Til sölu kraftmikill magnari.
Postby gtturbo » Thu 02. Dec 2004 17:15
Til sölu er magnari að gerðinni DLS. Hann er sama og ekkert notaður og var keyptur í sumar.
Hér að neðan er hægt að lesa um hann.
ULTIMATE series A7 Five-channel amplifier rated at 4 x 60 Watts on the stereo channels plus 1 x 300 Watts from the mono sub channel.
Built to provide a complete in car entertainment system system with all necessary crossovers, all in one amplifier. For detailed information about the crossover possibilities please read the technical specifications.
Internal switches connects all amplifier inputs if you prefer to use only one RCA cable.
Built-in fan control. Remote sub level control with phase shift is included.
RMS output per channel at 13,8 volts, 20 Hz - 20 kHz , < 0,1% distortion.
Mode : AB
Number of channels : 5
Nominal power in 4 ohm : 4 x 60 W
Nominal power in 2 ohm : 4 x 100 W
Mono channel, nominal power in 4 ohm : 300 W
Mono channel, nominal power in 2 ohm : 440 W
S / N ratio, A-weighted : > 100 dB
Damping factor : > 200
Input impedance : > 10 kohm
Input sensitivity, variable : 0,3 - 7 V
Filter ch. 1 & 2 : Highpass: 80 - 400 Hz / 1,6 - 8 kHz (x20)
Filter ch. 3 & 4 : Highpass: 80 - 400 Hz. Lowpass 0,3 - 4 kHz / 3 - 40 kHz (x10)
Filters mono sub channel : Lowpass: 50-125 Hz.
Terminal for external cooling fan : Yes
Phase control : 0-180 degrees continuously
Remote sub level control with phase shift : Yes
Dual DC-inputs : No
Current draw, idle : 1,1 A
Current draw, maximum : 120 A
Dimensions W x D x H : 605 x 240 x 73 mm (23,82 x 9,45 x 2,87 inch)
Weight
: 8,1 kg ( 17,86 lb)
Ásett verð á magnarann er 69.900kr.
Áhugasamir sendið mér einkapóst eða hringið í síma 863-9443
Úlli
Impreza turbo 2stk seldar
Audi A4 1.8 Turbo seldur
MMC Lancer EVO 8 MY04 2stk seldir
BMW M5 MY90 seldur
Toyota Corolla SI MY93 seld
Volvo S40 T4
gtturbo
Postby Kull » Fri 03. Dec 2004 09:48
Ég hef reynslu af þessum og get sagt að þetta er mjög góð græja. Magnarinn er mjög vandaður og power tölurnar eru allar mjög hógværar enda er þetta engin smásmíði að stærð og þyngd.
C32 AMG Carlsson
Toyota Land Cruiser 80
Subaru Impreza GX - beater!
Kull
Postby gtturbo » Wed 15. Dec 2004 15:42
Ennþá til sölu!!!
Úlli
BMW M5 MY90 seldur
Volvo S40 T4
gtturbo
