Apexi RSM GP - Rev Speed Meter GP
Postby -Hjalti- » Thu 22. Apr 2010 23:28
Er með til sölu nýjan og ónotaðan Apexi RSM GP - Rev Speed Meter GP
Hægt að mæla nánast allt með þessari græju, lesið bara lýsinguna hér fyrir neðan.
Með þessu fylgir taska undir unitið svo að skjáin rispist ekki við flutning
Verð úti er $268.00 og þá á eftir að flytja þetta inn.. er ekki með neitt fast verð en bara bjóða
Apexi RSM-GP Rev/Speed Meter. Like the original, the new Rev/Speed Meter GP is a complete multi function measuring device designed to measure and monitor data such as vehicle speed, engine RPM, and elapsed times. However, the strength of the new unit lies in its differences. The most obvious is its completely redesigned look. This new aesthetically pleasing model was crafted to match the likes of other highly popular A'PEX electronics such as the V-AFC (VTEC Controller) and the AVC-R (Boost Controller). The new screen utilizes the easy to read VFG (Vacuum Fluorescent Display) with built in light sensor used in many of A'PEX's line up.
The new unit also delivers a host of new functions. Standard features include: Engine RPM, Vehicle Speed, Travel Distance, and Battery Voltage (All which can be displayed in real time graph mode, numerical mode, or analogue mode; 1-4 channels at a time), Peak Hold, Replay (With 60 second playback), Speed Limiter Cut, 0-100m, 200m, 400m times with trap speed, 0-100km/h, 200km/h, 300km/h ? 0 times, user defined Mid Range Acceleration, Stop Watch functions, Best Time Memory, RPM Warning, Speed Warning, RPM and Speed Outputs (For external devices requiring an RPM or speed signal), Tire Size Correction (For acceleration and timing accuracy). And Vehicle weight input. One of the most exiting of the new features is the option to utilize the revolutionary A'PEX G-Sensor . . By taking advantage of the G-Sensor, the user can produce extremely accurate acceleration measurements. Usually, when mThe G-Sensor allows the unit to measure G forces in 4-way front/rear/left/right directions. This data can be plotted in a graph display to map acceleration characteristics and lateral G?s on the race track, or used the an array of new features including : Highly accurate 100m/200m/400m times with trap speed and wheel-spin correction, Horse Power Calculation, and Loss Power Calculationeasuring acceleration times using the speed sensor signal alone, the meter will end measurement too early (shorter distance) due to wheel-spin. Using the G-Sensor modifies the speed sensor signal, compensating for wheel-spin and producing impeccably accurate acceleration times.
00' E38 750i
-Hjalti-
Re: Apexi RSM GP - Rev Speed Meter GP
Postby -Hjalti- » Sun 25. Apr 2010 15:27
20.000
00' E38 750i
-Hjalti-
Postby -Hjalti- » Mon 26. Apr 2010 13:44
uppp
00' E38 750i
-Hjalti-
Postby -Hjalti- » Thu 29. Apr 2010 08:18
ttttttttttt
00' E38 750i
-Hjalti-
Postby -Hjalti- » Fri 30. Apr 2010 13:11
tttttttttttt
00' E38 750i
-Hjalti-
Postby -Hjalti- » Sat 01. May 2010 20:46
TO THE TOP
00' E38 750i
-Hjalti-
Postby -Hjalti- » Sun 02. May 2010 19:29
TTTTTTTT
00' E38 750i
-Hjalti-
Postby -Hjalti- » Wed 05. May 2010 23:57
uppppp
00' E38 750i
-Hjalti-
