Bíladagaplan.
Bíladagaplan.
Postby JonFreyr » Tue 29. May 2007 19:51
Finnst alveg í lagi að taka allavega tvennt af listanum og framkvæma :lol:
1. Hot Lunch - While receiving head from a woman, (her, on her back, you straddle her chest) you proceed to shit on her chest--just for the hell of it. She then becomes the "Lunch Lady."
2. The Stranger - Sitting on your hand until it falls asleep and then jerking off, eliciting the feeling of a hand job from someone else.
3. Donkey Punch - Banging a girl doggy style and then moments before you cum, sticking your dick in her ass, and then punching her in the back of the head. This should give you a tremendous sensation, but for it to work correctly, the girl must be knocked out so that her asshole tightens up.
4. Golden Shower - Any form of dropping piss all over a girl.
5. Pearl Necklace - Whenever you cum on the neck area of a girl - it takes on the look of beautiful jewelry.
6. Coyote - This occurs when you wake up in the room of a nasty woman and you know you've got to give her the slip. However, you realize that your arm is wrapped around her. Therefore you must gnaw off your own arm to get out of the situation. Can be very painful.
7. Purple Mushroom - This occurs when a woman is giving you oral sex and you pull your penis back slightly before poking it back into the inside of her cheek. It should leave a lasting impression similar to that of a purple mushroom.
8. The Flying Camel - As she is lying on her back and you are hammering her from your knees, you carefully balance yourself without using your arms to prop yourself up. You then proceed to flap your arms and let out a long, shrieking howl, much like you would imagine a flying camel to sound like. Strictly a class move.
9. Fishhook - A variation of "The Shocker" (an uninvited digit placed in the girl's anus ) in which, with the finger still up there, you "hook" back in the direction the pussy. No real purpose here other than to think to yourself while doing it, "ahhh yes the Fishhook......". Another variation called the "New Jersey Meathook" involves sticking your uninvited digit in the girl's anus while fucking her from behind. You finger is then turned upward toward her back and you pull her entire body toward you over and over while she is sliding on your cock.
10. The Ram - Again, you're attacking from behind, when you start ramming her head against the wall in a rhythmic motion. The force of the wall should allow for deeper penetration. Very handy for those lulls in penile sensitivity.
11. Dog in a Bathtub - This is a proper name for when you attempt to insert your nuts into a girl's ass. It is so named because it can be just as hard as keeping a dog in the tub while giving it a bath.
12. Felching - It occurs after you have been sticking your babe in the can, you bust your nut in there, back up and then pucker your lips up to her rim and suck out your ranch dressing. (This is also the first step of a very advanced maneuver called the Halmstad Hook).
13. Tossing Salad - One person simply chows box or asshole with the help of whatever condiments are available, i.e. lettuce, tomatoes, croutons, vinegar and oil, etc.
14. The Bronco - Back to reality with this classic. You start by going doggy style and then just when she is really enjoying it, you grab her tits and or a large lock of hair as tight as possible and yell another girl's name or state "Ya know your by far the ugliest girl I ever fucked". This gives you the feeling of riding a bronco as she tries to buck you off.
15. Pink glove - This frequently happens during a marathon session (maybe a second round) when a girl is simply not wet enough. When you give up and attempt to pull out to give her money or whatever, the inside of her twatsticks to your hog like the inside of a leather glove. Thus, the pink glove
16. The Fountain of You - While sitting on her face and having her eat your ass, jerk off like a madman. Build up as much pressure as possible before releasing. Then spew like a venerable geyser all over her face, neck and its. (Better in her bed). This is also a variation of the first stage of a Cleveland Steamer to be described later.
17. New York Style Taco - (Also known as a wet Betsy) - Anytime when you are so drunk that when you go down, you boot on her box. All the fixin's.
18. The Durty Sanchez - A time honored event in which while laying the bone doggie style, you insert your finger into said woman's asshole, pull it out, and wipe it across her upper lip leaving a thin, shit moustache. This makes her look like someone whose name could be Dirty Sanchez. A very popular European variation of this maneuver called "The Hitler" involves a simple shit smudge under her nose, replicating the look of Hitler's mustache.
19. The Fish Eye - From behind, you shove your finger in her ass, thereupon she turns around in a one-eyed winking motion to see what the hell you are doing. At that point, you have received a "Fish Eye."
20. Tuna Melt - Lights out, you're down on a chick lapping away at an unusually juicy slab when you discover that it just happens to be the time of the month. A man of honor, by no means do you stop. When the whale spews, tartar sauce with a hint of raspberry smothers your face. (this only work with chicks who REALLY cum hard).
21. Pole Vault - Originated by ancient Romans. When the female has sucked your pole to the point of ejaculation she swiftly inserts the index finger of her right hand into your anus. This surprise causes a subtle popping out of the eyes, a natural arch to the lower back and extra propulsion necessary to clear the high bar. Bruce Jenner added this to his warm-up routine after losing to Sergie Bubka in the 1979 Olympics.
22. Furr Ball - You're chomping away at some mighty trollop who has a mane between her legs the size of Lionel Richie's afro, you don't mind though, that is until a mammoth furr ball gets lodged in your throat and causes you to beat the piss out of her.
23. The Chili Dog - You take a shit on a girl's tits and then proceed to titty fuck her.
24. A Hot Carl - A simple maneuver where you withdraw your shaft from the bowels of her anus and place it directly into her mouth for a cleaning. Apparently some guy named Carl first tried this.
25. The Cleveland Steamer - Mentioned above in #16. After dumping your load on and around her chest--you position your ass just above your own pool of soup and sit in it, full weight, possibly causing her to gasp for breath. You then pretend to be pulling the whistle cord on a genuine Cleveland steam ship. As you make the loud noise you slide in your spunk from her chest to her bush smearing a spunk trail on her body in your wake. This can be done with the male facing either direction. The more authentic the steam whistle sound, the better.
26. The Halmstad Hook - As mentioned above in #12. This is a unique sequence of events named after a town in Sweden, where this apparently happens quite frequently. After dumping your spunk in her rear, the sauce is sucked out of the anus by the male. Once the sauce has transferred from her bowls to your mouth--the product that has been created is now known as "Swedish Cheese." The move is completed when the "Swedish Cheese" is transferred to the ladies mouth via a deep tongue kiss. You can cap this off with a swift stinging slap of her ass to show her how much you care and appreciate all her hard work.
27. Rapp-N-Poke - It's sat. night in the hood and you're lookin to stuff the Ho of the week. After the bitches 9 juveniles hit the streets for their evening violence,you stroll up in you're beat-up Cadillac an
hour late with two quarts of mad dog to set the mood. Don't forget to stop along the way to sell a glock and two rocks of crack to some under aged criminals. Now start the evening by yelling,"come here you
black bitch and suck my meat" Dip your oversized nigger-cock into some Kool-Aid and stuff it between her dishlipps. Constantly beat her like the slave that she is and pound your fist into that bubble ass. Now whack off into a bucket of extra crispy and put it over her head so she can't see the watermelon that you're about to volley off of her thick skull. After you shoot her, go to the porch, sit down, and don't work for the rest of your life.
Volvo 945 Túúúúúrbó
JonFreyr
Postby Omar » Tue 29. May 2007 20:36
hver kannast ekki við ..."ahhh yes the Fishhook......" :naughty:
Omar
Postby Eggert » Wed 30. May 2007 01:09
:shock:
E53 X5 4.4i
Eggert
Postby KristjánBMW » Wed 30. May 2007 13:14
BARA SNILLD!!!!!
You Never Know What You Have Until You Lose It.
Nissan Almera 99' Til Sölu.
KristjánBMW
Postby Angelic0- » Wed 30. May 2007 13:26
Hver kannast ekki við Hot Carl.... :lol:
Postby saemi » Wed 30. May 2007 22:04
Væri ekki nærri lagi að endurskíra þennan þráð og merkja hann 18+
Ég er ekki á því að þetta sé það sem stendur til að gera á bíladögum. Finnst þetta frekar óviðeigandi.
Users browsing this forum: Google [Bot] and 39 guests
