Postby oddur11 » Wed 13. Apr 2011 20:34
Maggi B wrote:sjáiði ekki að þetta er fake ?
afhverju?? meina þeir í mythbusters náðu að lifta bíl helvíti hátt með nokkrum slöngum og slökvuliðsbílum :D
Mazda 626 '98 R.I.P
BMW e32 730i '93 seldur
BMW e46 318 '99 seldur
BMW e34 525tds seldur
BMW e36 325is
BMW e36 318is seldur
BMW e34 525
oddur11
Postby Stefan325i » Wed 13. Apr 2011 22:35
http://jetlev.com/index.html
http://www.popularmechanics.com/outdoor ... eo-5525115
JETLEV R200 SPECIFICATIONS:
* Jetpack dimensions, with adjustable seat: 38.25”H x 35”W x 21.25-24.25”L (97 cm H x 89 cm W x 54-62 cm L)
* Jetpack dry weight (approx.): 30 lbs (14 kg)
* Maximum Thrust: 500 lbf (2,200 N)
* Thrust-to-weight ratio at takeoff (150-lb / 68 kg pilot): 2.5 : 1
* Boat length: 127 inches (323 cm)
* Boat beam: 48 inches (121 cm)
* Boat height with hatches closed: 27 inches (11 cm)
* Boat weight (dry): 649 lbs (295 kg)
* Engine: 4-stroke cycle marine engine
* Engine HP (approx.): 200 HP at 6,200 RPM
* Engine cooling system: Closed loop cooling with stainless steel internal heat exchanger
* Hose dimensions: 33 ft (10 m) L x 4” (10 cm) diameter
* Flight ceiling (measured at feet level): 28 feet (8.5 m)
* Measured top speed (150-lb or 68 kg pilot, ¼ fuel level): 22 mph (35 km/h)
* Fuel capacity: 26 U.S. gal (100 L)
* Duration at wide open throttle (approx.) 2 hours
* Duration at cruising speed (approx.) 3 hours
E30 S50B32
X5 3,0i ´02
Artic Cat ZR500 ´98
GSTuning
Stefan325i
Postby SteiniDJ » Thu 14. Apr 2011 10:14
Jafn fake og háþrýstidæla, Maggi. ;)
Postby Viggóhelgi » Thu 14. Apr 2011 11:10
SteiniDJ wrote:Jafn fake og háþrýstidæla, Maggi. ;)
búja ! hehe
BMW e60 520d - 2006
Honda Shadow Spirit - 2012
Viggóhelgi
Postby SteiniDJ » Thu 14. Apr 2011 13:46
Einn að reyna að fitta inn!
Postby Mazi! » Thu 14. Apr 2011 14:21
:lol2: :lol2: :lol2: :rofl: :rofl:
Postby Alpina » Thu 14. Apr 2011 14:37
Þetta hlýtur að vera geggjað
Postby SteiniDJ » Thu 14. Apr 2011 19:09
Postby Alpina » Thu 14. Apr 2011 19:25
Þetta er með ólíkindum :shock:
Postby SteiniDJ » Thu 14. Apr 2011 19:39
Alveg! Hér er útgáfa sem er talsvert öðruvísi.
Postby bimmer » Thu 14. Apr 2011 19:41
Postby SteiniDJ » Thu 14. Apr 2011 19:42
Hmmm... fender gap...
Postby SteiniDJ » Thu 14. Apr 2011 20:33
Postby saemi » Thu 14. Apr 2011 21:43
Já... ég sofnaði nú samt :bawl:
Postby GunniClaessen » Thu 14. Apr 2011 23:36
W124 500E
Þetta er stökkbreyttur W124 E500 :roll:
Kia VG
The upcoming Kia VG will share its front-wheel-drive platform with next-generation Hyundai Azera. It will be available with fuel-efficient 2.4L gasoline direct injected -GDI four-cylinder gasoline engine with estimated power of 200 hp and a 3.5L V6 Lambda with 277 horsepower. Kia VG is also rumored to be available with 2.7L V6 and 2.7L LPi engines.
Lamborghini Reventon Roadster
BMW E39 540i '97
BMW E39 520i '02
BMW E39 540i '96
BMW E46 330Ci '00
BMW E46 318i '03
+ aðrir.
GunniClaessen
