HKS ssqv blow off valve(GLÆNÝTT)
Postby haukurn » Tue 15. Mar 2011 15:48
er með svona til sölu
black edition limited
HKS Super Sequential Blow-Off Valve (SSQV) is a dual stage pull-type relief valve. Unlike typical push type blow-off valves, the SSQV will not leak under any level of boost. For maximum performance, the HKS SSQV incorporates both a small primary valve for ultra quick activation, and a larger secondary valve for additional discharge capacity. The SSQV is constructed of billet aluminum, which ensures long-term durability and a high luster look. The mounting base utilizes a circular mounting flange that combines with a C-clip snap ring and O-ring gasket to insure an excellent seal. The triple-fin discharge port design produces a powerful, unique and aggressive blow-off sound.
það sem fylgir með
# 1 x HKS Blow off valve
# 1 x C-clip
# 1 x O-ring
# 2 x T fitting
# 1 x Vacuum filter
# 3 x tie wrap
# 1 x Instruction manual
verð:25 þúsund
síminn er 8460007 haukur
haukurn
Re: HKS ssqv blow off valve(GLÆNÝTT)
Postby bErio » Tue 15. Mar 2011 16:07
P.s. Þetta gerir kellingarnar alveg vittlausar i rottunni
BMW E39 540i '00 - Sedans
E39 k1ng
Sævar P.
bErio
Postby Mazi! » Tue 15. Mar 2011 16:27
bErio wrote:P.s. Þetta gerir kellingarnar alveg vittlausar i rottunni
:naughty: :naughty:
Postby Alpina » Tue 15. Mar 2011 19:22
Og karlana brjálæða í borunni
Postby haukurn » Tue 15. Mar 2011 19:28
mikið rétt sævar 8) eigum við ekki bara að mixa þetta á bimmann ?
haukurn
Postby haukurn » Fri 01. Apr 2011 18:36
ttt. þessi seldist fljott, en er kominn með annan nákvæmlega eins í hendurnar !
8460007 haukur
haukurn
Postby haukurn » Sun 10. Apr 2011 12:49
upppá topp. hann sem ætlaði að kaupa er alltof lengi að kaupa =)
haukurn
Postby haukurn » Tue 12. Apr 2011 16:30
ttttttttt
haukurn
Postby BMW_Owner » Wed 13. Apr 2011 15:31
og hvað, þarf maður síðan að mixa loftdælu á þetta til að hljóðin komi ef maður er ekki með turbó :lol:
BMW 528Ia
BMW_Owner
Postby haukurn » Fri 15. Apr 2011 11:17
BMW_Owner wrote:og hvað, þarf maður síðan að mixa loftdælu á þetta til að hljóðin komi ef maður er ekki með turbó :lol:
já það er klárlega málið, og bara með takka inní bíl :o
haukurn
