Postby Þorsteinnlogi » Wed 27. Oct 2010 20:02
After every flight, Qantas pilots fill out a form, called a "gripe sheet" which tells mechanics about problems with the aircraft. The mechanics correct the problems; document their repairs on the form, and then pilots review the gripe sheets before the next flight.
Never let it be said that ground crews lack a sense of humor. Here are some actual maintenance complaints submitted by Qantas pilots (marked with a P) and the solutions recorded (marked with an S) by maintenance engineers.
By the way, Qantas is the only major airline that has never had an accident.
P: Left inside main tire almost needs replacement.
S: Almost replaced left inside main tire.
P: Test flight OK, except auto-land very rough.
S: Auto-land not installed on this aircraft.
P: Something loose in cockpit.
S: Something tightened in cockpit.
P: Dead bugs on windshield.
S: Live bugs on back-order.
P: Autopilot in altitude-hold mode produces a 200 feet per minute descent.
S: Cannot reproduce problem on ground.
P: Evidence of leak on right main landing gear.
S: Evidence removed.
P: DME volume unbelievably loud.
S: DME volume set to more believable level.
P: Friction locks cause throttle levers to stick.
S: That's what they're for
P: IFF inoperative.
S: IFF always inoperative in OFF mode.
P: Suspected crack in windshield.
S: Suspect you're right.
P: Number 3 engine missing.
S: Engine found on right wing after brief search.
P: Aircraft handles funny. (I love this one!)
S: Aircraft warned to straighten up, fly right, and be serious.
P: Target radar hums.
S: Reprogrammed target radar with lyrics
P: Mouse in cockpit.
S: Cat installed.
And the best one for last.
P: Noise coming from under instrument panel. Sounds like a midget pounding on something with a hammer.
S: Took hammer away from midget.
Þorsteinnlogi
Postby maxel » Wed 27. Oct 2010 20:20
Dannyp wrote:Image
:shock:
Postby Maggi B » Wed 27. Oct 2010 20:23
Er þetta að verða að Ultimate rúnkþræðinum eða
Maggi B
Postby fart » Wed 27. Oct 2010 20:23
:drool: :drool: :drool: shadowline
Postby ///MR HUNG » Wed 27. Oct 2010 20:28
fart wrote::drool: :drool: :drool: shadowline
Nákvæmlega :lol:
My like big time :thup:
///MR HUNG
Postby BirkirB » Wed 27. Oct 2010 23:06
Fender Jazzmaster árg. 1963
E39M5
I4M50
BirkirB
Postby bimmer » Wed 27. Oct 2010 23:49
Þessi gítargarmur er nú ansi mikið anticlimax eftir svartholið.
Postby Alpina » Wed 27. Oct 2010 23:51
Menn eru eflaust endalaust að horfa á entry brautina að slippnum ,,,,,,,, :king: :naughty: :naughty: :naughty:
Postby bimmer » Wed 27. Oct 2010 23:52
Glæsileg skutrenna.
Postby HAMAR » Thu 28. Oct 2010 00:00
Postby sindrib » Thu 28. Oct 2010 01:05
Dannyp wrote:Image
:drool: more
Merkur(sierra) xr4ti
sindrib
Postby HAMAR » Thu 28. Oct 2010 07:04
Postby rockstone » Thu 28. Oct 2010 10:14
rockstone
Postby rockstone » Thu 28. Oct 2010 10:24
rockstone
Postby íbbi_ » Thu 28. Oct 2010 11:06
þetta er nú orðið að ljóta rúnkþræðinum..
þá hendi ég þessi inn, spurning hvort einhver kannist við þetta
