Stórsniðugur lykill
Stórsniðugur lykill
Postby SteiniDJ » Sun 24. May 2009 18:47
!!Hydrokinetic Adjustable Wrench!!
Image Sniðugur lykill sem notar smá vökvadælu til að stilla stærðina að næstum hvaða bolta sem er.
Zoom
More Images
Adjusts to the job
Doctor Who has his sonic screwdriver - a small tool that can adjust to any situation. It uses advancements in technology to provide an infinitely adaptable tool. While the Hydrokinetic Adjustable Wrench won't let you start up your TARDIS, it will let you fiddle with twenty three different sizes of bolts and nuts. And the secret resides in wrench's liquid core. Take a look at the little computer graphic cut-away, and you'll know what we mean.
To adjust the Hydrokinetic Adjustable Wrench, just open the valve, fit around the nut or bolt of your choice, and push the gripper on the opposite end. It will compress the liquid which will, in turn, push the gripper on the end you want. Once it is snug against the nut, close the valve and your Hydrokinetic Adjustable Wrench is locked into position. It's that easy! The slim heads of the wrench will let you sneak it into tight spaces, and the design of the grip will help you turn even damaged nuts and bolts. Once you get your Hydrokinetic Adjustable Wrench in your hands, you will instantly know its power - that it looks like something from Doctor Who or Star Trek doesn't hurt either!
* Patented, liquid-core technology allows this wrench to adjust to fit almost any nut or bolt.
* Easily adjusts to 23 different sizes (metric and standard).
* Slim, ergonomic design allows the wrench to fit into hard to reach areas.
* Great for removing even damaged nuts and bolts.
* Made of nickel plated, cold forged steel.
* Dimensions: 7.5" long
Bara benda ykkur á þetta! :)
Re: Stórsniðugur lykill
Postby Astijons » Sun 24. May 2009 18:53
metric and standard...
REY/&"#$! :lol:
þetta er samt mega töff
Astijons
Postby slapi » Sun 24. May 2009 18:58
Æj veit það ekki , myndi líða betur með settið mitt.
Postby gunnar » Sun 24. May 2009 19:41
Er þetta ekki frekar stórt líka?
Lendi nú ansi oft í því að fasta lyklasettið mitt er nú of stórt í margar æfingarnar.. Hvað þá einhver Robocop 5000 skiptilykill :lol: :lol:
Postby Grétar G. » Sun 24. May 2009 20:54
slapi wrote:Æj veit það ekki , myndi líða betur með settið mitt.
Sammála en samt mega sniðugt
E30 M20B25 TÚRBÓ
E36 ///M3 Daytona Violet
E65 735i LOADED
Yamaha YZF R6 '07
Grétar G.
Postby Zed III » Mon 25. May 2009 17:34
þetta væri flott í skottið, svona just in case...
Benedikt Guðmunds. 615-2630
Zed III
