300w hátalarar
300w hátalarar
Postby Zed III » Wed 22. Apr 2009 09:46
Líta svona út fyrir utan að það eru auðvitað hlífðargrind meðfylgjandi
Set á þá 4000 eða tilboð
Upplýsingar um hátalarana
300 Watts output
size 6x9'
3 way speakers
92 dba
50-21000 Hz
GTO 935e
Polypropylene woofer cone with fine mesh finish - for a great transient attach and high power handling.
Tweeter wiring through post mounted pole piece - for increased reliability and better sound by an improved piston behaviour (selected models only)
20mm Kaladex Neodym Dome Tweeter - for smooth and flawless response up to 21kHz even at high output levels.
PlusOne woofer cone - provides larger cone surface for an increased bass output and higher efficiency (selected models only)
UniPivot 335 - Rotating and 10 degree - angled Tweeter - for flexicble mounting options and optimized imaging (some coax models only)
I-Mount Tweeter Mounting System includes all the hardware necessary for surface mounting flush mounting or angling.
Oversized Woofer Magnet - for high efficiency and power handling.
Metal grilles (except drop-in models)
Metal Speaker Basket - high stability and longer life.
Separate 12dB crossover box for Component Systems
Rubber Surround - for high cone edge suspension and long durabililty
Benedikt Guðmunds. 615-2630
Zed III
