BMW Standard Engine Mount
BMW Standard Transmission Mount
Miller - AFM to MAF Conversion Kit (With 'WAR' User Programable ECU Chip)
Zorba
Postby Aron Fridrik » Mon 01. Nov 2010 15:55
:shock:
it's going to be amazing though :thup:
Postby Jón Ragnar » Mon 01. Nov 2010 15:56
:shock: :shock: :shock:
Postby íbbi_ » Mon 01. Nov 2010 15:59
yeah!!
Postby bErio » Mon 01. Nov 2010 16:11
As we say in Icelandic
GÓÐAN DAGINN !
BMW E39 540i '00 - Sedans
E39 k1ng
Sævar P.
bErio
Postby tinni77 » Mon 01. Nov 2010 16:17
Ef þetta telst ekki til Team BE þá veit ég ekki hvað
Great job Magnus ! :thup: :thup:
BMW E30 325i Coupe
tinni77
Postby srr » Mon 01. Nov 2010 16:18
bErio wrote:As we say in Icelandic
GÓÐAN DAGINN !
Nei nei nei,,,
JÁ SÆLL :shock:
Postby jens » Mon 01. Nov 2010 16:29
:thup:
Postby Einarsss » Mon 01. Nov 2010 16:31
WTF!!! whats the total $$$?
I think we dont even have to vote for the Car of the year 2011,project of the year 2011, biggest spender 2011 :lol:
Mad props! 8) 8) 8) 8) 8) 8)
Postby JOGA » Mon 01. Nov 2010 16:35
Nice list and nice wheels... :thup:
Edit: These are 18"
Postby SteiniDJ » Mon 01. Nov 2010 16:42
Great job, man. Extremely great job.
I'm writing a letter to Mr. Grímsson, the president of the Icelandic Republic, as we speak, requesting that you will be honored with the Order of the Falcon. You deserve it.
Keep it up and you will, without a doubt, own one of the best E30s on earth!
Postby bimmer » Mon 01. Nov 2010 16:42
RRrrrrrriiiiinnnnngggggg.......
"Mr. VAC?"
"Yes"
"I´ll have a complete E30 M3 - unassembled - and I mean every fucking piece"
"Ok....."
"Ship it to Iceland"
"Ok, no problem."
"Bless"
Postby SteiniDJ » Mon 01. Nov 2010 16:47
"Bless." :lol: Ég skellti upp úr.
Users browsing this forum: No registered users and 65 guests
