Vantar felgur
Vantar felgur
Postby haukure46 » Mon 12. Feb 2007 15:46
hæ er nýr í þessu og mér vantar felgur undir e46 99" 17" EÐA 18" meiga vera smá laskaðar og helst djúpar væri frábært að fá myndir líka sendið bara á email-ið mitt um info vantar gegjað fyrir sumarið :)
haukure46
Re: Vantar felgur
Postby mattiorn » Mon 12. Feb 2007 15:52
haukure46 wrote:hæ er nýr í þessu og mér vantar felgur undir e46 99" 17" EÐA 18" meiga vera smá laskaðar og helst djúpar væri frábært að fá myndir líka sendið bara á email-ið mitt um info vantar gegjað fyrir sumarið :)
mattiorn
Postby saemi » Mon 12. Feb 2007 16:32
Er með þessar felgur. 18x8.5 Konig Imagine, kemur undan E46 M3
Seljast með nýjum dekkjum.
170.000.-
smu@islandia.is/699-2268
The Sumitomo HTRZ II is an Ultra High Performance Summer radial designed to blend appearance, performance and comfort. This combination makes the HTRZ II appropriate for many of today's sporty cars because it provides a unique look with a size lineup of 17" and 18" rim diameter "Plus Two" and "Plus Three" fitments. Like all summer tires, the HTRZ II is not intended to be driven in near-freezing temperatures, through snow or on ice.
On the outside the HTRZ II's tread pattern features extra wide, arched tread blocks to enhance dry road traction and handling. The blocks vary in size and shape to help minimize noise levels and are separated by Multi Direction Water Channels to help increase wet traction and resist hydroplaning. On the inside the HTRZ II features two steel belts with spirally-wrapped Jointless Nylon Band reinforcement for high-speed durability and predictable handling while minimizing weight and improving ride uniformity. The lower sidewall features Single Strand Beads for improved wheel fit and Wheel Flange Guards to help protect alloy wheels from curb damage.
