FLOTTUR 5,6" LCD Snertiskjár í bíl
Postby knuturksk » Mon 24. Jan 2011 17:04
Ég er að selja mjög flottan og góðan ÓNOTAÐANN / GLÆNÝR (ennþá í kassanum, aldrei verið settur í bíl) spilara í bíl sem er með nánast öllu !!! Mjög þægilegt að tengja iPod við og stjórna honum með snertiskjánum, hægt að stilla bassabox og já bara gera allt sem svona spilarar gera (spilar meira að segja divX myndir (myndir/þættir tekið af netinu). Mjög auðvelt að smella skjánum af til þess að koma í veg fyrir þjófnað ;)
Í kassanum fylgir með snúra sem tengist beint í iPod (hleður einnig), fjarstýring og allar aðrar nauðsynlegar snúru.
Meiri upplýsingar hér:
Overview
This car entertainment features digital a variety of functions, which enable you to enjoy DVD movies, listen to music, and watch TV channels all from the comfort of your car. Operation is easy with the 5.6 '' TFT LCD digital touch screen design, and the Bluetooth function allows for greater maneuverability. Go with this player and liven up your journeys!
Touchscreen: Easy-to-use and responsive touchscreen allows for smooth navigating. No more do you have to worry about trying to press all those tiny little buttons – Touchscreen will make using your player a breeze!
Bluetooth: The Bluetooth function allows you to have handsfree conversations with your callers through your car stereo system, giving you a office away from your office! A simple pairing with your mobile phone when you first climb into your car means you won't miss calls while you're on the road.
Digital Touchscreen: The 5.6” LCD-TFT screen shows amazingly crisp images, and the touchscreen allows truly intuitive interaction. This easy to use interface not only looks good, but is convenient for quick switching from one entertainment choice to another.
USB Port: With an USB Port, your options are unlimited! Play downloaded videos and films, or import your own music. The player supports MP4, DivX, WMA, MP3, and JPG formats along with the usual DVD options.
Analog TV Receiver: Have an endless source of entertainment with the analog TV receiver, which allows you to tune into general TV channels wherever you go! Keep yourself in touch with the news, or simply flip through the channels for hours.
FM Radio: A built-in FM tuner lets you tune into your favorite radio station wherever you are – great for chilling out and relaxing to some music whenever you feel like taking a break from the daily grind.
Features:
。Compatible with DVD,DVD-R,DVD-RW,HDVD,DVCD,MP3,MP4,CD-R,CD-RW,VCD,DIVX,WMA,and so on
。5.6-inch TFT-LCD screen
。Bluetooth
。Support Ipod
。RDS Function
。Multi-function IR remote control and instruction manual included.
。Compatible with multi-languages.
。Video and audio output, and rear monitor video.
。Automatic adjustable panel.
。Digital audio output, and 50Wx4 max power output.
。Built-in AM/FM tuner.
。TV-tuner with PAL/NTSC/SECAM:D/K.I.B/G.M video system.
。Support SD card funcation with USB slot。Bluetooth: Built-in bluetooth for mobile hands-free.
。TV system: Analog TV tuner, auto select NTSC, PAL
。Radio receiving: FM/AM
。Car backing display: It can connect the rearview camera
。Operation menu of language: English
。Full function remote Control
Specifications:
System
Form Factor In-Dash
Enclosure Type 1 Din
Security Features Detachable Faceplate
Features Built-in Bluetooth , TV Function , Radio Function , Subwoofer Output , Support Ipod
Display
Display Mode 16:9
Screen Size 5.6 "
Touch Screen Yes
Screen Resolution 480 x 234
Display Type LCD-TFT
Brightness Control Yes
OSD Language English, Chinese
Radio
Radio Tuner FM, AM
Station Preset Qty 30
Support RDS Yes
Radio response bandwidth AM: 520-1700 Hz ; FM: 87-110 Hz
DVD
Video Output System NTSC, PAL
Video Output
  D/K.I.B/G.M
Media Type CD , DVD-R/RW , DVD-RAM , Video CD , Mp3 , Mp4 , WMA , JPEG
TV tuner
Digital TV or Analog TV Analog TV tuner
TV antenna 1 TV antenna input on the back(You can buy TV antenna on shopping chart)
Amplifier
Form Factor In-dash unit integrated
Amplifier max output power / channel qty 50 Watts x 4
Bluetooth
Version V2.0,support AD2P(Bluetooth Stereo Music),can play stereo music through Bluetooth
Built-in microphone Yes
Received Call Yes
Dialled Call Yes
Missed Call Yes
Remote Control
Remote Control Technology Infrared
Interface
A/V Input 2 Channel
A/V Output 2 Channel
Connector Type 1 x A/V IN , 1 x A/V OUT , 1 x BRAKE CHECK , 1 x REARCAMERA , 1 x CONNECTERS (POWER ETC) , 1 x AUX-IN , 1 x TV ANTENNA , 1 x SUBWOOFER , 1 x IPOD
USB/SD Card Port USB Port, SD Port
Ipod Control Yes
Direct Connection Cable for Ipod Included Yes
Additional Features
Portable HDD Compatible No
Built-in Speaker No
CDC(CD Charger) No
Subwoofer Output Yes
Motorized slide-down Face Yes
Anti-Shock Yes
General
Color Black
Dimensions/W*D*H 185*175*50mm
Operation Temperature -10℃~50℃
Storage Temperature -20℃~75℃
Warranty 1Year
What's in the box 1 DVD Host, 1 Remote Control, 1 User Manual, 1 Cable Set, 1 Screw Set, 1 iPod Cable, 1 USB Cable, 1 Touch Pen
Hann er 1 din (tekur eitt pláss, sem þýðir að hann passar í "alla" bíla )
[COLOR="red"][SIZE="3"]Verð: 65.000 kr. / besta boð !
Skoða öll skipti !
[/SIZE][/COLOR]
ATH SKÍTKÖST Í PM/ Reportuð........ TAKK !!!!!!!!!!!!!
Knútur, 8676663
knuturksk
Re: FLOTTUR 5,6" LCD Snertiskjár í bíl
Postby gimpuz » Fri 28. Jan 2011 17:33
Hvaða tegund er þetta?
Ertu með týpu númer á gripinum?
Hver er umboðsaðilinn/Söluaðili á Íslandi?
Óska eftir Fornbíl
gimpuz
