E30 M3 Europa(RUST)Meister
Re: E30 M3 Europa(RUST)Meister
Postby slapi » Tue 02. Dec 2014 15:55
Just remember to orientate the adjusment bolts in the same direction to get the thrust angle right , people have been failing on that
Postby fart » Tue 02. Dec 2014 16:05
thankfully the camerawork doesnt really show the welds that well :lol:
Postby bimmer » Tue 02. Dec 2014 16:48
fart wrote:thankfully the camerawork doesnt really show the welds that well :lol:
Ouch......
Postby fart » Tue 02. Dec 2014 16:54
Ouch......
hehe :santa:
Postby Zorba » Tue 02. Dec 2014 20:25
Ouch......
hehe :santa:
Zorba
Postby Zorba » Fri 30. Jan 2015 21:09
Small update. . .
Got access to this today.....
.... and managed to get on with some welding with a lil help.....
Subframe repaired and reinforced:
Had to cut the bottom reinforcements to access the back
Then new plates welded in...
The top had to be filled in....
and then smoothed...
Finally the uter ones were welded back on ...
Then we did the ARB mount holes:
I mounted the reinforcements and secured them with a 10mm bolt:
Then welded all around and smoothed the welds (should look much better after paint):
The otherside was much worse as i had to remove some of the rusted area:
I am debating if i should leave it as it is or close it. As far as I know this holes only act as drains so it may be better to have them slightly larger.
What do you guys think?
Should be getting blasted again tomorrow and then painted.:-)
Zorba
Postby Alpina » Fri 30. Jan 2015 23:40
Weld,,,,,,,,,,,,,,,, meister ?
Postby Zorba » Sat 31. Jan 2015 00:18
Alpina wrote:Weld,,,,,,,,,,,,,,,, meister ?
Zorba
Postby Angelic0- » Sat 31. Jan 2015 16:15
Incredible craftsmanship :!:
:thup: :thup: :thup:
Postby Zorba » Fri 20. Feb 2015 09:21
Some small progress.....
Steering rack was taken completely apart .....
and parts painted and cleaned....
New seals replaced.....
And started putting it back....
I am still trying to find new bearings for it but seems like even the dealer can not find them.
The bearings are the ones circled in the below pic (altough the one I really want to replace is No.57
Worst case scenario I will reuse the old ones but if you guys know a part number or where to get new ones please let me know!
Zorba
Postby tinni77 » Fri 20. Feb 2015 21:51
Just take the bearing to Fálkinn and they will take care of you.. ;)
OE Quality stuff there+excellent service
BMW E30 325i Coupe
tinni77
Postby Zorba » Sat 21. Feb 2015 16:39
tinni77 wrote:Just take the bearing to Fálkinn and they will take care of you.. ;)
I already did that ....and they dont have anything like that
Zorba
Users browsing this forum: No registered users and 104 guests
