DVD Bílaspilari Með 5"Skjá Til SÖLU
Postby levy » Sat 01. May 2010 14:34
Rosaspilari glænýr til sölu
65þús kr..
Sími 6962682
Product Description:
CL-502
One din car DVD player
Vehicle multimedia player and Bluetooth system with 5 inch display.
Discs/Formats Played:
-Discs: DVD, CD, VCD
-File types: MP4, AVI, DIVX, XVID, VOB, MPG, MPEG, MP3, AAC, JPEG
Operation: Touch screen or remote control
Display Information
-Screen: 5 Inch TFT LCD
-Aspect Ratio: 16: 9
-Resolution: 480x234 RGB
-Angle: 0 to 90 (motorized sliding display panel)
-Brightness: 300 CD/m2
-Video Systems: PAL, NTSC, AUTO
Bluetooth Functions
-Pair with phone - then use touchscreen interface
-Dial, Receive, Disconnect calls
-Volume Control
-Touchscreen keypad
Audio Information
-Max Audio Output: 50W x 4
-Signal-To-Noise Ratio (SNR): >85dB
-User adjustable EQ, Bass, Treble, Fade and Balance
AM/FM Tuner
-AM Frequency Range: 522~1620KHz (worldwide)
-FM Tuning Range: 87.0~108.0MHz (worldwide)
TV Tuner Information
-TV Type: Analog
-Tuner Frequency Bands: VHF-L, VHF-H, UHF
-Color Systems: PAL M, PAL N, SECAM DK, NTSC, PAL I, PAL DK, PAL BG
Front Panel Controls
-Power ON/OFF
-Reset
-Mode select
-Volume dial
-Radio band select
-Disk eject
-Built-in MIC
-Answer calls/AV settings
-IR port
-Forward
-USB port
-Faceplate detach
-Back
-Display angle adjust
Media Inputs
-USB drive slot
-SD/MMC card slot
-DVD/CD disc slot
Cables/Wires
-Radio Antenna IN port
-TV Antenna IN port
-RCA Audio OUT x2 (front L and R)
-RCA Audio OUT x2 (rear L and R)
-AUX Audio IN (R/L)
-SUBWOOFER OUT
-Video OUT
-Rearview Camera IN (AV Video IN)
-AUX video IN
Certifications: CE, FCC
Dimensions: 181mm x 165mm x 50mm (L x D x H); Depth = 211mm including front panel
System Main Menu (color icons) Language: English
DVD Menu Languages: English, Chinese, Spanish, Italian, Russian, Polish
levy
