óska eftir ventlagormum
Postby wulff » Tue 30. Apr 2013 00:10
óska eftir ventla gormum úr e34 M5 bíll
wulff
Re: óska eftir ventlagormum
Postby srr » Tue 30. Apr 2013 00:17
Þetta liggur eflaust ekki hvar sem er,,,,,
S14, S38 og S50 mótorar sem eru með þetta sama,,,,,
Part 11341315912 (SET VALVE SPRING YELLOW/RED) was found on the following vehicles:
E30 M3 Coupe, S14, Europe, MANUAL (1001) : Valve Timing Gear - Cam Shaft
E30 M3 Coupe, S14, Europe, MANUAL (1007) : Valve Timing Gear - Cam Shaft
E30 M3 Coupe, S14, Europe, MANUAL (1005) : Valve Timing Gear - Cam Shaft
E34 M5 3.6 Sedan, S38, USA, MANUAL (HD93) : Valve Timing Gear - Cam Shaft
E34 M5 Touring, S38, Europe, MANUAL (HJ91) : Valve Timing Gear - Cam Shaft
E34 M5 3.6 Sedan, S38, Europe, MANUAL (HD91) : Valve Timing Gear - Cam Shaft
E34 M5 3.6 Sedan, S38, Europe, RHD, MANUAL (HD92) : Valve Timing Gear - Cam Shaft
E34 M5 3.8 Sedan, S38, Europe, MANUAL (HC91) : Valve Timing Gear - Cam Shaft
E34 M5 3.8 Sedan, S38, Europe, RHD, MANUAL (HC92) : Valve Timing Gear - Cam Shaft
E36 M3 Convertible, S50, Europe, MANUAL (BJ91) : Valve Timing Gear - Cam Shaft
E36 M3 Convertible, S50, Europe, MANUAL (BK91) : Valve Timing Gear - Cam Shaft
E36 M3 Convertible, S50, Europe, RHD, MANUAL (BJ92) : Valve Timing Gear - Cam Shaft
E36 M3 Convertible, S50, Europe, RHD, MANUAL (BK92) : Valve Timing Gear - Cam Shaft
E36 M3 Coupe, S50, Europe, MANUAL (BF99) : Valve Timing Gear - Cam Shaft
E36 M3 Coupe, S50, Europe, MANUAL (BG91) : Valve Timing Gear - Cam Shaft
E36 M3 Coupe, S50, Europe, MANUAL (BF91) : Valve Timing Gear - Cam Shaft
E36 M3 Coupe, S50, Europe, RHD, MANUAL (BG92) : Valve Timing Gear - Cam Shaft
E36 M3 Coupe, S50, Europe, RHD, MANUAL (BF92) : Valve Timing Gear - Cam Shaft
E36 M3 Sedan, S50, Europe, MANUAL (CD91) : Valve Timing Gear - Cam Shaft
E36 M3 Sedan, S50, Europe, MANUAL (CB91) : Valve Timing Gear - Cam Shaft
E36 M3 Sedan, S50, Europe, RHD, MANUAL (CB92) : Valve Timing Gear - Cam Shaft
E36 M3 Sedan, S50, Europe, RHD, MANUAL (CD92) : Valve Timing Gear - Cam Shaft
Z3 Z3 M Coupe, S50, Europe (CM91) : Valve Timing Gear - Cam Shaft
Z3 Z3 M Coupe, S50, Europe, RHD (CM92) : Valve Timing Gear - Cam Shaft
Z3 Z3 M Roadster, S50, Europe (CK91) : Valve Timing Gear - Cam Shaft
Z3 Z3 M Roadster, S50, Europe, RHD (CK92) : Valve Timing Gear - Cam Shaft
Postby Alpina » Tue 30. Apr 2013 00:48
wulff wrote:óska eftir ventla gormum úr e34 M5 bíll
Hversu mörgum ??
bubbim3 gæti átt þetta
