Smá Top Fuel fróðleikur
Postby bimmer » Thu 02. Jun 2011 01:23
Under full throttle, a dragster engine consumes 1 1/2 gallons of nitro per second
With nearly 3000 CFM of air being rammed in by the supercharger on overdrive, the fuel mixture is compressed into nearly- solid form before ignition. Cylinders run on the verge of hydraulic lock.
Dual magnetos apply 44 amps to each spark plug
Spark plug electrodes are totally consumed during a pass. After 1/2 way, the engine is dieseling from compression-plus the glow of exhaust valves at 1400 degrees F. The engine can only be shut down by cutting of it's fuel flow.
Dragsters twist the crank (torsionally) so far (20 degrees in the big end of the track) that sometimes cam lobes are ground offset from front to rear to re-phase the valve timing somewhere closer to synchronization with the pistons.
Top Fuel Engines ONLY turn 540 revolutions from light to light!
that the fuel-line pressure for NHRA Top Fuel dragsters and Funny Cars is between 400 and 500 psi
It takes 800bhp to turn the supercharger at full power it produces 45psi of boost
Top fuelers run approximately 7,414bhp / ton
The exhuast exits the headers at speeds over Mach 1, the exhaust actually provide downforce as well as forward THRUST
A top fuel car at full throttle can be heard from over 8 miles away measuring 150db
Video:
Sá sneggsti:
Injector demo :shock: :
Re: Smá Top Fuel fróðleikur
Postby Haffi » Thu 02. Jun 2011 01:48
haha! shit hvað ég mun aldrei kvarta undan eyðslu aftur eftir að hafa séð þetta video :lol:
Haffi W. Schnurrenberger.
Haffi
Postby ppp » Thu 02. Jun 2011 13:01
Shit. Ég varð bara hræddur þegar injectorinn fór á fullt.
Góður póstur.
330d e46 (Mr. X!)
ppp
Postby BMW_Owner » Thu 02. Jun 2011 13:45
holy hell.. það er video á youtube þar sem dragster með svona tekur míluna..... 3.7sek :D hahaha
BMW 528Ia
BMW_Owner
Postby Alpina » Fri 03. Jun 2011 14:57
BMW_Owner wrote:holy hell.. það er video á youtube þar sem dragster með svona tekur míluna..... 3.7sek :D hahaha
Þetta eru 1000 fet,,, flest ofur run hjá dröggum eru 1000 fet í dag
Hérna er smá fróðleikur fyrir .......... GUST
@MrGotsquashed I'm glad I was there to see the national record set even though 1000ft Top Fuel has gone as quick as 3.75. The engine of choice for Top Fuel and Funny Car for 40+years has been an all aluminum aftermarket Dodge 426 Hemi which is bored and stroked to 500 cubic inches.
NitroAmerica 2 months ago
@NitroAmerica So, the Chevrolet, Toyota, and Ford FCs/ TFs all have Mopars?
MrGotsquashed 2 months ago
TWINCAM/fjölventla hvað :lol: :lol: :lol:
@MrGotsquashed Yes, they all run aftermarket aluminum 426-style Hemis
