TS 2x magnarar SoundStorm Force F2000 og Pioneer PRS-D2000
Postby -Hjalti- » Thu 17. Feb 2011 17:39
Er með þennan SoundStorm Force F2000 KLIKKAÐAN Magnara
Verð 20.000kr skoða skipti á ýmsu
Sendist í PM
Force Series Monoblock Amplifier
RMS Power Rating:
4 ohms: 500 watts x 1 chan.
Max power output:
2 ohms: 2000 watts x 1 chan.
Bridgeable
Wired remote bass level control included
LED power/protect indicators
Protection (thermal, overload and speaker short)
Bass Boost (0-18 dB bass boost at 50 Hz)
Tri mode operation
2/1 channel operation
Line and speaker-level inputs
Heavy duty aluminum alloy heatsink
Variable input gain control
Chrome-plated RCA level inputs
Chrome-plated screw terminals
Variable low-pass filter (40-150 Hz)
Frequency response: 9-50,000 Hz
Damping Factor: 125
Dimensions: 15-7/16"L x 10"W x 2-7/16"H
4-gauge power and ground wiring is required for installation. Contact us for information regarding a discount on select amplifier kits when purchased together with this amplifier.
1-year Manufacturer's warranty
Amplifier Specifications
Amplifier Class AB
Number of Channels 1 - Mono
RMS Power (4 ohms) 500 watts x 1 channel
RMS Power (2 ohms) N/A
Pioneer PRS-D2000
2 Channel Class-FD Amplifier 2 x 600W
Verð 15.000kr þ Skoða ýmis skipti
Sendist í skilaboðum
Specifications PRS-D200
Maximum Output Power 1 x 1200W (4Ω) or 2 x 600W (4Ω)
Continuous power output (RMS) 14.4V (20Hz-20kHz/4Ω): 2 x 150W
14.4V (1kHz/2Ω): 2 x 300W
14.4V (bridged 1kHz/4Ω): 1 x 600W
The PRS-D200 amplifier incorporates ICEpower® digital design, with undisputed industry-leading efficiency. Our Class-FD ICEpower amps deliver maximum power with minimum distortion – overcoming the lower sound quality of traditional Class D Amps.
The amp also includes a convenient hard wired Bass Boost Control, from which your can select a bass level of 0,6,9 or 12 dB.
This 2-channel amp has a tight, compact design – without compromising on power output and quality levels - which makes for easier installation.
Load impedance capability (2 - 8Ω allowable) ≥4Ω
Frequency response 10 - 40 Hz
Distortion <0.005 %
S/N ratio >100 dB
Bass Boost 50 Hz, 0/6/9/12 dB (remote)
LPF 40 - 120 Hz (-12dB/oct)
HPF 40 - 120 Hz (-12dB/oct)
RCA terminals Yes (input/output)
Speaker Terminals Gold-plated screw-type
Max. current consumption (A/4ohms) 25.8 A
Chassis size (W x H x D) 304 x 56 x 202 mm
Unit weight 2.9 kg
00' E38 750i
-Hjalti-
