Viðgerðarskýrslur (brandari)
Postby Bjarkih » Wed 10. Jan 2007 11:56
Held að þetta sé hundgamalt, en þetta er alltaf jafn fyndið.
After every flight, Quantas pilots fill out a form, called a "gripe sheet," which tells mechanics about problems with the aircraft. The mechanics correct the problems, document their repairs on the form, then
the pilots review the gripe sheets right before the next flight. Never let it be said that ground crews lack a sense of humor.
Here are some of the actual maintenance complaints submitted by the Qantas' pilots (as marked with a P) and the solutions recorded (as marked with an S) by the maintenance engineers.
By the way, it is relevant to note that Qantas is the only major airline in the world that has never, ever, had an accident!
P: Left inside main tire almost needs replacement.
S: Almost replaced left inside main tire.
P: Test flight OK, except auto-land very rough.
S: Auto-land not installed on this aircraft.
P: Something loose in the cockpit.
S: Something tightened in the cockpit.
P: Dead bugs on windshield.
S: Live bugs on backorder.
P: Autopilot in altitude-hold mode produces a 200 feet per minute descent.
S: Cannot reproduce problem on ground.
P: Evidence of a leak on the right main landing gear.
S: Evidence removed.
P: DME volume unbelievably loud.
S: DME volume reset to a more believable level.
P: Friction locks cause throttle levers to stick.
S: That's what friction locks are for.
P: IFF inoperative in OFF mode.
S: IFF always inoperative in OFF mode.
P: Suspected crack in windshield.
S: Suspect you're right.
P: The number 3 engine is missing.
S: Engine found on right wing after a brief search.
P: Aircraft handles funny. (I love this one!)
S: Aircraft warned to straighten up, fly right and be serious.
P: Target radar hums.
S: Reprogrammed target radar with lyrics.
P: Mouse in cockpit.
S: Cat installed.
And the best one saved for last......
P: Noise coming from under the instrument panel. Sounds like a midget
pounding on something with a hammer.
S: Took hammer away from the midget. After every flight, Quantas pilots fill out a form, called a "gripe sheet," which tells mechanics about problems with the aircraft. The mechanics correct the problems, document their repairs on the form, then
S: Cat installed.
Bjarki Hilmarsson
E34 520iA '90 --seldur--
Bjarkih
Postby íbbi_ » Wed 10. Jan 2007 12:04
hei hei hei eg má!! :repost: :naughty:
Postby Stanky » Wed 10. Jan 2007 12:07
Þetta er samt alveg fyndið!
:D
Stanky
Postby siggir » Wed 10. Jan 2007 13:01
Ég held ég hafi hlegið alveg jafn mikið af þessu og síðast :lol:
Sigurður Rúnar Rúnarsson
No guts, no glory
siggir
Postby Haffi » Wed 10. Jan 2007 13:04
LEGENDARY !!
Haffi W. Schnurrenberger.
Haffi
Postby Kristjan » Wed 10. Jan 2007 13:35
Ég held að Bjarkih sé að reposta sjálfan sig....
Postby Bjarkih » Wed 10. Jan 2007 13:38
Kristjan wrote:Ég held að Bjarkih sé að reposta sjálfan sig....
Er mynnið hjá mér orðið svona lélegt :oops: :oops: :oops:
http://www.bmwkraftur.is/spjall/viewtopic.php?t=10399&start=0&postdays=0&postorder=asc&highlight=quantas
Bjarki Hilmarsson
Bjarkih
Postby ///M » Wed 10. Jan 2007 13:43
Haffi wrote:LEGENDARY !!
legend-ARY
2016 BMW X3 sDrive28i
///M
Postby arnibjorn » Wed 10. Jan 2007 13:53
Þetta er ógeðslega fyndið! Ég hló eins og einhver hálfviti hérna á bókasafninu í skólanum :lol: :lol:
Postby Hannsi » Wed 10. Jan 2007 14:15
Sæmi ætti að þekkja þetta :lol:
Hannsi
Users browsing this forum: Google [Bot] and 20 guests
