Bónval Nýr opnunartími ofl.......!!!!!!
Postby camaro F1 » Mon 25. Aug 2008 22:49
Nýr opnunartími Bónvals
Mánudaga-Föstudaga frá kl. 16.00-19.00
og Laugardaga frá kl. 11.00-14.00
Vorum að fá inn sendingu af Einszett......
fullt af fínu dóti, m.a. Míkró-fíber klútana sem seldust hratt upp í sumar, einnig Anti-insect (pödduleysir) sá allra besti á markaðnum, einnig trjákvoðu hreinsir.
Og svo auðvitað fullt af hinu geysivinsæla Deitail-Sprayi
her er smá lesning um það:
"Clean, shine, and protect with Eeinszett’s cutting edge polymer formula.
1Z Einszett Detail Spray ‘Lackfinish’ restores a just-waxed finish in just minutes! Using state-of-the-art German polymer technology, 1Z Einszett Detail Spray ‘Lackfinish’ adds durability and shine any time it’s needed. Spray it over the existing wax to see an instant improvement in gloss, and a long-term improvement in paint protection.
Enjoy an exceptional gloss anywhere, any time! 1Z Einszett Detail Spray ‘Lackfinish’ cleans and protects paintwork between washings with a dust-repellant polymer formula. The polymers bond to the existing wax to boost protection, slickness, and gloss. By reducing surface tension, 1Z Einszett Detail Spray ‘Lackfinish’ repels dust and keeps your vehicle cleaner longer.
Use 1Z Einszett Detail Spray ‘Lackfinish’ as a gentle quick detailer. The slick formula safely lifts light dirt and dust, fingerprints, smudges, soot, and bird droppings, without scratching. For the best results, use a microfiber towel with a deep, plush nap.
1Z Einszett Detail Spray ‘Lackfinish’ is a multi-surface instant detailer. Use it on paint, including clear coats, glass, chrome and other metals, and plastics. The safe and gentle formula will remove light contamination while imparting a lasting, protective coat of polymers.
For the best results, use 1Z Einszett Detail Spray ‘Lackfinish’ over 1Z Einzett Glanz Wax (pearls-shampoo). The 1Z Einszett Detail Spray ‘Lackfinish’ will restore the shine of Glanz Wax between details, and it will not remove or cloud the wax. The two products work hand in hand to give your vehicle a dazzling shine and excellent protection
Use 1Z Einszett Detail Spray ‘Lackfinish’ any time your vehicle seems to be losing its luster or water is not beading as well. 1Z Einszett Detail Spray ‘Lackfinish’ will restore maximum gloss and water repellency in just minutes. Mist the paint and gently wipe with a Microfiber Towel. Work from the top of the vehicle, down. The lower panels are the dirtiest and should always be detailed last to avoid cross contamination.
For instant gratification and lasting protection, use 1Z Einszett Detail Spray ‘Lackfinish’ any time to restore your vehicle’s gloss."
Endilega kíkið við hjá okkur í Bónval Súðavoi 32
s5576460
sendum einnig út á land
camaro F1
Postby SteiniDJ » Mon 25. Aug 2008 23:41
Leiðindar opnunartími á virkum dögum. :( En þið eruð nú ein af mjög fáum alvöru "bónbúðum" á íslandi, ætlið þið að fara stækka lagerinn ykkar eitthvað meira? Eins og t.d. með alvöru verkfærum og þannig?
Bara spá :)
Re: Bónval Nýr opnunartími ofl.......!!!!!!
Postby camaro F1 » Fri 29. Aug 2008 20:12
MUNIÐ OPIÐ LAUGARDAG FRA KL 11-14
FULLT AF FLOTTUM VÖRUM KOMNAR
camaro F1
