Nýji "Skyline-inn" ---> R35 GT-R
Postby Aron Fridrik » Sun 18. Nov 2007 11:37
bjornvil wrote:
Wikipedia wrote:Balance and smoothness
Straight-6 four-stroke cycle engines are in perfect primary and secondary balance and require no balance shaft. They are in primary balance because the two ends of the engines are mirror images of each other and the cylinders move up and down in pairs, one on the compression stroke and the other on the exhaust stroke. Piston #1 balances #6, #2 balances #5, and #3 balances #4, canceling the end-to-end rocking motion that would otherwise result. (This does not apply to two-stroke cycle engines.) Secondary imbalance occurs in straight-4 engines because the two pistons on the upper 180 degrees of the crankshaft rotation move faster than the two pistons on the lower 180 degrees, creating an unequal motion. Straight-6 engines have cranks at 120 degrees to each other, so the differences in speed on different parts of the crankshaft rotation are offset by the changing number of pistons on each portion.
The straight-6 is smoother than engines with a fewer number of cylinders because the power strokes of pistons partially overlap. Since each power stroke lasts 180 degrees of crankshaft rotation, while a new piston starts its power stroke every 120 degrees, there are 60 degrees of overlap on each stroke in which one piston is finishing while the next is starting. This results in a smooth delivery of power, unlike a four cylinder engine in which each piston must come to a complete stop before the next piston commences its power stroke. This makes the straight-6 engine's delivery of power much smoother than a four-cylinder engine. The fact that there are basically two straight sixes on the same crankshaft is the reason why 60 degree and 180 degree V12 engines are considered optimal for smooth power delivery; they allow for triple overlap of the power stroke between three cylinders at all times due to the overlap from their two component straight-6 banks. Eight cylinder engines have even more power stroke overlap than six cylinder ones, but the improvement in smoothness is not as pronounced as that of sixes over fours.
http://en.wikipedia.org/wiki/I6
Ætli að þetta sé ekki ástæðan fyrir því að bmw valdi I6
Postby íbbi_ » Mon 19. Nov 2007 09:28
L6 er eitt af bestu ballanceruðu vélarformum sem hefur verið notað, en það er alveg rétt sem gunni segir, hún er samt ekki mjög hentug, lengdin á henni krefst mikils vélarýmis á mikla þyngd yfirleitt fyrir framan framöxul, V-lag á vél minkar plássið svo mikið auk þess sem það er hægt að færa vélina neðarlega,
V6 vélar eru öruglega ó-plássfrekustu vélar m/a við stærð sem eru í boði.
ég hef samtaldrei verið mikill V6 maður... finnst þær yfirleitt hljóma leiðinlega og svo framvegis.. benz færðu sig yfir í v6 úr l6 fyrir 10 árum og virðast flestir hafa fylgd því á endanum
samt fátt sem toppar vel heita N/A 6cyl línu á öskrinu
Postby íbbi_ » Mon 19. Nov 2007 09:36
ég las ekki seinni blaðsíðurnar hérna áður en ég póstaði fyrra svari,
ólíkt venjulega þá er ég alveg sammála gunna í flestum atriðum hérna,
það er eitt alveg á hreinu, að í bifvélavirkjun og í vinnu sem bifvélavirkji læriru ekkert um hestöfl per liter og upsetningar bíls performance vise, enda ekki hlutverk bifvélavirkja að smíða bílin, bara laga hann,
varðandi amerískar vélar, þá verður að segjast að sumar þeirra séu mjög góðar, yfirleitt eru amerískar vélar mjög sterkar.. eða mjög oft þ.e.a.s t.d eru menn að ná allt að 500hö útúr 2.4l srt4 vélini frá mopar, á orginal kjallara án teljandi vandræða,
ls-x vélarnar frá gm finnst mér snilld, menn hafa verið að ná úr þeim 100hö/liter N/A heima í skúrnum hjá sér, á vél með 2v per cyl.. kambásin inní miðri blokk og undirlyftu stangir, og með orginal ls1 geturu náð hátt í 100hö með því einu að skipta um kambás ventlagorma og undirlyftustangir.. i.m.o hefur gamla v8 formið löngu sannað sig sem eitt besta vélarform ever
Postby fart » Mon 19. Nov 2007 09:40
Línu, Vaff, Waff eða whatever.. þá verður þessi bíll MAGNAÐUR
Postby íbbi_ » Mon 19. Nov 2007 10:52
þetta verður megagræja..
Postby Aron Fridrik » Wed 19. Dec 2007 22:43
íbbi_ wrote:þetta verður megagræja..
talandi um það
dyno tölur komnar í hús
482 PS út í hjól.. sirka 475awhp
þessi bíll verður suddalegur..
Users browsing this forum: Google [Bot] and 43 guests
