Flugvélaviðhalds djók
Postby Bjarkih » Thu 05. May 2005 20:56
Tekið af http://www.jumbojoke.com/
I'm not sure about the "actual" bit, since it has been attributed to the U.S. Air Force, United Airlines, Quantas Airlines, and more.
Here are some actual logged maintenance complaints and responses:
P = the problem logged by the pilot.
S = the solution and action taken by engineers.
P: Left inside main tire almost needs replacement.
S: Almost replaced left inside main tire.
P: Test flight OK, except auto-land very rough.
S: Auto-land not installed on this aircraft.
P: Something loose in cockpit.
S: Something tightened in cockpit.
P: Dead bugs on windshield.
S: Live bugs on back-order.
P: Autopilot in altitude-hold mode produces a 200 feet per minute descent.
S: Cannot reproduce problem on ground.
P: Evidence of leak on right main landing gear.
S: Evidence removed.
P: DME volume unbelievably loud.
S: DME volume set to more believable level.
P: Friction locks cause throttle levers to stick.
S: That's what they're there for.
P: IFF inoperative.
S: IFF always inoperative in OFF mode.
P: Suspected crack in windshield.
S: Suspect you're right.
P: Number 3 engine missing.
S: Engine found on right wing after brief search.
P: Aircraft handles funny.
S: Aircraft warned to straighten up, fly right and be serious.
P: Target radar hums.
S: Reprogrammed target radar with lyrics.
P: Mouse in cockpit.
S: Cat installed
Bjarki Hilmarsson
E34 520iA '90 --seldur--
Bjarkih
Postby BirkirG » Thu 05. May 2005 21:15
Bwahahahahahaha
BirkirG
Postby arnib » Thu 05. May 2005 22:51
hehehe
Þessi listi er ansi góður.
Sérstaklega kitlar þetta alltaf:
BMW E46 328i
arnib
Postby Jss » Thu 05. May 2005 23:41
Þvílík snilld. :rofl:
Jóhann
Jss
Postby Haffi » Fri 06. May 2005 00:03
rofl þvílík snilld :D
Haffi W. Schnurrenberger.
Haffi
Postby Schnitzerinn » Fri 06. May 2005 11:49
Veit ekki með ykkur, en ég myndi ekki treysta mér að fljúga með þessu flugfélagi :lol:
Dóri
Image BMW 525i e34 '91 [SELDUR]
Image Opel Vectra CD 2.0 '97[Í notkun]
Schnitzerinn
Postby Einsii » Fri 06. May 2005 12:35
:rollinglaugh: :rollinglaugh: :rollinglaugh: :rollinglaugh: :rollinglaugh: :rollinglaugh: :rollinglaugh: :rollinglaugh: :rollinglaugh: :rollinglaugh: :rollinglaugh: :rollinglaugh: :rollinglaugh: :rollinglaugh: :rollinglaugh: :rollinglaugh: :rollinglaugh: :rollinglaugh: :rollinglaugh: :rollinglaugh: :rollinglaugh: :rollinglaugh:
Gekk frekar brösulega með cocoa puffs'ið þegar ég las þetta :D
Einsii
Postby bebecar » Fri 06. May 2005 16:36
Sko.. maður trúir svona svörum alveg - stundum getur maður bara ekki látið það vera að svara asnalegum kommentum á "réttan" hátt :lol:
