Danni wrote:Ég veit, hann spurði hvar þetta var tekið ekki hvaða bílar eru þar inni
gunnar wrote:Þú vonandi átt Throwing Star felgurnar ennþá?
Ekki að þetta sé ekki fallegt, en hitt settið á bara heima með bílnum
Alpina wrote:E34 M5 + Throwing star er alveg málid
Aron Fridrik wrote:Sjæna og mounta þær öfugar
hexagone wrote:contrary to popular belief, this doesn't work exactly well on all LMs unless you do some machining. The top mounted LMs have an upper flange that is rounded rather than squared.
So if you reverse mount it, the rounded part makes contact with the barrel first rather than the flat mounting surface. So you could do it, but it leaves a very minimal gap between the face and the mounting flange of the barrel- resulting in all the stress being exerted only on a single point rather than plane.
rockstone wrote:Aron Fridrik wrote:Sjæna og mounta þær öfugar
Tekið af bimmerforumshexagone wrote:contrary to popular belief, this doesn't work exactly well on all LMs unless you do some machining. The top mounted LMs have an upper flange that is rounded rather than squared.
Users browsing this forum: No registered users and 56 guests
