!!!VANTAR!!! UPPER SPRING PLATE á M52B28
Postby Omar_ingi » Thu 27. Mar 2014 18:22
Mér vantar "UPPER SPRING PLATE" á M52B28
Sjá á mynd hérna Nr 8:
No. Description Supplement Qty From Up To Part Number Price Notes Photo
01 INLET CAMSHAFT 1 09/1998 11311703894 $585.21
02 CAMSHAFT EXHAUST 1 09/1998 11311703892 $585.21
03 INTAKE VALVE 33,0/5,94MM ? 09/1998 11341739820 ENDED
03 INTAKE VALVE 33,0/5,94MM ? 09/1998 11341739822
VALVE HEAD THICKNESS: +0,2MM
03 INTAKE VALVE W.OVERSIZE VA.SYSTEM +0,1MM 33,0/6,04MM ? 09/1998 11341739832 $114.53 +core
VALVE HEAD THICKNESS: +0,4MM
03 INTAKE VALVE W.OVERSIZE VA.SYSTEM +0,2MM 33,0/6,15MM ? 09/1998 11341739838 $114.53 +core
04 EXHAUST VALVE 30,5/5,94MM ? 09/1998 11341739821 ENDED
04 EXHAUST VALVE 30,5/5,94MM ? 09/1998 11341739823
04 EXH. VALVE W.OVERSIZE VA.SYSTEM +0,1MM 30,5/6,04MM ? 09/1998 11341739833 $156.19 +core
04 EXHAUST VALVE W.OVERSIZE VA.SYSTEM+0,2MM 30,5/6,14 ? 09/1998 11341739839 $156.19 +core
05 REPAIR KIT VALVE SEAL RING 2 09/1998 11349064457 $46.94
06 SPRING POCKET ? 09/1998 11341735254 $3.77
07 VALVE SPRING ? 09/1998 11347504268 $7.88
08 UPPER SPRING PLATE ? 09/1998 11341432453 $3.77
09 VALVE COLLET D=6 ? 09/1998 11341461405 $1.34
10 Hydraulic valve lifter ? 11321748884 $32.50
Mér vantar þetta sem ALLRA FYRST!!!
Ómar Ingi
Sími: 846-1534
Bílarnir mínir:
BMW E34 M5 3.8
BMW E30 325 90' "S50B32"
BMW E36 316 M-Tech
BMW E36 M3
Omar_ingi
Re: !!!VANTAR!!! UPPER SPRING PLATE á M52B28
Postby Omar_ingi » Thu 27. Mar 2014 20:11
Komið :)
Ómar Ingi
Sími: 846-1534
Bílarnir mínir:
BMW E34 M5 3.8
BMW E36 316 M-Tech
BMW E36 M3
Omar_ingi
