E30 M3 Europa(RUST)Meister
Re: E30 M3 Europa(RUST)Meister
Postby Zorba » Thu 19. Dec 2013 17:54
Xmas present pack 1 of 3.....
Should keep Sævar busy......;-)
Description Qty Part Number
1 Centering sleeve 1 26117526611
2 UNIVERSAL JOINT 1 26112226527
3 Hex Bolt 3 26117523709
4 Self-locking hex nut 6 7129900047
5 Self-locking hex nut 6 26127536563
6 Hex Bolt 3 26111225754
7 Gear selector rod joint 1 25 11 7 501 309
8 Dowel pin 1 23 41 1 466 134
9 O ring 2 25 11 1 221 243
10 Spacer ring 1 25 11 1 220 199
11 Circlip 1 07 11 9 932 863
12 Gear lever 1 25 11 7 527 252
13 Spacer ring 2 24 11 1 220 439
14 Circlip 2 25 11 7 571 899
15 Shift lever bearing 1 25 11 1 220 600
16 Exhaust gasket 1 18 30 1 711 969
17 Cover, wheel housing, front left 1 51711935841
18 Cover, wheel housing, front right 1 51711935842
19 HEAT INSULATION TUNNEL BOTTOM 1 51481953999
20 HEAT INSULATION TUNNEL BOTTOM 1 51482233176
21 Hex Bolt with washer ? 7119915066
22 Washer ? 7119900052
23 WAVE WASHER ? 7119932095
24 Heat insulation 1 51481911009
25 Push-button 2 51481923999
26 Push-button 2 51481923999
27 Push-button 1 51481923999
28 Push-button 1 51481976047
29 Heat resistant plate 1 51481943997
30 Hex nut 4 51451868108
31 Hex nut with plate 4 7147134319
32 Engine compartment screening 1 51711923771
33 Engine compartment screening 1 51712230719
34 Engine compartment screening 1 51712233043
35 Engine compartment screening 1 51711961894
36 Plastic nut 2 16131176747
37 Hex head screw 4 7119901294
38 Hex head screw 4 7119901299
39 Hex head screw 8 7119916967
40 Body nut 8 7129925711
41 Body nut 3 51480141020
42 Body nut 3 51481954066
43 Body nut 3 7146949380
44 SOUND INSULAT.DASH PANEL ENGINE ROOM CE. 1 51481916442
45 SOUND INSULAT.DASH PANEL ENGINE ROOM L. 1 51481962045
46 SOUND INSULAT.DASH PANEL ENGINE ROOM R. 1 51481962048
47 SOUND INSULATING DASH PANEL INNER ROOM 1 51481906393
48 SOUND INSULATING ROOF FRONT 1 51481906391
49 SOUND INSULATING ROOF REAR 1 51481906392
50 SOUND INSULATING REAR WINDOW FRAME LEFT 1 51481906381
51 SOUND INSULATING REAR WINDOW FRAME RIGHT 1 51481906382
52 Expanding rivet ? 51481884779
53 Expanding rivet ? 51481904142
54 Push-button ? 51481906207
55 Push-button ? 51481916238
56 Push-button ? 51481923999
57 Push-button ? 51481923999
58 Push-button ? 61131373669
59 Sound deadener ? 51481864964
60 Sound deadener ? 51488165271
61 E24 transmission mounts (one on the right) Is it 23 71 1 175 732
62 1 11 81 1 094 149
63 RUBBER MOUNTING RIGHT 1 11 81 1 094 150
64 Hex nut 2 7129904864
65 Hex nut with plate 2 32101133077
66 Hex nut with plate 2 22316760944
67 E28 535 Front wheel bearing 2 31211131298
68 Cup 2 31211128423
69 Wheel hub with bearing, front 2 31212225362
70 Collar nut 2 31211128336
71 Cap 2 31206777789
72
73 DUST PROTECTION 1 26111225089
74 DUST PROTECTION 1 26111225089
75 Dustcover plate 1 26111226553
76 GROOVED BALL BEARING 1 26121225071
77 Centre Mount 1 26112225620
78 Centre Mount 1 26121226723
79 Dustcover plate 1 26111225088
80 Dustcover plate 1 26111225088
81 Dustcover plate 1 26111226552
82 Lock Ring 1 26123648156
83 Threaded ring with clamp-ring 1 26117514037
84 TOOTH WASHER 1 26111209285
85 Threaded ring with clamp-ring 1 26117514037
86
87 Repair kit bellows, interior 2 33219067812
88 Repair kit bellows, exterior 2 33219067815
89 Securing plate 2 33411124945
90 Collar nut 2 33411125664
91
92
93 Collar nut 2 33331126136
94 Knurled bolt 2 51718181460
95 SET RUBBER MOUNTING ECCENTRIC 2 33329058822
96 Set rubber mounting 2 33329061945
97 Self-locking hex nut 4 7129900047
98 Hex Bolt 4 33321136406
99 Washer 2 33332225797
100 Pulse generator 2 34521155041
101 Fillister head screw 2 7119919913
102 WAVE WASHER 2 7119932099
103 WAVE WASHER 2 7119904496
104 Bracket 2 34521154232
105 Cable clamp 4 63121364431
106
107 Protection plate left 1 34212225444
108 Protection plate right 1 34212225445
109
110 Repair kit for Power steering ????????????
111 Fuel feed line 1 16121179285
112 FUEL RETURN LINE 1 16121177372
113 SPACER HOLDER 2 16121176766
114 Fuel hose ? 16121180409
115 Fuel hose ? 16121180409
116 Heat resistant plate 1 16111177345
117 Bracket, right 1 16111177347
118 Bracket, left 1 16111177346
119 Hex head screw 4 7119916966
120 Body nut 4 7129925719
121 Hex Bolt with washer 2 7119915042
122 Washer 2 7119936425
123 Washer 2 7119903791
124 Hex nut 2 7119905543
125 Protection plate 1 16111179429
126 AIR GUIDE 1 16111178949
127 AIR GUIDE 1 16111178949
128 Plastic nut 5 16131176747
129 Hex Bolt with washer 4 7119913214
130 SENDING UNIT ASSY METAL TANK 1 16141155075
131 Gasket ring 1 16141155066
132 Filler pipe 1 16112225577
133 Rubber grommet 1 16111176761
134 Hex Bolt with washer 1 7119915047
135 FILLER CAP WITHOUT LOCK 1 16116750564
136 Lockable filler cap 1 16121178534
137 Lockable filler cap 1 51212291901
138 Rubber seal 1 16111179680
139 Hose 1 16121180402
140 Hose clamp 1 7129952115
141 Hose clamp 1 7129952119
142 Hose 1 16111178927
143 Rubber seal 1 16111177659
144 Brake hose rear 1 34321159878
145 ONLY APPLIES TO DISK BRAKE 1
146 Brake hose rear 1 34321159881
147 DISTRIBUTION PIECE 1 34341111435
148 BRAKE PIPE BRACKET 1 34301161567
149 Clip 1 34341163565
150 Pipe 1 34326755686
151 Pipe 1 34326755567
152 Pipe 1 34326755560
153 Pipe 1 34326755591
154 Pipe 1 34326755591
155 BRAKE PIPE BRACKET 1 34321158467
156 Brake hose 1 34321159890
157 Clip 1 34341163565
158 Rubber grommet 1 34321154322
159 BRAKE PIPE BRACKET 1 34321160027
160 BRAKE PIPE BRACKET 1 34321156013
161 Hex head screw 1 7119916971
162 For vehicles with 1
163 without catalytic converter 1
164 Hex head screw 1 7119916971
165 Fuel hose 1 16121180409
166 For vehicles with 1
167 without catalytic converter 1
168 Fuel hose 1 16121180409
169 Hose clamp 1 7129952102
170 For vehicles with 1
171 without catalytic converter 1
172 Hose clamp 1 7129952102
173 Hose 1 16121177553
174 For vehicles with 1
175 without catalytic converter 1
176 Hose 1 16121177553
177 Hose clamp 1 7129952107
178 For vehicles with 1
179 without catalytic converter 1
180 Hose clamp 1 7129952107
181 Pipe 1 16131178821
182 For vehicles with 1
183 without catalytic converter 1
184 Pipe 1 16131178821
185 Fuel hose 1 16121180409
186 For vehicles with 1
187 without catalytic converter 1
188 Fuel hose 1 16121180409
189 Hose clamp 1 7129952104
190 For vehicles with 1
191 without catalytic converter 1
192 Hose clamp 1 7129952104
193 Pipe 1 16131178475
194 For vehicles with 1
195 without catalytic converter 1
196 Pipe 1 16131178475
197 END PIECE 1 16131177514
198 For vehicles with 1
199 without catalytic converter 1
200 END PIECE 1 16131177514
201 Cover 1 16131179011
202 For vehicles with 1
203 without catalytic converter 1
204 Cover 1 16131179011
205 Plastic nut 1 16131176747
206 For vehicles with 1
207 without catalytic converter 1
208 Plastic nut 1 16131176747
209 Repair cable ABS 1 61131390540
210 only in conjunction with 1
211 CONTACT SOCKET 1 61131357705
Zorba
Postby Zorba » Thu 19. Dec 2013 17:57
SteiniDJ wrote:An interesting way to post content without posting any content. We're starved for news on this car, and have been for the last year or so. :argh: I don't know about any other member here, but I'm way too far behind on my Europameister dose.
News coming soon.....
Here is a teaser:
Sand blasting on its way finally!!!!
Zorba
Postby Zorba » Thu 19. Dec 2013 18:03
:lol: Xmass pack 2 of 3 half way ready.....
Zorba
Postby jens » Thu 19. Dec 2013 19:33
:thup: :woow:
Postby fart » Thu 19. Dec 2013 19:43
Hahahaha god-damn!
Postby Yellow » Thu 19. Dec 2013 23:19
8) 8) 8) 8) 8) 8) 8) 8) 8) 8) 8) 8) 8) 8) 8) 8) 8) 8) 8) 8) 8) 8)
This restoration is amazing :twisted:
I look forward to see the E30 M3 when it's complete in the future :thup: :thup: :thup: :thup: :thup:
1997 BMW E39 523iA [NS-013]
Yellow
Postby Mazi! » Fri 20. Dec 2013 00:57
:shock:
Postby Zorba » Sat 21. Dec 2013 15:52
Operation STRIPPER begins:
Powder blasting to have these ready for glass blast and paint!!!
Can any of you guys confirm if E28 front wheel bearing fit the M3? Any part numbers maybe?
Zorba
Postby bimmer » Sat 21. Dec 2013 16:10
Zorba wrote:Operation STRIPPER begins:
Your'e liking this operation aren´t you??!?!?!?
Postby Zorba » Sat 21. Dec 2013 16:28
I never say no to some good stripping!!!!!
Zorba
Postby Zorba » Tue 31. Dec 2013 19:05
Operation Stripper still in progress:
Some before and after shot:
Spindles are cleaned to be send over for a beauty/enhancement operation.
Hopefully when they come back they will look like this (Plus some H&R springs:
Zorba
Postby Angelic0- » Tue 31. Dec 2013 21:34
Just buy an Öhlins coilover set..
Postby Zorba » Tue 31. Dec 2013 22:32
Angelic0- wrote:Just buy an Öhlins coilover set..
That will be at stage 3......lol
And to be honest this is not a track car to justify the cost:
BTW, Checked Ohlins prices :
OHLINS SUSPENSION KIT DOUBLE ADJ.
Code: LR-OHLINS-xxx-2
Price: $4,499.00
I think for a street car the maximum would be AST 4200 or TC KLINE.
I was going for KW but got bad feedback on their service.....
The above kit is designed for E30 with main use on Street. The inserts are custom Konis (most companies use Koni anyway) and have been getting really good reviews. For the money i think they are great!
Zorba
Postby Angelic0- » Wed 01. Jan 2014 19:02
I clearly forgot to put the :lol: smiley behind my last statement :)
But this restoration is amazing, i am looking forward to the results...
Not a big E30 fan, and the E30 M3 doesn't really do anything for me either, besides being the symbol that it was at it's time...
I have also looked into a set of AST, reviews are good and their customer service is supposedly very good...
KW seem to be lacking in service and also have a increase in defective parts over the last years...
Postby Alpina » Wed 01. Jan 2014 19:08
Angelic0- wrote:I clearly forgot to put the :lol: smiley behind my last statement :)
Put your peni5 in to a Holset 55
Users browsing this forum: No registered users and 106 guests
