Ford með Koenigsegg vél
Postby Maddi.. » Fri 08. May 2009 19:21
Maddi..
Re: Ford með Koenigsegg vél
Postby dabbiso0 » Fri 08. May 2009 20:09
Þetta á eftir að vera með því bilaðasta.
Hvað á hann samt eftir að vera að gera á þessu? þetta reykir bara dekkin uppí 250km/klst eða eitthvað
The engine can produce well over 2000hp,(it wll give about 2300hp at 2.4bar boost) but turbos is its only limitation , they can produce 1750hp at the maximum in teory , so we'll se how well they hang in there.
As it is now it produces 170hp at idle, 290hp at 2000rpm... and after that the turbos really kick in... so there is always enough power...!
Totally off bost, it produces somwhere between 550-600hp if everything continues as planned.
VÁ hvað þetta er bilað
dabbiso0
Postby ValliB » Fri 08. May 2009 20:52
Þessi hlýtur að hafa sloppið af einhverri geðdeild, því þetta er geðveiki :shock:
bmw3
ValliB
Postby jeppakall » Fri 08. May 2009 23:12
Þetta er -------SICK------ :shock: :shock: :shock: :shock: :shock:
jeppakall
Postby Jón Ragnar » Fri 08. May 2009 23:13
Er þetta ekki mustang mótor?
:edit:
Engine will be based on a heavily reinforced twin turbo charged koeniggsegg ccx engine.
Postby jeppakall » Fri 08. May 2009 23:17
John Rogers wrote:Er þetta ekki mustang mótor?
:edit:
Hún er bara til að máta
jeppakall
Postby Jón Ragnar » Fri 08. May 2009 23:19
Sjáðu síðustu myndinar,, mustanglegt eitthvað..
hann byggir bara mótorinn upp frá CCX mótornum eða eitthvað
Postby Aron Fridrik » Sat 09. May 2009 04:08
Koenigsegg notuðu ford mótora áður fyrr
Postby gardara » Sat 09. May 2009 17:37
██ 1974 BMW 1802
██ 1994 BMW E36 332i sedan
██ 2008 BMW E92 335i
██ 2013 BMW F30 320d
Postby Kjallin » Sat 09. May 2009 18:17
John Rogers wrote:Sjáðu síðustu myndinar,, mustanglegt eitthvað..
No you can't, and the koneiggegg engine is not up for our power levels, so that's why we only use its special block, wich is very good.
The engine of this car is based on the 32 v 4.6 mustang engine, though 4.7 liters in the 'egg , and 5.0 litres in ours due to larger diameter liners, erm...and pistons obviously.. ;-P
Kjallin
Postby Maddi.. » Sat 09. May 2009 18:20
Hef greinilega ekki lesið þráðinn nógu vel, myndirnar tóku allan áhugann frá textanum. :P
Engu að síður alveg virkilega magnað project!
Maddi..
