mis góð húsráð
mis góð húsráð
Postby Bjarkih » Wed 09. Apr 2008 17:29
1. If you're choking on an ice cube, simply pour a cup of boiling water down your throat. Presto! The blockage will instantly remove itself.
2. Avoid cutting yourself when slicing vegetables by getting someone else to hold the vegetables while you chop.
3. Avoid arguments with your wife/girlfriend about putting down the toilet seat -- use the sink instead.
4. For high blood pressure sufferers, simply cut yourself and bleed for a few minutes, thus reducing the pressure on your veins. Remember to use a timer.
5. A mouse trap placed on top of your alarm clock will prevent you from rolling over and going back to sleep after you hit the snooze button.
6. If you have a bad cough, take a large dose of laxatives -- then you'll be afraid to cough.
7. You only need two tools in life: WD-40 and duct tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape.
8. Have a bad toothache? Smash your thumb with a hammer and you will forget all about the toothache.
Bjarki Hilmarsson
E34 520iA '90 --seldur--
Bjarkih
Postby iar » Wed 09. Apr 2008 18:07
Frábær húsráð!!
Sérstaklega nr. 6 :rofl:
Postby Kristjan » Wed 09. Apr 2008 18:12
Postby SteiniDJ » Wed 09. Apr 2008 23:52
Snilld :lol:
Postby Axel Jóhann » Thu 10. Apr 2008 00:44
Hehehe snilld.
